[分立后级] 简洁的“JLH”甲类功放(MOSFET)
[复制链接] 查看: 67293|回复: 113
2912 点
975 ¥
 楼主| 发表于 2005-7-18 09:56 | 显示全部楼层
昨天做的试验版……
刀刻的电路版:
<img src="attachments/dvbbs/2005-7/200571895219665.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-7/200571895219665.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
全图:
<img src="attachments/dvbbs/2005-7/200571895355214.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-7/200571895355214.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
近照:
<img src="attachments/dvbbs/2005-7/20057189557434.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-7/20057189557434.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="attachments/dvbbs/2005-7/200571895530765.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-7/200571895530765.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
2912 点
975 ¥
 楼主| 发表于 2005-7-18 10:46 | 显示全部楼层
在我的样板中有些元件与原理图有些出入……
样板的实际元件及数值如下:
RP1 is 220K(先设到100K左右);
C4 is 22uF;
R2 is 120K;
C1 is 4.7uF("ERO" MKT cap.);
Q1 is 2SA970(hfe=287);
R5 is 5.1K欧;
C5 is 22pF;
V1 is 42V(DC);
MU-1 约 3V;
MU-2 约 19.5V(when Ucc is 42V);
MA-1 约100mA.
76
2276 点
1083 ¥
发表于 2005-7-18 11:50 | 显示全部楼层
效果
等待试音报告!
2912 点
975 ¥
 楼主| 发表于 2005-7-18 12:16 | 显示全部楼层
昨晚一点多钟……试了一下……会响……
LP本来睡着了……被我的AMP吵醒……被唠叨了一顿……呵呵!
今早一早就起来试音:
很好,很顺……没有上次的那款JLH-MOS(IRF540)那么难听……
和仿真的结果一样,由于C2(330UF)的缘故,所以低频不是很好,低频(低于100HZ)的信号衰减较大……
高音很好,很清晰……冷艳型……仿真时也知道:其高频很好(C5取22PF时,至少上到100KHZ才见衰减)……所以米勒电容C5我取22PF到47PF……不知道可不可以取消C5,我怕高频自激……
今晚再仔细试听,并看看调到甲类(推挽,静态电流约取1/2的最大输出电流)声音会不会好些……
[em02]
76
2276 点
1083 ¥
发表于 2005-7-18 14:15 | 显示全部楼层
改成正负电源供电
取消输出电容试试,看看效果如何?
2912 点
975 ¥
 楼主| 发表于 2005-7-18 15:35 | 显示全部楼层
不太好改!
以下是引用shaohua-zh在2005-7-18 14:15:00的发言:
改成正负电源供电
取消输出电容试试,看看效果如何?
我觉得是输入级的问题,输出电容并不是关键……
再加上输出中点并不是1/2UCC,而是上臂比下臂要高3V~4V,是不对称供电,所以不好搞……[em02]
76
2276 点
1083 ¥
发表于 2005-7-18 15:52 | 显示全部楼层
如何加强低音?
此电路中高音很好,就是低音差点,如何加强或提升?
2912 点
975 ¥
 楼主| 发表于 2005-7-18 17:08 | 显示全部楼层
对啊……我今晚回去再想想……
目前有两法针对该OTL电路:
(1)加大C2(330UF)到1000UF左右;
(2)加深负反馈;
还有就是改用双电源OCL,并改用差分前级……
我今晚回去仿真一下,明天给您答复吧……
76
2276 点
1083 ¥
发表于 2005-7-18 18:54 | 显示全部楼层
好的!
老兄真好干劲!
31
314 点
0 ¥
发表于 2005-7-18 19:35 | 显示全部楼层
不错!JLHOOD是好功放……
刚买了PASS A15的板子,准备玩玩了,最终还是想玩PASS A5
76
2276 点
1083 ¥
发表于 2005-7-18 20:38 | 显示全部楼层
pass系列:
就怕它发热量巨大,像个大电炉!
133
4912 点
2799 ¥
元老级
发表于 2005-7-18 21:12 | 显示全部楼层
名机不要改来改去
这种电路已经流行了很多年,能改的都改的差不多了,我看要改也得先装个原版做比较,不然JLH声音是什么样子都不知道就有班门弄斧之味道!
56
2305 点
607 ¥
发表于 2005-7-18 22:18 | 显示全部楼层
赞成楼上的。
搞得怎样都好,一定要有个参考对象。
128
887 点
215 ¥
发表于 2005-7-19 00:25 | 显示全部楼层
我觉得原电路
的确是很值得玩一下的。
2912 点
975 ¥
 楼主| 发表于 2005-7-19 11:01 | 显示全部楼层
哈哈……这么多大师来捧场——有褒有贬……
[em02]
昨晚听了一个多钟……我对它的中高频真是很满意……
唯独不能接受的是它的低频(100HZ以下的部分)……少了好多感染力……
SHAOHUA-ZH兄有说到加大输出电容会有些改善,确实是这样的(虽然不是关键,但还是要加大些好,如10000UF以上……),其实是负反馈网络没有把输出电容“包”在其中的缘故——所以我敢大胆的说:负反馈部分的思想落后了……
我昨晚仿真过:加大C2(330UF)到2200UF,C3(6800UF)加大一倍……低频是上去了一些……但还是不理想!
