[分立后级] 我的PHASE 120装机报告
[复制链接] 查看: 49488|回复: 141
96
开博喽cookzeng.blog.sohu. ...
1812 点
331 ¥
论坛贵宾
 楼主| 发表于 2004-12-14 22:51 | 显示全部楼层
今天晚上回来开始搞散热器和机箱
今天傍晚在散热板转了32个4.2MM的孔,铜板上转了32个4.8的孔,还有几个2.2MM的孔,准备用丝攻攻孔,用3MM的螺丝固定MOS管,结果我的转头和两个3MM丝攻全报销了,孔还没转完,我崩溃了[em00][em00][em00],实在是太累了,DIY 真是一项系统工程啊,还得学金工!
      散热器没搞定MOS管不敢接,手又痒了,于是又开始摆弄起来了。把推动级的两个发射极电阻的连接处之间与输出端用导线连起来,通电看看波形也好啊。
      通电测输出端的电位有300MV左右,这种电流模电路结构的输出电位偏差是比其他的差分电流大的,所以都要用DC SERVO 来摆平直流电位,但是电路的性能还是不错的。于是接上了DC SERVO 板子,呵呵,就是下面那几幅
<img src="attachments/dvbbs/2004-12/20041214224437126.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/20041214224437126.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="attachments/dvbbs/2004-12/20041214224524163.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/20041214224524163.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="attachments/dvbbs/2004-12/20041214224620495.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/20041214224620495.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
     酷吧,用5个铜螺柱锁再大板上,立体双层结构,哈哈,爽呆了!
     接上DC SERVO后再测输出电位只有0.5MV了,我用的是TL071做炮灰的,DZ用的是OPA134PA,看DZ上的一篇文章说是测试了用不同的运放放在DC SERVO 上,功放的味道会跟着这个运放改变,它试了几种运放,OPA134的话整个功放就是OPA134的味道,换成OPA627的话,就是OPA627的味道,真是奇怪了,等做完以后一定要试试!
126 点
5 ¥
发表于 2004-12-14 22:00 | 显示全部楼层
佩服中
47
754 点
312 ¥
发表于 2004-12-14 20:51 | 显示全部楼层
顶一下,看不到了!
157
8211 点
2614 ¥
发表于 2004-12-14 00:44 | 显示全部楼层
不用上什么样的调压器了
电路很简单,测C8二端不大于1V就烧不了功放管的[em11][em11][em11]
158
超级贵宾 当前离线
打鬼子的
7480 点
2562 ¥
元老级 super 贵宾
发表于 2004-12-14 00:23 | 显示全部楼层
祝你马到成功!
[em06][em06][em06][em06]
96
1812 点
331 ¥
论坛贵宾
 楼主| 发表于 2004-12-13 23:44 | 显示全部楼层
多谢wb136兄的建议
以后经常左功放是得考虑买一个以保安全啊,不知道多少米一个啊?贵不?
1670 点
1278 ¥
发表于 2004-12-13 22:58 | 显示全部楼层
建议楼主在电源变压器前加一个调压器(试验时)
建议楼主在电源变压器前加一个调压器(试验时),可以防止冒烟之类的事情。
96
1812 点
331 ¥
论坛贵宾
 楼主| 发表于 2004-12-13 22:38 | 显示全部楼层
板子上装了两个白色的LED
上电的时候很漂亮,只是这东东JS要了我1元一个,肯定是被宰了![em00]
96
1812 点
331 ¥
论坛贵宾
 楼主| 发表于 2004-12-13 22:35 | 显示全部楼层
刚才按错了,接着来
我的PHASE 120装机报告
我的PHASE 120装机报告
我的PHASE 120装机报告
我的PHASE 120装机报告
我的PHASE 120装机报告
我的PHASE 120装机报告
     刚才一直在搞电源,累啊。先用两个了areoM16000U/50V的大水塘,因为没有合适的变压器,就用花了巨款(50大元)在电子市场买的250W大火牛,呵呵,一看就知道了,35V的绕组,线径只有0.8MM!没有双绕组,是中间抽头的。不过还好通电之后居然不响,很满意了,滤波出来有正负46V,正负电源相差也不大,只好先用它试试了,继续找好牛ING。。。
      散热器没搞,所以没有加MOS管,晚上怕电转吓到邻居被投诉!明天回来早点弄。
     通电测了一下各点的电压,基本正常。测了偏置的电压,调节偏置VR可以在0.65V-4.6V之间变化,明天接上MOS管的话就应该不会冒烟了吧。[em11]
      测了一下不接MOS管时整机的的电流,大概五六十个MA 左右,头一次搞分立元件的功放,到这里还算顺利[em11][em11][em11]
96
1812 点
331 ¥
论坛贵宾
 楼主| 发表于 2004-12-13 22:01 | 显示全部楼层
再上一下图,汇报一下
[em11][em11][em11]
542 点
156 ¥
发表于 2004-12-13 20:12 | 显示全部楼层
哇噻,板子粉漂亮呀!
