- 2415
- 2137 小时
- 2026-5-9
- 100
罗宾汉
当前离线
BD7JQD tda1543*4+td2024+Roge
- 32294
- 5033
- 2415 点
- 2333 ¥
- 2007-12-16
a big assumption in the above calculation is that we are using bjt transistors, and as a result run the amp in Class A.
以上假设计算的前提是,使用双极型晶体管,目的是使用在甲类放大电路中.
if you use mosfets output devices, you have the option to run the output in Class B, and idle the output devices at much lower current levels (typically 100ma).
如果使用场效应管做输出,你可以使用乙类放大电路,且静态电流可以设置在比较低的水平上(典型100ma)
however, mosfets have much higher saturation voltages (4-5volt typically), so you will likely need to run the amp at higher supply voltage.
可是场效应管有着更高的饱和压降,(电芯那个4-5v),因此你需要让这个电路工作在更好的电压上.
here is a quick calculation, assuming that we generate the same output voltage on the same load, but with mosfets.
这有一个快速计算办法.假设,我们在相同负载输出相同的电压,但是使用场管
to output 16.5v on a 6ohm load, the mosfets should sustain 16.5v+5v saturation voltage = 21.5v, or 43vdc supply rail. That means 43vdc/1.3=33vac from yourpower transformer.
在6欧姆负载上输出16.5v.场管需要16.5V+5V=21.5v供电来维持,也就是需要21.5x2=43v的供电电压,这也就意味着,变压器需要33V交流输出
assume that we idle the mosfets at 100ma, each device will dissipate about 21.5v*100ma=2.2w, or 5w per amp. far less than a typically to220 device can take. So an IRF540 class mosfet will work perfectly here.
假设我们设置其静态电流为100ma,每个管子需要耗散21.5x0.1=2.2w,也就是双声道需要5W,远低于TO220封装的耗散功率,因此IRF540一类场管可以用于此
as you can see, with mosfets you dissipate less than 20% of the heat generated by bjts.
由此看来,场管低于双极型晶体管20%的发热量 |
