[胆机制作] 土兄请进
[复制链接] 查看: 222026|回复: 1452
209
越减越繁
2743 点
996 ¥
发表于 2005-4-3 21:34 | 显示全部楼层
期待最终结果
[em09][em09]
158
超级贵宾 当前在线
打鬼子的
7483 点
2565 ¥
元老级 super 贵宾
发表于 2005-4-3 21:13 | 显示全部楼层
晕!猴年马月了!早开声了!
以下是引用fwi297在2005-4-3 19:42:00的发言:
靠!都不知道自己看到哪页了。
八路的2A3开声了没有?
目前,在J版指导下进行改进!
[em06][em06]
209
越减越繁
2743 点
996 ¥
发表于 2005-4-3 19:42 | 显示全部楼层
几天没来!
靠!都不知道自己看到哪页了。
八路的2A3开声了没有?
158
超级贵宾 当前在线
打鬼子的
7483 点
2565 ¥
元老级 super 贵宾
发表于 2005-4-1 20:51 | 显示全部楼层
我到处发贴!没人愿意做呀!
457 点
0 ¥
发表于 2005-4-1 19:05 | 显示全部楼层
8路兄
准备开工D1了吗?[em11]
12063 点
11762 ¥
发表于 2005-3-31 18:50 | 显示全部楼层
干脆开个英文版坛算了!
158
超级贵宾 当前在线
打鬼子的
7483 点
2565 ¥
元老级 super 贵宾
发表于 2005-3-31 00:33 | 显示全部楼层
还没翻译呢!
我只能看动一点![em02][em02]
157
8211 点
2614 ¥
 楼主| 发表于 2005-3-31 00:26 | 显示全部楼层
靠,这算什么翻译啊
[em12]
457 点
0 ¥
发表于 2005-3-30 21:19 | 显示全部楼层
Compression Chambers
The size of the compression chambers depends on the drivers and the frequency range you want from the horn. For a rear-loaded bass driver such as in a Lowther horn, the front compression chamber volume tends to vary from about 2.5 liters to 4 or more liters. Of course, a Lowther horn does not have a rear compression chamber (because of the radiation from the front of the driver).
A number of different formulas exist for compression chambers, and any one of them may not give the best size for your application. These formulas should be considered a starting point. One formula for a compression chamber volume:
<img src="attachments/dvbbs/2005-3/2005330211843581.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-3/2005330211843581.gif\');}" onmousewheel="return imgzoom(this);" alt="" />
VB is the back volume (volume of compression chamber next to horn throat, the front chamber in the diagram on the previous page)
Vas, Fs, and Qts are standard driver parameters
Fc is the lower cutoff frequency of the horn flare (I think)
Another formula comes from the paper by D.B. Keele, Jr., Low-Frequency Horn Design Using Thiele/Small Driver Parameters from the AES (see References) which is a simple form first derived by Klipsch in 1941:
<img src="attachments/dvbbs/2005-3/2005330211910394.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-3/2005330211910394.gif\');}" onmousewheel="return imgzoom(this);" alt="" />
VB is the back volume (volume of compression chamber)
ST is the throat area of the horn
FC is the horn cutoff frequency
c is the velocity of sound
Front and rear compression chambers are calculated differently in the Leach model.
David McBean's program (see below) can show the effects of different size front and rear chambers on the reactance and SPL generated by a horn.
158
超级贵宾 当前在线
打鬼子的
7483 点
2565 ¥
元老级 super 贵宾
发表于 2005-3-30 21:14 | 显示全部楼层
翻译一下
457 点
0 ¥
发表于 2005-3-30 21:11 | 显示全部楼层
Coupling the driver to the horn
Now, before we attempt to stuff the whole thing into a box, some attention needs to be directed to the volume of air (the cavity) between the driver's back side and the horn throat. We'd like to keep higher frequencies out of the horn. A good thumb rule is to let the horn play 3-4 octavesii or less. One should therefore dimension the cavity in such a way that it will act as a low-pass filter with an upper cut-off freq. 3-4 times the horn's fc. Also, the upper cut-off should be set at a frequency where the horn's length equals an odd multiply of the wavelength (because the horn is loaded from the back of the driver, 180 degrees out of phase). This is to avoid a canceling of the frequencies around the upper cut-off. Calculate the volume of the cavity (Vc) using this formula:
Vc = (C * Throat area) / (2 * PI * upper cut-off freq.) iii
In the 'BIG FUN' horn, this wasn't considered, because I wanted to leave plenty of space available for experimenting with different upper cut-off frequencies and damping of the cavity. However, I would recommend DIY constructors to take advantage of this math.
457 点
0 ¥
发表于 2005-3-30 21:05 | 显示全部楼层
嗯。今天才发现
Carfrae号角不是指数的。
Some people are using the Tractrix expansion in bass horns for Lowther drivers, for example the Big Fun horn and the commercial Carfrae.
113 点
2 ¥
发表于 2005-3-30 15:50 | 显示全部楼层
原来如此~~~
还是8路比较眼尖!!我继续潜水!!!
158
超级贵宾 当前在线
打鬼子的
7483 点
2565 ¥
元老级 super 贵宾
发表于 2005-3-30 15:49 | 显示全部楼层
什么新人!他是钳子家的老姑娘!
以下是引用Fanny在2005-3-30 15:46:00的发言:
大家应该鼓励的嘛!!HOHO!!!
[em11][em11][em11]
113 点
2 ¥
发表于 2005-3-30 15:46 | 显示全部楼层
1?怎么这样BS新人的说来?
大家应该鼓励的嘛!!HOHO!!!
157
8211 点
2614 ¥
 楼主| 发表于 2005-3-30 13:54 | 显示全部楼层
晕,狂晕
近来真多无聊之人[em10][em10][em10][em10]
这样的玩笑不好玩[em11][em11][em11]
158
超级贵宾 当前在线
打鬼子的
7483 点
2565 ¥
元老级 super 贵宾
发表于 2005-3-30 13:12 | 显示全部楼层
你恶作剧!小心卸了你的钳子!
以下是引用大钳子在2005-3-30 13:08:00的发言:
请各位大哥多多关照![em11]
[em11][em11]
53 点
0 ¥
发表于 2005-3-30 13:08 | 显示全部楼层
新人报到!
请各位大哥多多关照![em11]
158
超级贵宾 当前在线
打鬼子的
7483 点
2565 ¥
元老级 super 贵宾
发表于 2005-3-30 13:07 | 显示全部楼层
音源是垃圾!线材一般!
步步高DV-927K,有时也用先锋PD X707,秋叶原信号线,宝韵192喇叭线[em02][em02]
457 点
0 ¥
发表于 2005-3-30 13:01 | 显示全部楼层
是了!
忘记问8路兄您现在用啥音源的啊?咸菜呢?<img src="attachments/dvbbs/2005-3/200533013036110.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-3/200533013036110.gif\');}" onmousewheel="return imgzoom(this);" alt="" />
GMT+8, 2026-4-8 08:56 , Processed in 0.178586 second(s), 20 queries , Gzip On, Redis On.
