[分立后级] [推荐]DX AMP 装机报道,Yeah!!!
  [复制链接] 查看: 300096|回复: 441
203
特级厨师~!
6419 点
4433 ¥
发表于 2007-12-28 17:18 | 显示全部楼层
每次看这种分立的功放都让我心潮澎湃啊。
另外问一下:管子是否需要配对?末级射级电阻加与不加有什么大的影响?
240ma的声音如何?
我有点兴趣想搞一个做做了:)
140
古典音乐爱好者
4727 点
4250 ¥
论坛贵宾
发表于 2007-12-28 18:11 | 显示全部楼层
不错!
别人花钱,我DIY
3841 点
3553 ¥
发表于 2007-12-28 18:29 | 显示全部楼层
老兄是否考虑提供材料~~~\好想试试~~~
4715 点
4730 ¥
发表于 2007-12-28 18:37 | 显示全部楼层
等上MJL21193/4大管的报告
2857 点
2785 ¥
发表于 2007-12-28 19:09 | 显示全部楼层
i wouldnt build it: the p3 or aksa are simpler and better amps in my view. even the ska.
having said that, you may try the following:
a) use a resister to replace r6/r7/vr1/z1/c8: it is way to complicated as is.
b) or use a constant current source for better psrr.
c) make r9=r5. or take out r9.
d) r4=r8=11 to 47. they are too large at 100ohm.
e) take out c13. the beauty of a bootstrap is that it becomes less capacitive and more resistive (thus less gain) at high freq. c13 killed that. taking out c13 allows better stability thus lower c14.
f) c14 too big to be a hi-fi amp. try to reduce it to < 47p. see the slew rate for your amp.
g) use a small resistor at the emitter of q3. 11-22ohm will do. it prevents q3 from going into hard saturation.
h) r15/18 in the wrong place. move them to the left.
i) use a small capacitor on q8. 0.1u will do.
j) add a small resistor in serial with vbe. see nap140.
k) r20/r21 are very good. aksa / john curl style.
l) i would add two 0r22 RE resistors to q6/q7.
m) use a choke on output. wound 10 turns on a 10ohm 5w resistor.
n) r12=r13.
hopy it helps.
157
8211 点
2614 ¥
发表于 2007-12-28 19:19 | 显示全部楼层
的确把温补管贴在大管上是最有效的方法
个人觉得用C5200的话就要上200mA以上的电流,否则感觉高频很不自然
1191 点
929 ¥
社区贡献 新人进步
发表于 2007-12-28 19:28 | 显示全部楼层
以前某个帖子里看到过,三肯的管子需要上大的静态电流,东芝的管子电流大了低频太软,现在看见“文招”兄又提出5200需要上200ma的电流高频才好,搞不懂了,这是个人经验还是通过分析官方的pdf给出的曲线得到的呢?请教!
另外,每次看“millwood "兄的帖子都会很有收获,非常感谢!不过如果按照“millwood”兄的建议改了可能就不叫dx amp了哦。
98
I love DIY!
2240 点
1968 ¥
发表于 2007-12-28 19:29 | 显示全部楼层
原帖由 millwood 于 2007-12-28 19:09 发表
a) use a resister to replace r6/r7/vr1/z1/c8: it is way ...
高手啊!
部分观点我不懂,或者是值得商榷,但是许多观点很是认可,至少在名机线路看到是那么做的。
149
2257 点
1848 ¥
DIY大赛获奖
发表于 2007-12-28 19:30 | 显示全部楼层
ary的文章每次都是大作
125
2379 点
1155 ¥
这个玩意如果用45V供电行吗
1327 点
1115 ¥
发表于 2007-12-28 19:41 | 显示全部楼层
怎么我看amp的电路基本原理都是和nap的相同,就是电流管用上了互补和差分的恒流这些不同。
这也好,不用老是挑npn的大管了
210
Amp秀才
4442 点
2272 ¥
元老级 优秀设计
 楼主| 发表于 2007-12-28 19:41 | 显示全部楼层
原帖由 沙迦 于 2007-12-28 17:18 发表
每次看这种分立的功放都让我心潮澎湃啊。
240ma的声音如何?
我有点兴趣想搞一个做做了:)
输入级配对一下就行了.
射级电阻的增加有助于稳定电路,但会影响音色。
240mA建议你有把握再试,呵呵。其实调到120mA时,随着机器温度的升高,静态电流也会稍稍提升点,大概能到150mA
禁止访问 当前离线
4380 点
2995 ¥
发表于 2007-12-28 20:38 | 显示全部楼层
开一下板,提供一下套件.
业余HIFI
188 点
125 ¥
发表于 2007-12-28 21:02 | 显示全部楼层
严重关注
116 点
116 ¥
发表于 2007-12-28 21:06 | 显示全部楼层
曾经做过类似的电路,不过我Q3负载用的是恒流源,未知恒流源的听感和电阻有多大差别
1581 点
854 ¥
发表于 2007-12-28 21:11 | 显示全部楼层
期待
论坛总版主
1180 点
1143 ¥
发表于 2007-12-28 21:21 | 显示全部楼层
太好了,喜欢电路简单的功放,讲解的很好,值得一试。
1167 点
1120 ¥
发表于 2007-12-28 21:35 | 显示全部楼层
我越简单越喜欢.请楼主给一份PCB文件,我想自己制作一块!
如能得到LZ的帮助将非常的感谢!
请发JD_WPK@163.COM
203
特级厨师~!
6419 点
4433 ¥
发表于 2007-12-28 21:51 | 显示全部楼层
原帖由 ary 于 2007-12-28 19:41 发表
输入级配对一下就行了.
ok,谢谢ary兄,元旦备件去:)
359 点
352 ¥
发表于 2007-12-28 22:49 | 显示全部楼层
不错,简洁就是硬道理
GMT+8, 2026-5-15 09:13 , Processed in 1.033182 second(s), 7 queries , Gzip On, Redis On.
