[心得经验] 有摩过CD机晶振的吗?
 关闭 [复制链接] 查看: 234086|回复: 492
157
8211 点
2614 ¥
发表于 2004-12-3 14:05 | 显示全部楼层
鸣呼
扑街邮局,我的还未见[em10][em10][em10]
399
超级版主 当前在线
16988 点
8778 ¥
 楼主| 发表于 2004-12-3 14:01 | 显示全部楼层
应该靓过你套件个只挂.
[em11]
157
8211 点
2614 ¥
发表于 2004-12-3 13:49 | 显示全部楼层
哈哈
到时候我也拆我的227esd上的TDA1541A试吓[em11]
399
超级版主 当前在线
16988 点
8778 ¥
 楼主| 发表于 2004-12-3 13:41 | 显示全部楼层
不用换.都给你.
[em11]<img src="attachments/dvbbs/2004-12/2004123134054934.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/2004123134054934.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />[em11]
157
8211 点
2614 ¥
发表于 2004-12-3 13:29 | 显示全部楼层
你给你的我
我拿WIMA跟你换[em05]
157
8211 点
2614 ¥
发表于 2004-12-3 13:27 | 显示全部楼层
[em11]
399
超级版主 当前在线
16988 点
8778 ¥
 楼主| 发表于 2004-12-3 13:26 | 显示全部楼层
你别胡说呀.WIMA怎么不行?
157
8211 点
2614 ¥
发表于 2004-12-3 13:20 | 显示全部楼层
HQ兄
你的0.1uF/250V好东东啊
我也认为坛上的WIMA不行[em11][em11][em11]
399
超级版主 当前在线
16988 点
8778 ¥
 楼主| 发表于 2004-12-3 13:00 | 显示全部楼层
雏形.
<img src="attachments/dvbbs/2004-12/2004123125957733.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/2004123125957733.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
399
超级版主 当前在线
16988 点
8778 ¥
 楼主| 发表于 2004-12-3 12:36 | 显示全部楼层
这两天忙于搞1541.没时间玩晶振了.
[em11]
376 点
92 ¥
发表于 2004-12-20 12:40 | 显示全部楼层
谢谢
我回去试试看,谢谢
1374 点
28 ¥
发表于 2004-12-18 23:07 | 显示全部楼层
是55脚
上面所说的是55脚
1374 点
28 ¥
发表于 2004-12-18 23:04 | 显示全部楼层
你看看55脚接地了吗?
以下是引用hclfy在2004-12-17 12:45:00的发言:
昨天给CXD2500BQ(DSP)第53脚接有源4脚16.9344M的晶振,并拆除了原机的2脚晶振和对地的2个电容,接线正确无误,可是CD不能工作,转盘也不转,盒仓也打不开,更换不成功,不知道何故,恳请不吝赐教。谢谢。
用16.9344M的晶振53脚要接地,用33.8688M晶振53脚接正电源。
179 点
2 ¥
发表于 2004-12-18 05:48 | 显示全部楼层
望贴兴叹!
实在没时间回贴!
Wima MKP10 声音有点硬.
鬼版, 你的问题实在没时间回了.
音乐虫子, 不太了解你的问题是什么也. 换 clock 和做 reclocking 是两回事.
前者主要是改善机子本身的性能, 后者是改善讯号输出品质. 原作者两件事一起做了.
1059 点
168 ¥
发表于 2004-12-17 21:58 | 显示全部楼层
把NEC光驱的33MHz换了。看有什么改进不,哈哈
光驱已经有了缓冲电路,很不错,这是光驱的原来时钟电路
<img src="attachments/dvbbs/2004-12/20041217215637267.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/20041217215637267.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="attachments/dvbbs/2004-12/200412172213282.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/200412172213282.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
光驱原始电路
下面是一些修改者的话:
{光驱本身的数字输出线路很简陋,增加的这部分线路是为了提高数字输出的质量,尽量减少JITTER。线路见图1,这其实就是反复在论坛里贴出过的RELOCK和DISX线路的结合,采用一组LM317单独供电。为了提供准确的基准时钟源,这里先用一只精密的TCXO钟振换掉原主板上的33.8688两脚晶体,然后用一只HD74AC74P将数字信号和时钟信号进行RELOCK,最后经 74VHCUO4构成的缓冲级输出,由于线路简单就没有做PCB,直接用洞洞板搭焊。数字信号直接从CXD2510的数字输出脚引入增加的线路板。主板的时钟电路是由板载的74HCU04将 33.8688二分频为16.9344提供给CXD2510作为主时钟,进行RELOCK的时钟信号就从CXD2510的 X-OUT脚输出。传输时钟信号和数字信号的接线要用高频屏蔽电缆}
疑问:(1)不是直接换掉原来的33M就可以了吗?为什么又要来然后用一只HD74AC74P将数字信号和时钟信号进行RELOCK,最后经 74VHCUO4构成的缓冲级输出??我应该如何做啊?直接换掉原来的33MHZ呢?还是要另外用分频电路接CXD2510的53脚?
疑问(2)这个应该如何换啊?接电阻端是输入? 电容接地端是时钟地?大家帮忙吧。哈哈。。谢谢
1059 点
168 ¥
发表于 2004-12-17 21:35 | 显示全部楼层
试试将光驱的33.868MHz换了。看有什么变化。哈哈。。
109
论坛版主
8012 点
1636 ¥
元老级 社区贡献 优秀设计
发表于 2004-12-17 12:58 | 显示全部楼层
。供参考
http://www.hifidiy.net/dispbbs.asp?boardID=2&ID=4435&star=2&skin=0
最好用示波器检查一下。
376 点
92 ¥
发表于 2004-12-17 12:45 | 显示全部楼层
CXD2500BQ(DSP)如何接有源4脚16.9344M的晶振?
426 点
13 ¥
发表于 2004-12-12 02:24 | 显示全部楼层
好贴
好贴,可惜无米之炊啊.我买不到晶振.
674 点
33 ¥
发表于 2004-12-22 22:50 | 显示全部楼层
不敢当
以下是引用HQ在2004-12-22 22:12:00的发言:
不过与其贴个贴个频率计的图片还不如贴点电路近照
GMT+8, 2026-5-19 23:55 , Processed in 0.146322 second(s), 8 queries , Gzip On, Redis On.
