[全频音箱] 全频同好会!
  [复制链接] 查看: 78116|回复: 317
1584 点
1568 ¥
发表于 2012-1-12 23:20 | 显示全部楼层
看来 T/T 兄要说说古董,摩登全频喇叭,两族声音的差异。呵呵~
1366 点
1360 ¥
 楼主| 发表于 2012-1-12 23:23 | 显示全部楼层
33x 发表于 2012-1-12 23:20
古董纯,摩登扩展!
1584 点
1568 ¥
发表于 2012-1-12 23:32 | 显示全部楼层
那个算是真的(绝对的)全频呢? 呵呵~
摩登扩展的像是分频,像吗?
1366 点
1360 ¥
 楼主| 发表于 2012-1-12 23:34 | 显示全部楼层
那个算是真的(绝对的)全频呢? 呵呵~
摩登扩展的像是分频,像吗?
33x 发表于 2012-1-12 23:32
The Audio Nirvana 'Super 15 Coax' ($498/pr) has a frequency response from 26 hz to 25,000 hz. You can expect at least 99 db efficiency in any of our cabinets. It handles 70 watts continuous RMS (normal listening level will be about 1/10 watt). Impedance is 8 ohms. Voice coil is 2.0 inches (50 mm) for the woofer and 1.5 inches (38 mm) for the tweeter. Magnet weight is 4.3 lbs (woofer) and 4 oz (tweeter). Total weight is 19 lbs. The woofer cone is made of paper. The surround is accordion style and made of treated cloth. The frame is cast aluminum. There are separate terminals for the woofer and the tweeter so the speakers can be biwired, if desired. This speaker is more properly called a 'triaxial' because it has a whizzer cone for midrange information. The best classic coaxial drivers were also triaxials.
1366 点
1360 ¥
 楼主| 发表于 2012-1-12 23:35 | 显示全部楼层
The Audio Nirvana 'Super 10 ALNICO' ($699/pr) has a frequency response from 35 hz to almost 20,000 hz. You can expect at least 96 db efficiency in any of our cabinets. It handles 30 watts continuous RMS (normal listening level will be about 1/10 watt). Impedance is 8 ohms. Voicecoil is 1.4 inches (35.5mm). Magnet weight is 2.4 lbs. Total weight is 13 lbs. The cone is made of paper. The surround is accordion style and made of treated cloth. The phase plug is copper anodized, machined solid aluminum. The Alnico magnet is made of aluminum, nickel, and cobalt and is stronger than normal ferrite/ceramic magnets. Our alnico magnet models are the smoothest Audio Nirvana models and make the most bass.
1366 点
1360 ¥
 楼主| 发表于 2012-1-12 23:36 | 显示全部楼层
像吗?
1584 点
1568 ¥
发表于 2012-1-12 23:40 | 显示全部楼层
One is coaxial , one is extended range; but BOTH in paper AND in cones, NO FUN~
1366 点
1360 ¥
 楼主| 发表于 2012-1-12 23:44 | 显示全部楼层
普通的这个亦可以吧!
The Audio Nirvana 'Super 10 Cast Frame' ($228/pr) has a frequency response from 34 hz to almost 20,000 hz. You can expect at least 99 db efficiency in any of our cabinets. It handles 30 watts continuous RMS (normal listening level will be about 1/10 watt). Impedance is 8 ohms. Voice coil is 1.4 inches (35.5mm). Magnet weight is 3.2 lbs. Total weight is 9 lbs. The cone is made of paper. The surround is accordion style and made of treated cloth. The phase plug is copper anodized, machined solid aluminum
发烧.土匪..
1075 点
1114 ¥
发表于 2012-1-12 23:45 | 显示全部楼层
喜欢全频。
1366 点
1360 ¥
 楼主| 发表于 2012-1-12 23:46 | 显示全部楼层
33x 发表于 2012-1-12 23:40
普通的这个亦可以吧!
1366 点
1360 ¥
 楼主| 发表于 2012-1-12 23:50 | 显示全部楼层
喜欢全频。
406715438 发表于 2012-1-12 23:45
  兄台在玩全频吗,给点意见!
1584 点
1568 ¥
普通的这个亦可以吧!
The Audio Nirvana 'Super 10 Cast Frame' ($228/pr) has a frequency response ...
TerenceT 发表于 2012-1-12 23:46
摩登全频? 国内许多的。呵呵~
发烧.土匪..
1075 点
1114 ¥
发表于 2012-1-12 23:53 | 显示全部楼层
回复 131# TerenceT
    目前 只是有优雅喇叭..箱子DIY....声音.自己觉得好 才是硬道理 ..谢谢 兄弟..
1366 点
1360 ¥
 楼主| 发表于 2012-1-12 23:55 | 显示全部楼层
回复  TerenceT
    目前 只是有优雅喇叭..箱子DIY....声音.自己觉得好 才是硬道理 ..谢谢 兄弟..:ha ...
406715438 发表于 2012-1-12 23:53
    优雅喇叭评价很好,有机听听!
1366 点
1360 ¥
 楼主| 发表于 2012-1-13 00:02 | 显示全部楼层
摩登全频? 国内许多的。呵呵~
33x 发表于 2012-1-12 23:50
  国内的已玩了几款,都不差,现要冲到国外了!
老菜鸟
519 点
518 ¥
发表于 2012-1-13 20:50 | 显示全部楼层
TerenceT 发表于 2012-1-13 00:02
对呀!把眼界放宽一点,你会有意想不到的收获!
100
2616 点
2404 ¥
发表于 2012-1-13 22:17 | 显示全部楼层
今天试了下8寸的,感觉没6.5的爽啊 是不是在外面,太空旷的缘故?,因为太忙,明天把6.5的那对,也放出去试试。
185
1245 点
1054 ¥
发表于 2012-1-14 07:15 | 显示全部楼层
动不动的搞一堆英文,你以为玩全频的都和你一样英文那么好啊啊啊.翻译一下吧
1366 点
1360 ¥
 楼主| 发表于 2012-1-14 23:42 | 显示全部楼层
lzx 发表于 2012-1-13 20:50
呵呵,但很多国外品牌现在已是Made in China了!
1366 点
1360 ¥
 楼主| 发表于 2012-1-14 23:44 | 显示全部楼层
今天试了下8寸的,感觉没6.5的爽啊 是不是在外面,太空旷的缘故?,因为太忙,明天把6.5的那对,也放出去试 ...
外行发烧 发表于 2012-1-13 22:17
兄台的箱很漂亮!
GMT+8, 2025-12-6 00:35 , Processed in 1.364897 second(s), 7 queries , Gzip On, Redis On.
