[音箱资料] 分频电容大比拼
[复制链接] 查看: 144912|回复: 142
412 点
311 ¥
发表于 2015-3-7 13:37 | 显示全部楼层
江南长城 发表于 2015-3-6 23:34
从价格和声音表现来看,M-cap evo油浸用在低通是不错的,v-cap油浸的声音连贯性、信息量比m-cap evo 油 ...
那个Supreme电阻180一个啊,两个也要360。一个比一个EVO OIL 电容还贵啊。。。。
497
847 点
340 ¥
发表于 2017-8-7 11:22 | 显示全部楼层
学习
78
1141 点
928 ¥
发表于 2020-2-3 11:39 | 显示全部楼层
先收藏吧
2176 点
2154 ¥
发表于 2020-2-3 13:36 | 显示全部楼层
都是英文啊,要我翻译。。。,一个电容能翻了天?
2176 点
2154 ¥
what a bunch of apes !
608 点
321 ¥
发表于 2020-7-4 19:12 | 显示全部楼层
好贴。学习了。
3873 点
3773 ¥
发表于 2020-7-4 20:53 | 显示全部楼层
IMG_20200704_194157.jpg 高音三阶CLC的第一个C,我喜欢用蓝色的,有韵味。
7653 点
7551 ¥
发表于 2020-7-5 16:04 | 显示全部楼层
core2duo 发表于 2008-12-18 22:33
solen不如wima? mks4如何?
规格上MKS10较好但MKP10全面赢出!关键是真品!!!
103
1081 点
817 ¥
发表于 2022-2-4 14:43 来自手机端 | 显示全部楼层
还有什么电容,放分频器上合适?
408 点
341 ¥
发表于 2022-12-18 18:42 | 显示全部楼层
最常用的wima mkp-10的评分刚好漏了?
101
4169 点
3988 ¥
发表于 2022-12-18 23:49 | 显示全部楼层
nppc 发表于 2008-12-19 00:09
MKS4还不如MKT.
个人用过天蓝色的ERO MKP.感觉足够跟苏伦分庭抗礼.
确实是!
3090 点
1442 ¥
发表于 2022-12-19 11:00 | 显示全部楼层
WIMA MKP 10 100VDC - 10% tolerance
Technical specifications (according to manufacturer): "Pulse capacitor. The construction principle of the series WIMA MKP 10 consists of a non-metallized dielectric film and an carrier film metallized on both sides acting as electrode. Thanks to the metallization on both sides, the electrical conductivity is considerably improved and the contact surface between the electrodes and the schoopage layer is doubled. This results in better contact and allows for high current and pulse loading capability. The properties of metallized capacitors such as excellent self-healing and high volume capacitance remain unchanged."
Sound: With the WIMA MKP 10 you get a neutral, smooth and well balanced capacitor. For this price range the amount of transparency is quite reasonable and overall the MKP 10 is pleasant to listen to. Compared to the similar shaped and sized Mundorf RXF the presentation is more forward and a fraction less clear. But never the less it has good overall sound qualities. Don't forget to give it some time to burn-in. Fresh out of the box they sound restricted and dynamics are limited. After several weeks of use they should open-up.
Verdict: 8
谷歌翻译:
WIMA MKP 10 100VDC-10%公差
技术规格(根据制造商):“脉冲电容器。WIMAMKP 10系列的构造原理由非金属化的电介质膜和在两侧均金属化的用作电极的载体膜组成。由于在两侧均进行了金属化,因此导电性得到显着改善,电极与剥离层之间的接触面增加了一倍,从而实现了更好的接触,并具有高电流和脉冲负载能力,并保留了金属化电容器的性能,例如出色的自愈性和高容量电容不变。”
声音:使用WIMA MKP 10,您将获得一个中性、光滑且平衡良好的电容器。对于这个价格范围,透明度是相当合理的,并且MKP 10总体上令人愉悦。与类似形状和尺寸的Mundorf  RXF相比,呈现方式更加前向且清晰度较低。但总的来说,它具有良好的整体音质。别忘了给它一些时间进行老化。开箱即用,它们听起来很受限制,而动力却很有限。使用数周后,应将其打开。
判决:8
408 点
341 ¥
发表于 2023-1-1 22:35 | 显示全部楼层
111 点
109 ¥
发表于 2023-4-5 12:34 | 显示全部楼层
好文章,可以用google浏览器翻译来看,谢谢分享
120 点
116 ¥
发表于 2023-4-6 20:58 | 显示全部楼层
个人感觉 分频器的电容是成音最最最重要的一个环节
全西门子油浸就齐了
再补点战神 牛血啥的 齐活
197 点
173 ¥
发表于 2023-4-7 10:29 | 显示全部楼层
如三分频的电容,应分别考虑其特性。也就是说,高音用高频特性好的、、、
466 点
466 ¥
发表于 2023-4-8 05:58 | 显示全部楼层
47 点
45 ¥
发表于 2023-4-8 11:21 | 显示全部楼层
听感这东西是客观的,每个人能接受的频率频段的敏感度也是不一样的。所以,无论什么大牌,杂牌的发烧器件还是音箱系统都是萝卜白菜各有所爱。
2241 点
2175 ¥
发表于 2023-4-10 17:12 | 显示全部楼层
目前觉得比较好听的是蒙多福的油浸,其它都不出彩
68 点
62 ¥
发表于 2023-4-25 17:37 来自手机端 | 显示全部楼层
楼主:这文章是不错的,看得明只是小数人,本人文化水平有限,确实不明白,主要译解一下那些种类的电容好,划分一下几个档次和价格的高低,这样才知道怎样选择好适合自己使用白电容,只是提议一下。
GMT+8, 2026-5-9 16:21 , Processed in 0.149009 second(s), 8 queries , Gzip On, Redis On.
