51 点
0 ¥
发表于 2006-4-5 16:13 | 显示全部楼层
<>有一点疑惑,ETON12寸单元灵敏度为91DB,双单元并联则为94DB,而漂尔中高和ETON中低的灵敏度均为89DB,直接用分频器分频会带来5DB的声压差,而用衰减电阻减少低音单元灵敏度则大大增大功放负担,白白浪费功率,同时又会减小阻尼系数,盟主原厂好象是用专用电子分频有源功放推双低,用户只需搭配功放推中高与中低,由此解决单元灵敏度不相匹配的问题,不知一点兄是如何做的?</P>
<>还请一点兄解小弟之疑.</P>
土匪
727 点
249 ¥
 楼主| 发表于 2006-4-12 10:10 | 显示全部楼层
我的频响曲线,大家给看看
另开一贴,我正在做的四分频5单元音箱
另开一贴,我正在做的四分频5单元音箱
另开一贴,我正在做的四分频5单元音箱
另开一贴,我正在做的四分频5单元音箱
95DB
另开一贴,我正在做的四分频5单元音箱
另开一贴,我正在做的四分频5单元音箱
102DBTHD&N
佛主的邻居
321 点
17 ¥
发表于 2006-4-10 17:34 | 显示全部楼层
好贴,别沉了?!!!
149 点
63 ¥
发表于 2006-4-18 03:28 | 显示全部楼层
上海东讯音响扬声器终点站
呵呵,这些单元均为上海东讯音响提供! 扬声器终点站:http://www.hifi-efax.com/bbs/index.asp
149 点
63 ¥
发表于 2006-4-18 03:08 | 显示全部楼层
[B]以下是引用[I]一点[/I]在2005-10-26 12:25:00的发言:[/B]<br><img src="attachments/dvbbs/2005-10/20051026122148989.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-10/20051026122148989.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />我的高音单元
<img src="attachments/dvbbs/2005-10/20051026122219790.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-10/20051026122219790.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />我的中高音单元
<img src="attachments/dvbbs/2005-10/20051026122313932.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-10/20051026122313932.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />我的中音单元<img src="attachments/dvbbs/2005-10/20051026122345136.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-10/20051026122345136.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />我的低音单元两个<img src="attachments/dvbbs/2005-10/20051026122432861.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-10/20051026122432861.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />想做的箱子
粮票用光了.
93 点
0 ¥
发表于 2006-4-24 15:14 | 显示全部楼层
<>终于看完了,也不知道说什么,</P>
<>弓虽 丁页 !</P>
608 点
321 ¥
发表于 2006-4-22 13:00 | 显示全部楼层
土匪
727 点
249 ¥
 楼主| 发表于 2006-4-22 10:16 | 显示全部楼层
我是这样搞的.
[B]以下是引用[I]demain[/I]在2006-4-21 22:59:00的发言:[/B]<br><>有一点疑惑,ETON12寸单元灵敏度为91DB,双单元并联则为94DB,而漂尔中高和ETON中低的灵敏度均为89DB,直接用分频器分频会带来5DB的声压差,而用衰减电阻减少低音单元灵敏度则大大增大功放负担,白白浪费功率,同时又会减小阻尼系数,盟主原厂好象是用专用电子分频有源功放推双低,用户只需搭配功放推中高与中低,由此解决单元灵敏度不相匹配的问题,不知一点兄是如何做的?</P><>还请一点兄解小弟之疑.</P><>同问</P>
我用的是两个ETON11寸,老兄只考虑了单元本身的灵敏度,在实际中,你的电感的用料及做法(如空心和磁心、普通铜和扁铜的内阻都是不同的)以及电容都影响整个喇叭的灵敏度,在实际中喇叭是否好推大家都知道还有一最重要的问题,就是低音的导向孔.盟主原厂的低音箱体是密闭箱,所以非常吃功率,用电子分频有源功放推双低,在我前面的那个荷兰朋友就是用百事通电子分频的.用一对KERLL 100去推的低音.而我当时是怕我的公房力量不足以推动密闭低音箱,所以我在低音箱体使用了两个9#的后导向孔,中高音和中低音是密闭的箱体,去协调他们的灵敏度,现在实践证明是完全正确的,五个单元的声音一致性使我感到很满意.在听《春之祭》的动作一致性是普通喇叭根本无法相比的,伦敦爱乐的肖斯塔可威奇的第五交响区第二乐章现场我是去听过的,同伦敦爱乐出的Decca版肖斯塔可威奇的第五交响区第二乐章也同样是我调声的CD之一,在喇叭中的还原比现场稍微慢点,大鼓的瞬间凌厉的动态反应基本可以达到,小提琴的那电光一瞬也没有问题的可以表现(这点在单那25周年和至尊上就无法表现。所以在灵敏度的一致性方面经过我以上的调整可以说已经解决。当然影响灵敏度的还有其它因素,如箱体的结构,箱内线的选择等。
不知道这样解释可以吗?
