- 1551
- 1651 小时
- 2021-1-7
- 70
侠之大者
当前离线
-= Class A Fans =-
- 183733
- 1493
- 1551 点
- 1381 ¥
- 2010-3-21
楼主 |
发表于 2013-9-25 10:56
显示全部楼层
5.MBL Radialstrahler 101E Mk.II
Description: Four-way floorstanding loudspeaker. Three omnidirectional bending-mode drive-units: 24-segment carbon-fiber tweeter, 12-segment carbon-fiber upper-midrange unit, 12-segment aluminum lower-midrange unit; plus, in separate enclosure, bandpass-loaded 12", aluminum-cone woofer. Crossover frequencies: 105Hz, 600Hz, 3.5kHz (Linkwitz-Riley, fourth-order). Acoustic center: 45" (1140mm) from floor. Frequency range: 24Hz–40kHz. Sensitivity: 81dB/2.83V/m. Nominal impedance: 4 ohms. Power handling: 320–500W continuous, 2.2kW peak.
Dimensions: 67" (1720mm) H by 16" (410mm) W by 18" (460mm) D. Weight: 176 lbs (80kg).
Finishes: Piano Black, Piano Silver, Piano White, with chrome or gold-plated accents.
Serial numbers of units reviewed: 233831 & '2.
Price: $70,500/pair. Approximate number of dealers: 10.
Manufacturer: MBL Akustukgerate GmbH & Co., KG, Kurfurstendamm 182, Berlin 10707, Germany. Tel: (49) 030-2300584-0. Fax: (49) 030-230058410. Web: www.mbl-germany.de. US distributor: MBL North America, Inc., 263 West End Avenue, Suite 2F, New York, NY 10023. Tel: (212) 724-4870.
Web: www.mbl-northamerica.com |