所以我想:不管是BJT版本还是MOS版本,它的前级及负反馈部分是一样的……所以说JLH1969原版的低音不会和MOS版本有本质区别!
我对差分电路没有好感……所以JLH-OCL我也不去弄了……
暂时还没有想出有效的方法对其低频欠缺的问题进行改善……看来还是不容易啊
[em06]
2912 点
975 ¥
 楼主| 发表于 2005-7-29 10:12 | 显示全部楼层
这么多天了,终于有了新进展!
我之前做的确实是少了很多低音(BASS),中高音很好……
这是很让人费解的问题,中低音不足,会让人觉得音乐很空洞……没有感动的氛围。
为了解决问题,我近段一直泡在外国DIYAUDIO上,相关链接:
http://www.diyaudio.com/forums/showthread.php?s=&postid=691825#post691825
试了很多种方案,都不可以得到满意的效果,昨夜用了很简单前级,解决了这低音不足的问题!
所以我说的就是:JLH1969的前级部分不是不好,是落后了,也许在当时音频窄的二十世纪六七十年代,这已可满足人们的听音需要了……,但现在不行了……
低音不好,JLH1969空有清亮的中高音,还是败给了ZEN功放,这是在DIYAUDIO上的PASS论坛上的DIYER说的:“我们只有听过人们赞美ZEN的声音好,可是几乎没有听到过有人赞美JLH1969……”!!??
我个人认为是JLH1969的低音不足是其落败的主因……
好了来看看更新的图纸吧(注意:电路未作测试,迟些我焊了实验后再向大家作报告):
<img src="attachments/dvbbs/2005-7/200572910103348.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-7/200572910103348.gif\');}" onmousewheel="return imgzoom(this);" alt="" />
这是该电路的输出曲线图:
<img src="attachments/dvbbs/2005-7/2005729101041597.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-7/2005729101041597.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
欢迎扔砖头……[em02]
1970 点
699 ¥
发表于 2005-7-29 18:28 | 显示全部楼层
路过!这么好玩,也提供点参考
看看有参考作用吗
http://www.diyzone.net/sections.php?op=viewarticle&artid=150
109
论坛版主
8012 点
1636 ¥
元老级 社区贡献 优秀设计
发表于 2005-7-29 23:03 | 显示全部楼层
JLH1969
以下是引用DarkHorse在2005-7-29 10:12:00的发言:
中高频好,低频不好,估计是电源或输出级做得不够好。。。。
JLH1969这个线路,老外有不少人大赞呀。。。。风头似乎还高于ZEN4[em08]
2912 点
975 ¥
 楼主| 发表于 2005-7-30 11:06 | 显示全部楼层
谢谢AKMY5和鬼版……
昨晚焊好了,试了一下音,高音是“哧噌哧噌……”鲜明的不得了……
我怕怕,怎么还是这么亮的高音啊……之后我就把RF(1.8K)换到9K左右……噫?低频出来了……高音合适了……怪事!
我又试着把RF换大一点,22K吧,哎,低音很肥了……
大家明白了吧,RF取值决定AMP与您的喇叭发出让您的耳朵觉得舒服的声音,在这里,RF应该在2.2K~10K之间选择吧……
同样地,C2(10UF)也类似这样的,但它是越小,低音越足……越大低音越弱……C2可以在2.2UF~10UF间选择……我今晚也试试换C2……哈哈!
其实看来可能是我的喇叭问题,或许如果您有好的音箱,JLH1969及之前的MOS版本也可能会发出您喜爱的低音吧……
所以还是先要有一对好箱子……不知道我搞了这么多是不是徒劳了……[em02]
2912 点
975 ¥
 楼主| 发表于 2005-8-2 09:59 | 显示全部楼层
这是我实验后认为可以接受的电路……
要输出满功率就要前级放大器(5~10倍放大就可以了)……
我用CD-PLAYER,输出1000MV(P-P),只可以获得7W(RMS)的功率……
它可以较好地重现低音……中高音也不赖……
出声真的还不错……有点高级音响的“味道”……
[em06]
<img src="attachments/dvbbs/2005-8/20058295916176.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/20058295916176.gif\');}" onmousewheel="return imgzoom(this);" alt="" />
GMT+8, 2026-4-6 10:05 , Processed in 0.135835 second(s), 7 queries , Gzip On, Redis On.
