890 点
740 ¥
发表于 2006-12-19 23:50 | 显示全部楼层
別沉啊<img alt="" src="http://www.hifidiy.net/bbs/Skins/default/topicface/face3.gif"/><br/><br/>手上還有4支17000uf/75vdc的AeroM電容等着餵飽這線路...呵呵<img alt="" src="http://www.hifidiy.net/bbs/Skins/default/topicface/face4.gif"/>
1026 点
280 ¥
发表于 2006-12-20 08:58 | 显示全部楼层
<p>diyaudio上转过来的。个别元件值有变化,仅供参考。</p><p></p><p> (, 下载次数: 12)
890 点
740 ¥
发表于 2006-12-20 17:44 | 显示全部楼层
<div class="quote"><b>以下是引用<i>windtf</i>在2006-12-20 8:58:00的发言:</b><br/><p>diyaudio上转过来的。个别元件值有变化,仅供参考。</p><p></p><p><img src="attachments/dvbbs/2006-12/200612208571776624.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-12/200612208571776624.gif\');}" onmousewheel="return imgzoom(this);" alt="" /><br/><img src="attachments/dvbbs/2006-12/200612208572435733.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-12/200612208572435733.gif\');}" onmousewheel="return imgzoom(this);" alt="" /><br/></p></div><p>取消了10欧浮地阻,把回授電容由470uf減至220uf,效果會是怎樣?</p>[em05]
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2006-12-20 17:59 | 显示全部楼层
<p>浮地阻还是很有效果的.470电阻改至220应该无碍.</p><p>另外,W兄,我加了你的MSN.</p>
98
I love DIY!
2240 点
1968 ¥
发表于 2006-12-21 14:49 | 显示全部楼层
<p>准备做,刚画好了PCB,保险丝没画,准备装到电源上,[em03][em03]</p><p>
[贴图]经典分离功放 Symasym 装机报道.呵呵.
<br/></p>
890 点
740 ¥
发表于 2006-12-21 20:33 | 显示全部楼层
<div class="quote"><b>以下是引用<i>binphy</i>在2006-12-21 14:49:00的发言:</b><br/><p>准备做,刚画好了PCB,保险丝没画,准备装到电源上,[em03][em03]</p><p><img src="attachments/dvbbs/2006-12/2006122114471750749.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-12/2006122114471750749.gif\');}" onmousewheel="return imgzoom(this);" alt="" /><br/></p></div><p></p>不玩白不玩,如能画成細長型的,輸出管用两對,以備擴大輸出或加大電流,將更完美<img alt="" src="http://www.hifidiy.net/bbs/Skins/default/topicface/face4.gif"/><img title="em07" src="http://www.hifidiy.net/bbs/Skins/Default/emot/em07.gif" style="CURSOR: pointer;" alt=""/>
3891 点
3708 ¥
发表于 2007-3-21 19:25 | 显示全部楼层
HOHO我的7294开机也没PENG!!!
565 点
472 ¥
发表于 2007-3-27 16:08 | 显示全部楼层
<p>有一点不明白 谈到R2的虚接地 那是什么意思,又是怎么做的,好处是什么?为什么有这样的好处?</p>
215 点
100 ¥
发表于 2007-4-1 15:37 | 显示全部楼层
顶一下这个帖子,提几个菜问题。
1、这个电路如果加大偏置变成A类输出是不是能够进一步改善性能?调到A类的话其他部分是不是需要作相应的改动?
2、前面的两个差分对是不是还有改进的余地?比如第二个差分对/镜像电流源,如果把2N5401/2N5551换成BC546/556或者换成hfe更大的型号对性能会有什么影响?
3、那个22p反馈电容,ary老师说大些则高音会好些,小些则系统稳定性好些,这里有点不明白。如果这个电容加大是不是高频反馈会加深,闭环增益减小,同时对高频反馈信号的相移也有一定的补偿?为什么大了系统反而不稳定呢?若高频闭环增益减小,为什么听起来反而高频会更好些呢?不会觉得高频减少吗?
