[基础知识] 我的第二版1541DAC装机报告
[复制链接] 查看: 84521|回复: 191
437 点
5 ¥
发表于 2005-2-21 09:28 | 显示全部楼层
强烈警告…………
以下是引用finneybear在2005-2-21 3:49:00的发言:
CADDOCK<I></I> TF020
<img src="attachments/dvbbs/2005-2/200522134836907.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-2/200522134836907.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
用这个电阻要注意…………请将她放底,进行………………不然在高潮呻吟会有点毛…………
112
2492 点
634 ¥
元老级
发表于 2005-2-21 07:37 | 显示全部楼层
严重抗议!
finneybear老大快把我毒晕过去了……[em09][em09][em09]
350 点
38 ¥
发表于 2005-2-21 04:51 | 显示全部楼层
caddock正点
多少钱买的?
179 点
2 ¥
发表于 2005-2-21 04:00 | 显示全部楼层
NCC 最新超猛固态电容
比一般 OS-Con 强 30%, 一颗 100uf 放电能力等於一般 6800uf 的!
<img src="attachments/dvbbs/2005-2/200522135931151.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-2/200522135931151.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
179 点
2 ¥
发表于 2005-2-21 03:56 | 显示全部楼层
我最坏!
S2!
<img src="attachments/dvbbs/2005-2/200522135550847.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-2/200522135550847.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
179 点
2 ¥
发表于 2005-2-21 03:49 | 显示全部楼层
再来!
CADDOCK TF020
179 点
2 ¥
发表于 2005-2-21 03:41 | 显示全部楼层
强人?!! 这次该我晕倒!!
意淫一下吧, 上礼拜刚买的一堆聚苯乙烯电容. .01uf 和 1nf 的.
<img src="attachments/dvbbs/2005-2/200522134016688.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-2/200522134016688.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
399
超级版主 当前在线
16988 点
8778 ¥
 楼主| 发表于 2005-2-21 00:16 | 显示全部楼层
强人finneybear兄曾经说过
“ 这 14 颗电容是 1541 的设计精华所在”。当初不屑一顾。实在有眼无珠。
后来经过多次试验,的确如此。
以下是引用finneybear在2005-2-20 9:42:00的发言:
这几天会写篇文章解释这<I></I> 14<I></I> 颗电容的工作原理和跟声音的关系,<I></I> 在这和老飘的
网站刊登.<I></I> 1541<I></I> 低音虚浮的问题跟这<I></I> 14<I></I> 颗电容有绝大关系.
[em08][em08][em11][em11]
399
超级版主 当前在线
16988 点
8778 ¥
 楼主| 发表于 2005-2-20 22:44 | 显示全部楼层
贵族
以下是引用seabreeze在2005-2-20 22:33:00的发言:
你贴的那个还是noble,是那个著名的电位器牌子?
157
8211 点
2614 ¥
发表于 2005-2-20 22:35 | 显示全部楼层
请问zwuzzy兄,你所说的电容是这种吗
<img src="attachments/dvbbs/2005-2/200522022335742.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-2/200522022335742.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
当初也想过作6N11的阴极电容(四个并联)。但看脚位不合便放弃了
112
2492 点
634 ¥
元老级
发表于 2005-2-20 22:33 | 显示全部楼层
这两个二极管在一些DAC芯片的datasheet里有介绍的
这种聚苯乙烯电容用在DAC里绝对是不可多得的上品,可惜难觅啊,你贴的那个还是noble,是那个著名的电位器牌子?
399
超级版主 当前在线
16988 点
8778 ¥
 楼主| 发表于 2005-2-20 22:26 | 显示全部楼层
有道理
以下是引用seabreeze在2005-2-20 22:11:00的发言:
接入两只反向并联的二极管,<I></I> 是避免出现因上电不同步导致器件逻辑锁死
[em09][em11]
399
超级版主 当前在线
16988 点
8778 ¥
 楼主| 发表于 2005-2-20 22:25 | 显示全部楼层
应该是聚苯乙烯,铜膜的更好。
以下是引用seabreeze在2005-2-20 22:16:00的发言:
是不是聚苯乙烯啊,我有几个从国产通讯设备拆下的透明的也像这样,每只都是两个并联修正精度,这种电容应该是有感绕法,但用在数字耦合比WIMA好得多了,只是体积太大[em11]
但用在数字耦合也非常好。可惜容量大的难找。
[em11]
157
8211 点
2614 ¥
发表于 2005-2-20 22:20 | 显示全部楼层
我也认为是
当时不是用在TDA1541上的。是CS8412+SM5843+PCM1700上。
记得当初总共用上十几组稳压供电
[em10][em10][em10]
112
2492 点
634 ¥
元老级
发表于 2005-2-20 22:16 | 显示全部楼层
HQ兄贴的那几个电容
157
8211 点
2614 ¥
发表于 2005-2-20 22:15 | 显示全部楼层
私弊红头的轴向小电解本人只有150uF的
[em07][em07][em07]
112
2492 点
634 ¥
元老级
发表于 2005-2-20 22:11 | 显示全部楼层
同意文招
接入两只反向并联的二极管, 是避免出现因上电不同步导致器件逻辑锁死
159
6251 点
2937 ¥
发表于 2005-2-20 22:01 | 显示全部楼层
如果是16uf
肯定是起到提升高频的作用了。不能说不好,也不能说不好。
噪音是交流声,高频的噪音没有增加。
现在我用的陷波器根本不用怕交流声了。又能更好的保留自然的声音。[em11]
已经爽了好几天,每天都能听6,7个小时。[em11]
981 点
350 ¥
发表于 2005-2-20 21:46 | 显示全部楼层
刚才把阴极电阻改成了两只私弊
红头的轴向小电解,8UF/50V,后面并连两只同样的,总共16UF,声音改善让我吃惊,低音没有削弱,高频改善巨大,听“四川”里的第一首竹笛,感觉真是余音绕梁,三日不绝啊。
同时TDA1541那只470P的小电容曾用过云母的,后来还是换成了WIMA的HQ系列的聚丙烯电容,感觉还是好些。
以上请文招兄斟酌。
399
超级版主 当前在线
16988 点
8778 ¥
 楼主| 发表于 2005-2-20 21:41 | 显示全部楼层
什么噪音相对来说大了点?
以下是引用aeon在2005-2-20 20:16:00的发言:
曾经试过33欧的电阻,噪音相对来说大了点,输出的电平也低了恨多,但低频恨爽呢。
GMT+8, 2026-5-19 21:52 , Processed in 0.144919 second(s), 8 queries , Gzip On, Redis On.
