- 680
- 220 小时
- 2017-7-21
- 50
- 777546
- 640
- 680 点
- 619 ¥
- 2014-12-22
关于 TIM ,可見:
http://en.wikipedia.org/wiki/Audio_power_amplifier#Further_developments_in_amplifier_design
For some years following the introduction of solid state amplifiers, their perceived sound did not have the excellent audio quality of the best valve amplifiers (see valve audio amplifier). This led audiophiles to believe that valve sound had an intrinsic quality due to the vacuum tube technology itself. In 1970, Matti Otala published a paper on the origin of a previously unobserved form of distortion: transient intermodulation distortion (TIM),[3] later also called slew-induced distortion (SID) by others.[4] TIM distortion was found to occur during very rapid increases in amplifier output voltage.[5] TIM did not appear at steady state sine tone measurements, helping to hide it from design engineers prior to 1970. Problems with TIM distortion stem from reduced open loop frequency response of solid state amplifiers. Further works of Otala and other authors found the solution for TIM distortion, including increasing slew rate, decreasing preamp frequency bandwidth, and the insertion of a lag compensation circuit in the input stage of the amplifier.[6][7][8] In high quality modern amplifiers the open loop response is at least 20 kHz, canceling TIM distortion.
简单来说,就是现代音频放大器根本不可能出现 TIM 。 |