广东广州
2325 点
540 ¥
发表于 2004-12-13 20:10 | 显示全部楼层
做得很漂亮
剩下来就是声音如何。
63V以上容量100UF以上,飞利浦轴线、rifa124和roe都有这规格。
红威马不如rifa420,体积大小刚好一样。
1059 点
168 ¥
发表于 2004-12-13 19:29 | 显示全部楼层
好东西是要顶。。。要求加精///
96
1812 点
331 ¥
论坛贵宾
 楼主| 发表于 2004-12-13 19:16 | 显示全部楼层
还有几幅
我的PHASE 120装机报告
我的PHASE 120装机报告
我的PHASE 120装机报告
我的PHASE 120装机报告
我的PHASE 120装机报告
我的PHASE 120装机报告
晚上再搞电源和散热器[em06]
96
1812 点
331 ¥
论坛贵宾
 楼主| 发表于 2004-12-13 19:08 | 显示全部楼层
把PHASE 120的主电路部分基本都焊完了
刚才用+-24V蓄电池供电试了一下,没有冒烟,这就放心了[em11][em11]
MOS管还没敢焊上,搞了个插座准备用螺丝拧。
接下来电源部分还没有搞,还有散热板了,力气活啊。慢慢来,先再上几张PHASE 120 主电路板的写真。跟大家汇报一下。[em11][em11][em11]<img src="attachments/dvbbs/2004-12/2004121318503084.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/2004121318503084.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="attachments/dvbbs/2004-12/20041213185112140.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/20041213185112140.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="attachments/dvbbs/2004-12/2004121318525422.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/2004121318525422.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
       本来想都用DALE RN60D军规电阻,可是国内都找不齐,最可气的是从温州升艺邮购的电阻,上面说是1/4W 0.30元一个,可是寄过来一看所谓的DALE 1/4W电阻,都是RN55C CMF55C这些,比1/4W的DALE RN60D小多了,应该是1/8W的,而它所谓的 0.60元一个的DALE 1W电阻,其实是1/4W的,真是个骗子!以后再也不会从升艺邮购了!
       推动级的管子用的是2SD669AC,2SB649AC 都是210编号的,这对管子倒还是比较好买到的,MJE340 350很难找到合适的。
       还有四个用于板子电源退偶的电容还没有找到合适的,耐压要63V以上容量100UF以上,这边买不到什么发烧电容,只有红宝石的,不想用,只好先空着,大家看看这里用什么电容比较好,还有哪里可以买到真货啊,(好像现在好多地方的电解都是假的)
93 点
16 ¥
发表于 2004-12-13 15:30 | 显示全部楼层
开声时感觉特"爽"
101 点
5 ¥
发表于 2004-12-13 09:33 | 显示全部楼层
cool老大扳子有我份?
更想你套件!
207 点
23 ¥
发表于 2004-12-12 21:13 | 显示全部楼层
我顶。。。。密切关注。。。。
套件什么时候出来?我想做平衡式的,就是要两套。。。
密切关注。。。。
广东广州
2325 点
540 ¥
发表于 2004-12-12 13:43 | 显示全部楼层
等看报告
47
754 点
312 ¥
发表于 2004-12-12 00:49 | 显示全部楼层
等待你的好消息!
我猜你今天一定很兴奋!
GMT+8, 2026-4-6 10:14 , Processed in 0.138913 second(s), 9 queries , Gzip On, Redis On.
