2753 点
2609 ¥
发表于 2013-9-25 20:59 | 显示全部楼层
高低音单元  源自SEAS  非常亲民的
-= Class A Fans =-
1551 点
1381 ¥
 楼主| 发表于 2013-9-26 08:55 | 显示全部楼层
344ms 发表于 2013-9-25 20:59
高低音单元  源自SEAS
感谢补充!
-= Class A Fans =-
1551 点
1381 ¥
 楼主| 发表于 2013-9-26 08:57 | 显示全部楼层
11.Focal-JMlab Grande Utopia EM
Description: Three-way, five-driver dynamic loudspeaker system. Drive-units: 15" woofer, 11" midbass/lower midrange, two 6.5" midrange units, 1.2" inverted-dome tweeter. Crossover points: 400Hz, 3kHz. Impedance: 4 ohms nominal, 3.2 ohms minimum. Sensitivity: 95dB/W/m. Frequency response: 20Hz–25kHz, ±3dB. Maximum spl: 118dB. Maximum program power: 500W.
Dimensions: 69" H by 20~" W by 30" D. Weight: 397 lbs.
Price: $65,000/pair. Approximate number of dealers: 6.
Manufacturer: Focal-JMlab, BP 201-42013 Saint-Etienne Cedex 2, France. US distributor: Prism Audio Group, Dallas, TX 75234 (1995. Audio Plus Services 156 Lawrence Paquette Industrial Drive, Champlain, NY 12919. Tel: (800) 663-9352 (2012).
Web: www.audioplusservices.com
-= Class A Fans =-
1551 点
1381 ¥
 楼主| 发表于 2013-9-26 09:02 | 显示全部楼层
12.Aerial Acoustics Model 7T
Description: Three-way, floorstanding loudspeaker. Drive-units: 1" (25mm) soft ring-radiator tweeter with dual magnets and machined waveguide; 5.9" (150mm) papyrus-blend midrange cone with 1.25" (32mm) voice-coil, dual magnets, and cast magnesium frame; two 7.1" (180mm) bilaminate-cone woofers with 1.5" (39mm) voice-coils and cast magnesium frames. Crossover: 400 and 3000Hz, both four-order Linkwitz-Riley. Frequency response: 28Hz–25kHz, ±2dB; –6dB at 23Hz. Dispersion: 30Hz–15kHz, +0/–3dB from axial response over 45° horizontal window. Impedance: 4 ohms nominal, 3 ohms minimum. Sensitivity: 89dB/2.83V/m. Power requirements: 25W minimum, >100W recommended. Two sets binding posts for biwiring/biamping.
Dimensions: 44.5" (1130mm) H by 9.7" (245mm) W by 15.3" (390mm) D (height includes base). Weight: 96 lbs (44kg)
Finishes: Gloss Cherry, Gloss Rosenut, Nero Metallic Black.
Serial Numbers Of Units Reviewed: 074051, 074052.
Price: $9850/pair. Approximate number of dealers: 23.
Manufacturer: Aerial Acoustics Corporation, 100 Research Drive, Wilmington, MA 01887. Tel: (978) 988-1600. Fax: (978) 988-1661.
Web: www.aerialacoustics.com
-= Class A Fans =-
1551 点
1381 ¥
 楼主| 发表于 2013-9-26 09:05 | 显示全部楼层
13.DeVore Fidelity Orangutan O96
Description: Two-way, stand-mounted loudspeaker with reflex port. Drive-units: 1" silk-dome tweeter, 10" paper-cone woofer. Frequency range: 25Hz–28kHz. Sensitivity: 96dB/W/m. Impedance: 10 ohms nominal, 8.75 ohms minimum (at 200Hz).
Dimensions: 28.25" (725mm) H by 18" (460mm) W by 12" (310mm) D. With stands, 35.5" (910mm) H. Weight: 55 lbs (25kg).
Finishes: Veneer-covered ply (front baffle), gloss black (enclosure).
Serial number of units reviewed: O9605033 (both).
Price: $12,000/pair, including stands. Approximate number of dealers: 8.
Manufacturer: DeVore Fidelity, Brooklyn Navy Yard, 63 Flushing Ave., Unit 259, Brooklyn, NY 11205. Tel: (718) 855-9999. Fax: (718) 855-9998.