91 点
13 ¥
发表于 2006-4-21 22:59 | 显示全部楼层
<>还请一点兄解小弟之疑.</P>
<>同问</P>
217 点
0 ¥
发表于 2006-4-28 15:03 | 显示全部楼层
还忘了问一个重要的问题!!
盟主所用的单元是否是特别定制的!!如果是,和我门能买到的单元差别是否很大?最后说一句!!楼主的箱子是我以后的目标!!不过只想用一只超底!!!底音用AT的是不是柔和一点!??
217 点
0 ¥
发表于 2006-4-28 14:56 | 显示全部楼层
谢谢DX的回复!很详细!
想买T330多时,但看了一点的帖子后,对陶瓷的感兴趣了!!一点兄可否推荐一套!!想做书架!!用票尔的高低音!先谢过!
认真的发烧友
3662 点
2874 ¥
发表于 2006-4-28 12:01 | 显示全部楼层
<><FONT size=2>近日网上看到漂尔的性能及参考价: (Retail USD = 美元报价)</FONT></P>
<>高音头:    灵敏度                直流电阻          面积           美元报价</P>
<>Tweeters:    Eff  Qm  Qes  Qts  Re  Fres  Vas  Sd   Le     Retail USD <BR>C&sup2;12-4                                 3.2            6.0               179.00 <BR>C&sup2;12-6      89.5                    6.0 700        6.0  0.04        179.00 <BR>C&sup2;23-4                                  3.5            8.5              213.00 <BR>C&sup2;23-6      89.5                    6.1 350        8.5 0.04         213.00 <BR>                        <BR>中音:</P>
<>Midranges:   Eff   Qm   Qes  Qts  Re  Fres  Vas  Sd    Le   Retail USD <BR>C&sup2;44-4                                    3.0            24.0           220.00 <BR>C&sup2;44-8      88.5 1.19  2.2  0.77       8.2  390  0.11 24.0  0.02    220.00 <BR>C&sup2;79-4                                 3.9            75.5          276.00 <BR>C&sup2;79-6      88.5 0.96 1.07 0.51        5.8   96  3.1  75.5  0.12    276.00 <BR>                        <BR>5 " 低音:   Eff   Qm  Qes  Qts  Re  Fres  Vas  Sd    Le  Retail USD <BR>C&sup2;88-4           1.17 0.52 0.36 3.9  36   17.9 80.1              265.00 <BR>C&sup2;88-6    86.0   1.04 0.54 0.35 5.9  36   20   80.1  0.16        265.00 <BR>C&sup2;88-12          1.08 0.69 0.42 11.7 38   17.6  80.1             265.00 <BR>C&sup2;89-T6   89.2   3.29 0.23 0.215 5.9 33.6 23.5  83.3 0.40        288.50 <BR>C&sup2;89-T13                              12.9           83.3  0.66        288.50 <BR> </P>
<>diamond drivers                       <BR>钻石高音:    Eff Qm Qes Qts  Re  Fres Vas  Sd    Le     欧元报价/含税?<BR>&raquo; D&sup2;20-6     89.5             6.0 900      3.15  0.04       1848.1/2199.3<BR>&raquo; D&sup2;30-6     90.0             6.0 440      7.0   0.04       3108.4/3699 </P>[em01][em01][em01]
土匪
727 点
249 ¥
 楼主| 发表于 2006-4-28 08:13 | 显示全部楼层
我知道的
<DIV class=quote><B>以下是引用<I>SION</I>在2006-4-27 16:28:00的发言:</B><BR>想请问一点兄票尔的陶瓷高音有几种啊?</DIV>
<>有三种:  C2-22(C平方22,以下同)高音上限到30000
<>              C2-23高音上限到35000  我用的这款
<>              C2-24高音上限到40000
217 点
0 ¥
发表于 2006-4-27 16:28 | 显示全部楼层
顶上!
