- 1255
- 1576 小时
- 2023-12-17
- 70
- 4
- 34083
- 1113
- 4
- 1255 点
- 1002 ¥
- 2008-1-15
楼主 |
发表于 2008-12-15 20:18
显示全部楼层
首先感谢millwood热心提出的宝贵意见
我菜菜的翻译了下有关技术的,方便更多人看。
原帖由 millwood 于 2008-12-15 00:08 发表
how you want to modify it depends a lot on what you want with this amp and how you approach audio in general.
一般来讲 有很多种方法来修改和提高这个放大器
just some obvious design considerations, based on the first schematic in post #2:
下面是一些关于二楼图纸的一些明显的设计考虑
1) you should never use a mosfet without gate stoppers. R8=R26=11 - 470ohm based on your mosfet and for this particular pair, you can go lower but not having one is asking for trouble.
使用MOSFET必须使用gate stoppers,在这个制作中 mosfet 使用R8=R26=11 - 470ohm,除非比较殊的,用很小的但是自找麻烦
2) R14/R21: unless you want to use this as a power amp, use higher R14/R21 to mminimize distortion andn provide better thermal stability. 4.7 - 47ohm would be a good starting point.
对于R14/R21,除非你想将这个做为一个大功率放大器,使用更大的R14/R21来降低失真,并提高热稳定性,4.7~47ohm 比较合适。
3) C6/C7/C12/C13 are on the small side. but keep them if your amp isn't oscillating.
C6/C7/C12/C13取值小了,如果放大器不自激就可以保持不变
4) Q12/Q13: the use of BJTs to compensate mosfet output devices tends to result in overcompensation. I would use a Vgs multiplier here - replace those transistors with the same transistors as your output device.
Q12/Q13是使用的三极管来补偿输出用的的MOSFET,但容易导致过渡补偿,我会在这里使用Vgs multiplier在这里,用你输出级的MOSFET来替换这些器件
5) R35/R34: this is not a CFB amp and it doesn't benefit from absurdly small feedback resistors. not to mention those astronomical gain numbers for a headphone amp.
对于R35/R34 该机并不是一个CFB amp,如此小的 反馈电阻是荒谬的 得不到好处。对于耳机放大器来说是不需要的
6) C19: don't use C19 unless you have exhausted anything else.
不要使用C19,除非你不得不用
7) R18: too large. it doesn't nothing but make the amp susciptible to interference and introduces thermal noise. for perfect offset cancellation, R18=R34//R35 but since you are using jfets, that may not be as big of an issue here. I would make sure that it is less than 47k.
R18过于大,容易让放大器受到干扰和引入噪声,最佳的大小应该是R18=R34//R35 ,但是这里使用的JEFET,所以可能不够大,我确认这里至少要使用47K
8) R9/R10/R19/R24: a little bit high, especially for jfets but shouldn't be a big deal.
对于R9/R10/R19/R24 稍微大了点,虽然这是可以针对JFET
9) C2/C16: make sure you use a small and fast capacitor. I typically use polyester caps here.
C2/C16 确保使用的是小容量和充放快速的电容,我推荐使用聚酯电容