4、电压放大级和推动级之间的两个22Ohm电源耦合电阻,如果换成稳压(LM317/337或者简单的三极管+稳压管共基极),对性能会有怎样的影响?
在ary老师发的新学期课本里翻到如下的A类电路,据说理论性能很好。
这个图里有不少有意思的东西:输入差分对用电流源武装到了牙齿,A/B类偏置可以切换,用差分对和参考电压源做的偏置电流稳定电路,输出级保护电路。这些东西如果结合到这个Symasym里面会有意义吗?特别问一下输入差分对反馈这里的C15/R47,这个据作者说对提高高频稳定性很重要,为什么?好像在很多电路里都没有这样的设计。
215 点
100 ¥
发表于 2007-4-3 15:13 | 显示全部楼层
没人理了,是不是问题太菜了?
自己顶一次
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2007-4-3 16:03 | 显示全部楼层
1,我们说AB类主要是针对交越失真而言的,在这里效果不是很明显。我最大调到300mA试过。用的是MJL21193/4,没感觉出明显差别
2,第二级的管子用这种小管子本来就有点小热了,你用BC546换上可能会更热。你要能在发热和hFE还有截止频率上找到合适的估计也是可以试试。这个我没试过换管,你换后记得说说听感,
3,电容越小,当然高频越多罗,呵呵。只在保证足够的”相移稳定区域“,这个电容应该是尽量小的,这个的理论依据是那个叫“Bode"图的东西。你可以找点相关资料看一下就明白了。
4,这个东西理论上换稳压当然会好罗,不过实际上我看到过国外很多人讨论过,要么就说电阻足够了换稳压不明显,要么就说感觉很怪声音反而很干,我在Quad 405上试过将稳压管那部分换独立电源用的是LT的高性能12V稳压芯片。没感觉到改善。
5,这张电路图暂时没时间分析,以后有空了给你补上,呵呵。
注:以上是我个人的理解,不一定全对,欢迎继续讨论,最好结合听感与相关知识的统一就最好不过了。
:18
367
4000 点
1902 ¥
发表于 2007-4-3 16:06 | 显示全部楼层
这种电路我觉得调高静态电流没什么用
367
4000 点
1902 ¥
发表于 2007-4-3 16:18 | 显示全部楼层
这种电路我觉得调高静态电流没什么用
纯甲才有用 但是太大我觉得也不行 动态范围被压缩了
A/B类克服交越失真的方法是“制造出”那一小截 我觉得本质上是不保真的
ary老大还有没有套件啊 我的烧了一块 很郁闷哦
96
2274 点
1930 ¥
发表于 2007-4-9 14:19 | 显示全部楼层
搂主你好,我也作了一块sym板mpsa18找不到,用2240先带了,我现在0。22欧上的压降为20mv,可以吗?中点输出开机时2.5mv稳定后4.5mv。mpsa18请问哪有卖
谢谢
215 点
100 ¥
发表于 2007-4-9 14:50 | 显示全部楼层
顶一下,我也备料备的差不多了。计划先用洞洞板作成同样结构但增益和功率都缩小的耳放或者前级,顺便试验几个改动的方案。都试成熟了再做大功率的。
mpsa18在著名的李老师那里有卖配对的,就是价钱高点。我定的还在路上呢。
96
2274 点
1930 ¥
发表于 2007-4-9 16:06 | 显示全部楼层
谢谢fisheryu
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2007-4-9 16:10 | 显示全部楼层
原帖由 szccm 于 2007-4-9 14:19 发表
谢谢
mpsa18我也没用,我用BC550的。替换足够了
20mV可以的
96
2274 点
1930 ¥
发表于 2007-4-9 17:12 | 显示全部楼层
谢谢,搂主,今晚开声
1530 点
1152 ¥
发表于 2007-4-9 20:16 | 显示全部楼层
上11032.033有惊喜!!!!!!!!!!!!!!!!!!!!!!!!
96
2274 点
1930 ¥
发表于 2007-4-12 10:29 | 显示全部楼层
我的sym自己热转的板
GMT+8, 2025-12-19 08:09 , Processed in 0.125513 second(s), 6 queries , Gzip On, Redis On.