Web: www.devorefidelity.com
-= Class A Fans =-
1551 点
1381 ¥
 楼主| 发表于 2013-9-26 09:07 | 显示全部楼层
14.Jadis Eurythmie II
Description: 4-way hybrid horn/dynamic-driver loudspeaker system. Crossover frequencies: 180Hz, 700Hz, 7kHz. Peak power handling: 70W. Sensitivity: 103dB/W/m with bi-amplification, above 180Hz, 96dB/W/m with mono-amplification.
Dimensions: 59" (1500mm) H by 27.5" (700mm) W by 27.5" (700mm) D. Weight: 176 lbs (80kg).
Price: $37,000/pair (1996); no longer available (2012).
Manufacturer: Jadis S.A.R.L., Villedubert, France. US Distributor: Northstar Leading the Way, Durango, CO 81302 (1996); Bluebird Music Ltd., 310 Rosewell Avenue, Toronto, Ontario M4R 2B2, Canada. Tel: (416) 638-8207. Fax: (416) 638-8115.
Web: www.bluebirdmusic.com
-= Class A Fans =-
1551 点
1381 ¥
 楼主| 发表于 2013-9-26 09:10 | 显示全部楼层
15.MartinLogan Montis
Description: Two-way, floorstanding, electrostatic loudspeaker with a powered dynamic woofer. Drive-units: 44" (1118mm) H by 11.3" (287mm) W XStat CLS electrostatic high-frequency transducer (radiating area, 497in.2 [3209cm2]); 10" (254mm) high-excursion, aluminum-cone woofer. Crossover frequency: 340Hz. Frequency response: 29Hz–23kHz, ±3dB. Horizontal dispersion: 30°. Vertical dispersion: 44" (1120mm) line source. Sensitivity: 91dB/2.83V/m. Impedance: 4 ohms, 0.52 ohm at 20kHz. Compatible with 4, 6, or 8 ohm rated amplifiers. Woofer amplifier: 200Wpc (4 ohms). Recommended amplification: 20–500Wpc. Audio controls: ±10dB under 100Hz. Lighting: LED intensity control (On/Dim/Off). Power draw: Idle: <1Wpc (idle), 200Wpc (maximum).
Dimensions: 59.3" (1505mm) H by 12.7" (322mm) W by 18" (457mm) D. Weight: 58 lbs. (26.3 kg).
Finishes: black ash, dark cherry, black cherrywood.
Serial numbers of units reviewed: MTWH 000, MTWH 001.
Price: $9995/pair. Approximate number of dealers: 74.
Manufacturer: MartinLogan, 2101 Delaware Street, Lawrence, KS 66046. Tel: (785) 749-0133.
Web: www.martinlogan.com
376 点
333 ¥
发表于 2013-9-26 09:50 | 显示全部楼层
学习
天造之才,皆有其用!
5040 点
2766 ¥
社区贡献 论坛贵宾 新人进步
发表于 2013-9-26 20:35 | 显示全部楼层
都是神一般的产物,仿也仿不起!
1090 点
1076 ¥
发表于 2013-9-26 20:42 | 显示全部楼层
全是高級貨
350 点
295 ¥
发表于 2013-12-18 11:07 | 显示全部楼层
179win 发表于 2013-9-25 11:54
8.TAD Evolution One
分频器在底座比较方便我等diy调节。有收获。
87
236 点
165 ¥
发表于 2013-12-18 13:42 | 显示全部楼层
179win 发表于 2013-9-25 11:01
7.Sony SS-AR2
多谢楼主提供的资料。
不过个人认为鉴赏价值高于参考价值。
77 点
74 ¥
发表于 2013-12-18 15:20 | 显示全部楼层
养眼.........
110
755 点
667 ¥
发表于 2013-12-18 16:19 | 显示全部楼层
等哥成千万富翁再说饿了
765 点
585 ¥
发表于 2013-12-18 20:09 | 显示全部楼层
也就只能欣赏一下了,谢谢提供!
GMT+8, 2025-12-5 20:06 , Processed in 0.136012 second(s), 7 queries , Gzip On, Redis On.
