[分立后级] [推荐]DX AMP 装机报道,Yeah!!!
  [复制链接] 查看: 300097|回复: 441
96
3705 点
2485 ¥
发表于 2007-12-29 03:21 | 显示全部楼层
看电路似平淡无奇,不知有何内里乾坤?
印象中较简单的不带恒流源电路往往容易获得柔顺的中频,但是高频要暗淡一点.
上个20K方波的图瞧瞧.
分立件功放玩的比较菜,还望指点啊.
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2007-12-29 08:14 | 显示全部楼层
原帖由 laurel 于 2007-12-29 03:21 发表
看电路似平淡无奇,不知有何内里乾坤?
上个20K方波的图瞧瞧.
分立件功放玩的比较菜,还望指点啊.
L兄,三点钟还不睡!!!
有条件的话请一定要试一下呵呵.
20K的波形很好三楼有帖出来的(实际是19K多一点,20K跟它一样的),
但正如你所说,高频在我弄过的机机里的确不是最靓的.
人生就像电梯
761 点
870 ¥
发表于 2007-12-29 08:42 | 显示全部楼层
看电路似平淡无奇,不知有何内里乾坤?
上个20K方波的图瞧瞧.
分立件功放玩的比较菜,还望指点啊.
  看起来的确是没什么特别的地方!!!!不知道lz有和高见!!!
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2007-12-29 08:45 | 显示全部楼层
原帖由 millwood 于 2007-12-28 19:09 发表
i wouldnt build it: the p3 or aksa are simpler and better amps in my view. even the ska.
having said that, you may try the following:
a) use a resister to replace r6/r7/vr1/z1/c8: it is way to complicated as is.
b) or use a constant current source for better psrr.
c) make r9=r5. or take out r9.
d) r4=r8=11 to 47. they are too large at 100ohm.
e) take out c13. the beauty of a bootstrap is that it becomes less capacitive and more resistive (thus less gain) at high freq. c13 killed that. taking out c13 allows better stability thus lower c14.
f) c14 too big to be a hi-fi amp. try to reduce it to < 47p. see the slew rate for your amp.
g) use a small resistor at the emitter of q3. 11-22ohm will do. it prevents q3 from going into hard saturation.
h) r15/18 in the wrong place. move them to the left.
i) use a small capacitor on q8. 0.1u will do.
j) add a small resistor in serial with vbe. see nap140.
k) r20/r21 are very good. aksa / john curl style.
l) i would add two 0r22 RE resistors to q6/q7.
m) use a choke on output. wound 10 turns on a 10ohm 5w resistor.
n) r12=r13.
m兄,你好。
a,用稳压管是为了方便适应更宽的供电电压
b,电流源我文中提到过,会使声音发硬,个人感觉加理解,不一定对,这一点值得大家讨论。
c,两个值不等可能可以平衡一下Q3的偏置,呵呵
d,100ohm这个电阻我倒没有试过变小,这个电阻是调节稳定性和开环增益的,有机会倒是要试一下你所说的小值情况呵呵。
e,C13这个问题,我改天再细听一下差别。暂时留下它的原因是我做电路的时候也习惯大电容并小电容,呵呵。你所说的我有机会验证一下。你的这个解释ms有些道理 ,但好像不大影响C14
f,C14小了会自激,这个是经我实测的,而且47p与100p也无所谓决定hifi与否,我记得在symasym里补偿相位的电容有用到330pF
g,射级电阻会影响音色,我在文中有详细说明,呵呵
h,这两个电阻没有问题的,呵呵。
i,这一点的确是好建议,回头就加上。有助于稳定电路!
j,这个电阻很关键?主要是我电路不太好加了
k,恩。这两个电阻现在许多功放都在用!
l,同g
m,恩。choke电路是应该加上的,不过建议直接加到喇叭后面。
n,R12与C12一起自举用,R13主要用作调节偏置,常见的电路中相等不一定意味着必须相等的
多谢好建议!呵呵
另外,强烈建议m兄试验一下这个电路,真的是简单好声!!!
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2007-12-29 08:48 | 显示全部楼层
原帖由 kuangren 于 2007-12-29 08:42 发表
呵呵。每个电路都有特别的地方,只是分离功放的结构都看起来一样的。所以咋一看都觉得没什么特别。
所以设计电路的话,不一定是设计大概结构,关键是每一个小部分要怎么搭配,是元件取值对音色的影响。
详细我在文中一楼都有提到,欢迎补充,呵呵。
283
3121 点
2513 ¥
发表于 2007-12-29 09:12 | 显示全部楼层
对照“电子线路”课本里的OCL功放电路实例,看了下。大局上是相同的 但是还是有其特别的地方,一个是浮地,一个就是输出级只有R19一个电阻,这样负反馈也有些变化了。至于说自举电路课本上也是有的
699 点
673 ¥
发表于 2007-12-29 20:33 | 显示全部楼层
本机是基于传统的自举电路-闻名于好声的一款经典线路,特点有三:1,非常好声;2,器件易找,容易制作;3,花费不大。同时拥有这三个特点,没道理不试试,呵呵。
如果楼主,出套件,就能帮助我这样的菜鸟一个学习的机会了,
我只玩过IC类的 LM4766
也想玩下这种了
很多爱好音乐的烧友,都在小城里,买零件不是很方便,如果楼主,能出套件
一是奉献,二也可以赚包烟钱,
203 点
208 ¥
发表于 2007-12-29 21:55 | 显示全部楼层
期待中
2857 点
2785 ¥
发表于 2007-12-30 01:14 | 显示全部楼层
someone sent this to me for my comments.