想请问一点兄票尔的陶瓷高音有几种啊?
438 点
37 ¥
发表于 2006-5-3 01:34 | 显示全部楼层
<><IMG src="http://www.diyaudio.com/forums/images/smilies/bigeyes.gif" border=0><IMG src="http://www.diyaudio.com/forums/images/smilies/bigeyes.gif" border=0><IMG src="http://www.diyaudio.com/forums/images/smilies/bigeyes.gif" border=0><IMG src="http://www.diyaudio.com/forums/images/smilies/bigeyes.gif" border=0><IMG src="http://www.diyaudio.com/forums/images/smilies/bigeyes.gif" border=0></P>
<><FONT color=#f70909 size=4>一种精神,值得学习!!!!</FONT></P>
55 点
0 ¥
发表于 2006-5-2 21:54 | 显示全部楼层
我顶你一个..,..虽然是菜鸟但越看越想看成品
217 点
0 ¥
发表于 2006-4-30 13:39 | 显示全部楼层
多谢一点兄!
81
1403 点
832 ¥
发表于 2006-4-30 13:21 | 显示全部楼层
<>问下,3分频做中音是C79好还是C89好点啊?</P>
土匪
727 点
249 ¥
 楼主| 发表于 2006-4-30 09:16 | 显示全部楼层
哦!
<DIV class=quote><B>以下是引用<I>SION</I>在2006-4-28 15:03:00的发言:</B><br>盟主所用的单元是否是特别定制的!!如果是,和我门能买到的单元差别是否很大?最后说一句!!楼主的箱子是我以后的目标!!不过只想用一只超底!!!底音用AT的是不是柔和一点!??</DIV>
<>因为所有的钻石高音和超高都是定制.没有成品.[漂尔的陶瓷都是配对的,每一对的指标曲线都可以说是基本完全重合.以前以为ETON的9寸是定制的,实际也是有成品的,一般很少人用,因为它的尺寸的原因.所以漂尔因为生产厂在单元指标上没有什么问题,划分的也较细,高音从200KHZ一直到30KHZ都有生产,所以不需要特别定制,ETON有定制的但主要在小尺寸单元上为了兼顾各个频段.又不想增加太大的成本.玩笑的话就是想:两分频做出或接近三分频的效果.<br>
<>这个话题也一下说不清楚,<br>
<>但我的DIY观点是:做自己喜欢的东西,你就是全部都一样,你调出的声音也不是厂家的声音,因为:<br>
<>1、厂家是在无响室调的,你基本没有这个条件,但厂家在无响室调的声音并不适合你家里---谁家也不是无响室。<br>
<>2、调音师喜欢的声音不一定是你喜欢的声音<br>
<>3、绝对平衡的声音不是音乐要表达的东西----天天听平均律有什么意思<br>
<>4、找自己喜欢的声音是DIY的本意之所在,否则还不如买点古玩玩玩还保值那。<br>
<>5、仿制箱体的外观是因为我的美学设计水平不够,还是感觉人家的箱体样子好看。另外大箱子的高中低音单元的分布和之间的角度不好算,偷懒找现成的!呵呵</P>
土匪
727 点
249 ¥
 楼主| 发表于 2006-4-30 08:49 | 显示全部楼层
谢谢OKK老兄的详细解释
<DIV class=quote><B>以下是引用<I>SION</I>在2006-4-28 14:56:00的发言:</B><BR>想买T330多时,但看了一点的帖子后,对陶瓷的感兴趣了!!一点兄可否推荐一套!!想做书架!!用票尔的高低音!先谢过!</DIV>
<>建议用C&sup2;24做高音,C&sup2;89做低音,这样在以后升级你的单元也完全符合大箱子的要求,只需要加一12寸的AT或ETON就是一比较完美的组合.</P>
<>AT的单元ETON的松弛很多,风格不同,12寸的价格相当.</P>
<>美国和国内陶瓷全系列都的比OKK的寻价高,钻石没有OKK那个高.</P>
[em03]
GMT+8, 2026-5-26 16:09 , Processed in 0.135969 second(s), 20 queries , Gzip On, Redis On.
