刺客
235 点
235 ¥
发表于 2008-12-14 21:48 | 显示全部楼层
期待
罪恶燃烧
1255 点
1002 ¥
 楼主| 发表于 2008-12-14 21:49 | 显示全部楼层
原帖由 发烧龙 于 2008-12-14 21:42 发表
套件在哪里买?短信告诉我下好么?谢谢。
β22爱好者QQ群 63247767
罪恶燃烧
1255 点
1002 ¥
 楼主| 发表于 2008-12-14 22:08 | 显示全部楼层
谢谢O大大 帮忙更新完图片 全文完毕
精妙绝伦博古通今.嘻嘻
1904 点
1904 ¥
发表于 2008-12-14 22:31 | 显示全部楼层
四川老乡的贴要顶~
的确是好东西!
罪恶燃烧
1255 点
1002 ¥
 楼主| 发表于 2008-12-14 23:08 | 显示全部楼层
原帖由 iop 于 2008-12-14 22:31 发表
四川老乡的贴要顶~
的确是好东西!
谢谢了
4254 点
4563 ¥
发表于 2008-12-14 23:27 | 显示全部楼层
好。功力深厚
2857 点
2785 ¥
发表于 2008-12-14 23:43 | 显示全部楼层
原帖由 燃烧我的罪恶 于 2008-12-14 20:28 发表
结构上是这样的
但是国内就是不容易购买到
我曾经问过很多家 有些甚至天价啊 几十元的报价
jfets are typically sold in grades based on their Idss. so you just need to buy a few of them in the same grade and hand match them.
2sk170 or lsk170 are very very good jfets for such purposes.
2857 点
2785 ¥
发表于 2008-12-15 00:08 | 显示全部楼层
给点 改进意见啊
how you want to modify it depends a lot on what you want with this amp and how you approach audio in general.
just some obvious design considerations, based on the first schematic in post #2:
1) you should never use a mosfet without gate stoppers. R8=R26=11 - 470ohm based on your mosfet and for this particular pair, you can go lower but not having one is asking for trouble.
2) R14/R21: unless you want to use this as a power amp, use higher R14/R21 to mminimize distortion andn provide better thermal stability. 4.7 - 47ohm would be a good starting point.
3) C6/C7/C12/C13 are on the small side. but keep them if your amp isn't oscillating.
4) Q12/Q13: the use of BJTs to compensate mosfet output devices tends to result in overcompensation. I would use a Vgs multiplier here -  replace those transistors with the same transistors as your output device.
5) R35/R34: this is not a CFB amp and it doesn't benefit from absurdly small feedback resistors. not to mention those astronomical gain numbers for a headphone amp.
6) C19: don't use C19 unless you have exhausted anything else.
7) R18: too large. it doesn't nothing but make the amp susciptible to interference and introduces thermal noise. for perfect offset cancellation, R18=R34//R35 but since you are using jfets, that may not be as big of an issue here. I would make sure that it is less than 47k.
8) R9/R10/R19/R24: a little bit high, especially for jfets but shouldn't be a big deal.
9) C2/C16: make sure you use a small and fast capacitor. I typically use polyester caps here.
if you step back, you will notice that this is an overkill for a headphone amp. you wouldn't even come close to remotely using a tiny fraction of this amp's capabilities to drive most headphones.
will you get good sound out of it? yes.
will you get more than what you could out of a much simpler design? yes.
will you be able to tell them apart? highly unlikely.
the design is a "techno" design in that it pursues the best measurement, regardless if such measurement brings any betterment to the sound, or at what cost (both monetary or effortwise).
it is designed by a very technically superior designer who has minimal understanding of how to design a beautiful sounding amp.
I will take any of Pass' designs over this one (b22), even though the Pass designs are far inferior to this amp technically.
I was recently discussing this very issue and the analogy I used is that a great race car driver knows when to slow down and a new race car driver only wants to drive fast.
hope that helps.
吝啬
1102 点
1102 ¥
发表于 2008-12-15 00:58 | 显示全部楼层
看着那一堆电容也足够口水了。强帖一定要顶!!!
1324 点
1302 ¥
发表于 2008-12-15 01:29 | 显示全部楼层
大制作,大手笔。
326
辉记DIY
8192 点
6427 ¥
发表于 2008-12-15 02:02 | 显示全部楼层
很漂亮的机,做者的功夫也是一流
73
2933 点
2608 ¥
发表于 2008-12-15 02:11 | 显示全部楼层
确实不错。
159
6251 点
2937 ¥
发表于 2008-12-15 08:39 | 显示全部楼层
这个比KG那个完善多了。不过我十分反对3通道,宁愿4通道或者2通道。那些插座十分YY。
129
农夫,山前有点田!
5493 点
3823 ¥
发表于 2008-12-15 09:40 | 显示全部楼层
这是本年度我见过的最高水准DIY作品!
144 点
144 ¥
发表于 2008-12-15 11:16 | 显示全部楼层
事后冷静分析,原因是B22在没有接电位器的情况下,1M多长的信号线配合高达1M的输入阻抗让放大器立马自激,功率管归西。
这么可怕?
全能选手
400 点
358 ¥
发表于 2008-12-15 12:31 | 显示全部楼层
要支持一下。这种全对称双差分渥尔曼电路性能非常高
351 点
293 ¥
发表于 2008-12-15 12:34 | 显示全部楼层
有点进口厂机味道
719 点
700 ¥
发表于 2008-12-15 12:44 | 显示全部楼层
建议出产品出售。
1215 点
1214 ¥
发表于 2008-12-15 12:47 | 显示全部楼层
很详细.看来这耳放电路要火一阵了.
2476 点
2393 ¥
DIY大赛获奖
发表于 2008-12-15 12:49 | 显示全部楼层
原帖由 ngzxm 于 2008-12-15 12:31 发表
的确这种电路不但性能好声底也非常的不错,希望有DX能出大功率的的后级板
GMT+8, 2026-4-9 00:49 , Processed in 0.136918 second(s), 8 queries , Gzip On, Redis On.
