[分立前级] 讨论一下JC2的两个问题
[复制链接] 查看: 68512|回复: 191
346 点
334 ¥
 楼主| 发表于 2010-6-7 23:04 | 显示全部楼层
关注,是迁就管子?还是其它原因?
441 点
421 ¥
发表于 2010-6-8 10:45 | 显示全部楼层
有人能把 2010板的JC-2 图貼上來,討論一下嗎 ?
5672 点
5633 ¥
发表于 2010-6-8 13:41 | 显示全部楼层
95# 一孤
2010 JC-2用24v供电,所以动态和低频有明显改善,原作者 John Curl 说可以直接推动耳机
John Curl在什么时候说的,可否把原话贴出来。
Sorry that I did not get back to answer questions, I didn't see this thread for awhile.
Unfortunately, I cannot give additional info on the JC-2 attenuators, as I did not design them.
这是John Curl在前天说的话,对于JC-2衰减器他不能够提供更多的资料,因为他没有设计它们,
这直接推耳机的说法从何而来?
5672 点
5633 ¥
发表于 2010-6-8 13:46 | 显示全部楼层
101# WKJ
其所用的JFET的Idss=?,Vp=?
如用2N5434(Idss=30mA),
Rd=100欧姆,1Hz~200Hz线性也很好。
5672 点
5633 ¥
发表于 2010-6-8 14:38 | 显示全部楼层
JC-2输入并管,1Hz~100Hz线性,很好。
5672 点
5633 ¥
发表于 2010-6-8 14:50 | 显示全部楼层
Rd=300 VS Rd=100
441 点
421 ¥
发表于 2010-6-8 19:07 | 显示全部楼层
95# 一孤
这是John Curl在前天说的话,他现在不设计JC-2。
ch639827608 发表于 2010-6-8 13:41
翧譯上的意思有出入!
JC 意謂 : "當年的attenuators不是他設計"
據我知,現他為 Parasound 做設計 !
5672 点
5633 ¥
发表于 2010-6-8 20:01 | 显示全部楼层
108# oldboy
啊,是阁下这说法对,就是衰减器不是他设计的。
545 点
535 ¥
发表于 2010-6-8 21:27 | 显示全部楼层
95# 一孤
这直接推耳机的说法从何而来?
This is a low feedback, high open loop bandwidth design, that originally was designed as a cable driver of about 50 ft or more, for the Grateful Dead, 'Wall of Sound' PA system, designed in 1973. YES, we set the original idle at about 50 ma in the output stages in order to operate at peak beta of the 2W, heatsinked high speed devices that we chose. This was trimmed down slightly in the JC-2 line stage, because such need for long cable driving was not as important. 600 ohms was our design target and common in pro sound at the time. The original design used +/- 24 V power supplies, as well, for added headroom. It was pared down to +/- 15V for the JC-2, because the external power supply provided that voltage.
__________________
"Condemnation without Examination is Prejudice"
http://www.diyaudio.com/forums/s ... 16.html#post1971908 1157楼
5672 点
5633 ¥
发表于 2010-6-8 21:56 | 显示全部楼层
110# 一孤
他说的是1973的原设计用+/-24v供电,是要驱动50英尺的PA系统的电缆的,不是2010的设计,他也没说直接推耳机,当然你拿来推600欧姆的高阻耳机也可以,但这推耳机不是他说的。
该贴的时间是:
6th November 2009, 02:34 PM
JC-2要变成耳放,那20欧姆的Re必须减少,输出管换成中功率管,正负24v供电才行。
545 点
535 ¥
发表于 2010-6-8 22:27 | 显示全部楼层
110# 一孤
该贴的时间是:
ch639827608 发表于 2010-6-8 21:56
你真是专业人士,2010 JC-2的输出管是用中功率功的
346 点
334 ¥
 楼主| 发表于 2010-6-8 22:39 | 显示全部楼层
Rs已改作10R,电路还是14#贴出的电路,已经听2天.
声音风格没有改变,人声聚焦好了一点点,但要细心听才可察觉,总的来说是变化不大.
2180 点
2139 ¥
发表于 2010-6-8 22:40 | 显示全部楼层
上一个我最近做的陈兄的2010JC2
331 点
327 ¥
发表于 2010-6-8 22:49 | 显示全部楼层
请问各位,陈大师的2010JC-2板子哪里有买啊!!
346 点
334 ¥
 楼主| 发表于 2010-6-8 22:51 | 显示全部楼层
112# 一孤
传闻后期的厂机也是使用中功率管.
2180 点
2139 ¥
发表于 2010-6-8 22:58 | 显示全部楼层
我的也是双24V,中功率管
HIFI36度
2876 点
2828 ¥
发表于 2010-6-8 23:00 | 显示全部楼层
上一个我最近做的陈兄的2010JC2
WKJ 发表于 2010-6-8 22:40
很靓的JJ,有点心动的感觉,看来有机会也要找来做一个。
441 点
421 ¥
发表于 2010-6-9 03:10 | 显示全部楼层
110# 一孤
该贴的时间是:
文中的 "Headroom"不是 "Headphone", 請不要誤會 ! "
"for added headroom"可意解 :為增加寬容度
441 点
421 ¥
发表于 2010-6-9 03:13 | 显示全部楼层
大家讨论了 2010-JC 2那麽多, 但沒有人上傳图來一起分享, 失望
5672 点
5633 ¥
发表于 2010-6-9 11:37 | 显示全部楼层
headroom
[5hedru:m]
n.
[建]净空, 头上空间, 净空高度(拱梁等下面)
headroom
head.room
AHD:[hµd“r›m”, -r‹m”]
D.J.[6hed7ru8m, -7r&m]
K.K.[6hWd7rum, -7r&m]
n.(名词)
Space above one's head, as in a motor vehicle, above a doorway, or in a tunnel; clearance.
净空高度:如在机动车内、门上方或隧道中的某人头部上端的空间;空间
Electronics Dynamic headroom.
【电子学】 能活动的空间
在该文的意思为:功率裕量
