[DIY制作] 【LME49810TB俱乐部】 之 玩尽 49810
  [复制链接] 查看: 900769|回复: 1752
1558 点
1207 ¥
 楼主| 发表于 2010-5-17 15:33 | 显示全部楼层
先看一下LME49810TB的内部图:
1558 点
1207 ¥
 楼主| 发表于 2010-5-17 15:36 | 显示全部楼层
3.3k+75p是接在输入级后,电压放大级前。
将无用的超高频滤掉。
112 点
112 ¥
发表于 2010-5-17 15:48 | 显示全部楼层
119 点
122 ¥
发表于 2010-5-17 16:31 | 显示全部楼层
The circuit that is "added" in the posted drawing is actually a "noise gain compensation" circuit. (I had never seen one before Bob showed it to me!) It is required for the 4702 and the LME49811.
by Audioman54
- 楼上分析的不错。老外说这个是 “噪音增益补偿” 。不知道翻译的是否恰当。呵呵。
119 点
122 ¥
发表于 2010-5-17 16:32 | 显示全部楼层
而且再次强调,这个增加电路对于 49811 是必须的。
119 点
122 ¥
发表于 2010-5-17 16:38 | 显示全部楼层
With either the LM4702 or LME49811 I have listened to them both ways (and even did some single blind tests with others as subjects at National) and inverting wins every time! The 49810 is a little different animal but it is very close to the 811 sonically (with 10x the current out!) so you could use it if you need a higher power amplifer. My rule of thumb was 811 for all amps under 300W and 49810 for everything over that. Also the 810 has some nice extra features the 811 does not have like a clipping indicator output. I use the 811 in all my power amplifiers at home now and my 2 Krell KSA 200S amps are no longer used.
《- 这个老外说 他自制的49811 甚至干掉他自己家的 krell 。呵呵。
69
1601 点
1473 ¥
发表于 2010-5-19 16:54 | 显示全部楼层
LME49810芯片是一款高度原音的单声道音频功率放大器驱动器,最适用于音响发烧友及专业级的音频系统。LME49810内置优质、高性能功率放大器输出级驱动器所需的音频电路;可以输出50mA的电流;压摆率高达50V/us;电源抑 ...
wj_88 发表于 2009-9-5 17:26
http://item.taobao.com/auction/i ... 3b078fc05fc88b5.htm
使用 2SJ201+2SK1530  2对   单声道  有何改动?
1558 点
1207 ¥
 楼主| 发表于 2010-5-19 20:01 | 显示全部楼层
信誉 发表于 2010-5-19 16:54
链接失效,PM我把!
138 点
134 ¥
发表于 2010-5-20 23:44 | 显示全部楼层
1601 点
1473 ¥
发表于 2010-5-21 11:24 | 显示全部楼层
1150# wj_88
已PM
hi-fi之家那个文章给我发份,看不清
lfwife@slof.com
210 点
210 ¥
发表于 2010-5-21 11:26 | 显示全部楼层
对新手很有帮助,顶
非典防治专家
52 点
52 ¥
发表于 2010-5-21 16:07 | 显示全部楼层
继续关注中~~~
1558 点
1207 ¥
 楼主| 发表于 2010-5-22 23:37 | 显示全部楼层
1150# wj_88
q强烈希望  WJ-88  设计更多的好板  作为你的顾客 对你的东西感觉是非常不错了  ,同时希望你 除了开发 后级 的同时  多开发点前级用于搭配  像  KSA50   PASS 系列  都可以做 点  49810做了这么 ...
liusky2008 发表于 2010-5-20 23:44
开发了一款全分立元件前级,输入用的是孪生管对,非对称线路,场管甲类输出。
这款暖声的前级专门用于配LM49810TB等功放的。
最近进行了测试,从327楼开始看:
http://bbs.hifidiy.net/viewthrea ... age%3D1&page=17
637 点
623 ¥
发表于 2010-5-23 16:18 | 显示全部楼层
1148# tel5169553
没说干掉,只是说好久没用。
138 点
134 ¥
发表于 2010-5-24 12:21 | 显示全部楼层
304 点
304 ¥
发表于 2010-5-25 11:41 | 显示全部楼层
哈哈,,这些天在整里屋子 还在找10多年以前留下的东西,,变压器。喇叭。散热器。电容。管子。机箱。等东西!电容已经找到了1箱 33000UF/63V
准备上老大的7并板子 装4对1216 2922或者1494 3858  电压准备在60V 调试在纯甲
8 点
108 ¥
发表于 2010-5-25 11:46 | 显示全部楼层
138 点
134 ¥
发表于 2010-5-28 00:22 | 显示全部楼层
7 点
7 ¥
发表于 2010-5-31 12:56 | 显示全部楼层
2051 点
2004 ¥
发表于 2010-5-31 15:47 | 显示全部楼层
王兄被禁言了?
王兄,负反馈上并10P会不会太小了,怕引起高频自激。
GMT+8, 2026-4-14 04:08 , Processed in 0.166100 second(s), 8 queries , Gzip On, Redis On.