it is supposedly the new and improved version of the dx amp.
it has apparently incorporated quite a few of my suggestions but more needs to be done.
the use of two super linear paris in the differential input stage is quite good, btw.
still, I would build the nap, aksa or p3a before I try the dx amp.
2754 点
2610 ¥
发表于 2007-12-31 01:31 | 显示全部楼层
楼主继续下文啊
1389 点
1044 ¥
发表于 2007-12-31 09:13 | 显示全部楼层
把隔直电容3.3威马换成无极电解,低频应该会有改善
57 点
57 ¥
发表于 2007-12-31 10:04 | 显示全部楼层
回复 #1 ary 的帖子
DX AMP试装结果!ary先生请看看
花了一天一夜,用洞洞板装了一个,有问题请教朋友:总的来说声音是出来了,但低音生硬,没弹性,高频在声音小时也失真,不知道有什么方法可以解决?中点电压可以调的很好1-20mV,末级管B极电压调到0.47V左右,高就失真,哎,不知道问题出在哪里,苦于家里没示波器,请ary先生指教,R14(24)电路图上为2K,PCB板上为330欧姆,我按了个390欧姆,R11我没39K,用了个36K,R9没820欧姆,换了个680欧姆,TIP41,42,我用2073和940,Q3为BD139,手头没用了个D669,其他都一样了,2073和940点点温度都没有,是不是工作状态没调好?其他等有发现再说.
1068 点
594 ¥
发表于 2008-1-1 22:48 | 显示全部楼层
今天终于装好了,基本就是原图的参数,把自举电容加大到100UF(手上没有47UF的 )。牛只有150W。想不到这么简单的电路声音还真不错,声音很均衡,和手上的论坛140对比了一下,除了高频差了一点点,不论是低音还是中音,都相当的好。。现在遇到的问题只有一个,就是末级的静态电流不好调。。。。
1068 点
594 ¥
发表于 2008-1-1 22:50 | 显示全部楼层
通过仿真,发现把R5加大到1K5,整机的失真度更小。。。下来实际试试。。
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2008-1-2 14:38 | 显示全部楼层
原帖由 l-k 于 2007-12-31 09:13 发表
L 兄, 无级电解固然好,不过毕竟是电解,做耦合来讲还是聚脂效果好的.
无级电解的优势在于其容值可以做到很大.
呵呵
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2008-1-2 14:44 | 显示全部楼层
原帖由 山耗子 于 2008-1-1 22:48 发表
今天终于装好了,基本就是原图的参数,把自举电容加大到100UF(手上没有47UF的 )。牛只有150W。想不到这么简单的电路声音还真不错,声音很均衡,和手上的论坛140对比了一下,除了高频差了一点点,不论是低 ...
山兄,恭喜出声,呵呵.
静态的确是这个电路最大的特色之一!!! 建议刚开始可以在保持好的散热效果的情况下,将BD140的VCE调到2.35V,可以一试
再次恭喜
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2008-1-2 14:47 | 显示全部楼层
原帖由 hwl2007 于 2007-12-31 10:04 发表
DX AMP试装结果!ary先生请看看
花了一天一夜,用洞洞板装了一个,有问题请教朋友:总的来说声音是出来了,但低音生硬,没弹性,高频在声音小时也失真,不知道有什么方法可以解决?中点电压可以调的很好1- ...
hwl兄,
你的电路的我怀疑有自激
81
2460 点
2058 ¥
发表于 2008-1-2 15:17 | 显示全部楼层
电路结构有点象<Nelson Pass的Harmon Kardon C12>哈曼卡顿C12
呵呵,这个电路的声音应该是极其细腻的.有一种久听不厌的感觉.
436 点
177 ¥
发表于 2008-1-2 15:34 | 显示全部楼层
是不是准备出套件啊?
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2008-1-2 20:13 | 显示全部楼层
DX AMP试装结果!ary先生请看看
换管子关系倒不是很大,不至于失真得这么明显的.
"Q3为BD139,手头没用了个D669"
Q8的BD140呢?
GMT+8, 2026-5-15 09:13 , Processed in 1.215163 second(s), 8 queries , Gzip On, Redis On.
