[心得经验] PHILIPS AK640 CD的改装(参赛)
[复制链接] 查看: 114120|回复: 158
130 点
0 ¥
发表于 2005-3-11 01:33 | 显示全部楼层
哪位大师能帮帮我,我的PHILIPSAK64不读盘
进出盘正常,主轴不转,面板指示代码“E”
919 点
10 ¥
发表于 2005-3-11 08:03 | 显示全部楼层
130 点
0 ¥
发表于 2005-3-12 23:13 | 显示全部楼层
我爱diy
<img src="attachments/dvbbs/2005-3/2005312231124601.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-3/2005312231124601.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
这个板子你还有吗?给我一张行吗?
143 点
-1 ¥
 楼主| 发表于 2005-3-12 23:39 | 显示全部楼层
看看你的晶振是否坏了
以下是引用ddrsdr在2005-3-11 1:33:00的发言:
67
荣誉版主 当前离线
版主
2130 点
195 ¥
元老级 社区贡献 论坛版主
发表于 2005-3-12 23:45 | 显示全部楼层
楼主技术很好的说。
2294 点
1127 ¥
发表于 2005-3-21 03:29 | 显示全部楼层
论坛版主
8012 点
1636 ¥
元老级 社区贡献 优秀设计
发表于 2005-3-23 22:30 | 显示全部楼层
FALCON4的英文很不错
赞一个。。[em09]
。。。难说那个问你问题的老外,英语水平能不能及上你。。。哈[em11]
falcon4 []
diyAudio Member
Offline
you're welcome!  Post #9
let me try,my eng is poor,so that i hope you could understand what i say.
the original diyer's projet:
1.modify the power supply :add a power plug receptacle(easy to change the power line),change the old power transformer to a 50W 17V~X2 EI transformer(look at the pic below).
+5v to crystal, digital output board
+5v to mainboard
+5v to display ,control panel
+12v to motor drive
2.change the original electrolyte caps to philips caps or nichicon caps,and the terylene caps to polypropylene caps.
3.change the 3pin crystal to a high quality 4pin crystal. and take out the 1M resistor and the 33pf cap at the 71pin(xin) and 72pin(xout) of the saa7341.the high quqlity crystal's out pin solder to the 71pin of the saa7341.the 32pin of the 7341 is the digital output, solder it to the digital output board's(by buy) input pin.
the green board is the digital out board.
4.add a infrared remote control:
add 4 components: the sony's infrared receiver , 4.7k 100 resistor and a BC560
196 点
53 ¥
发表于 2005-3-24 11:06 | 显示全部楼层
CD机的晶振频率多少为最好啊???
2294 点
1127 ¥
发表于 2005-3-24 11:42 | 显示全部楼层
一阴一阳之谓道
5929 点
5418 ¥
发表于 2006-10-29 20:54 | 显示全部楼层
<p>推</p>
永远菜的鸟
1073 点
784 ¥
发表于 2006-10-29 21:40 | 显示全部楼层
246 点
0 ¥
发表于 2006-11-24 17:30 | 显示全部楼层
原来是多少的就换多少的,上面有标住.
246 点
0 ¥
发表于 2006-12-8 08:59 | 显示全部楼层
<div class="quote"><b>以下是引用<i>我爱diy</i>在2005-1-19 19:56:00的发言:</b><br/>这类机的DAC部分改造升级潜力不大,所以我的观点是加装数字输出当转盘使用。<br/>遥控部分因为CPU的不同,我原来一个朋友按你的这种接发加装过他的AK640,控制不是很灵,还有打碟现象。文章里讲了,该机器的主板设计时是有遥控部分的,通过对板子的分析试验,才加装成功的,用BC560这个PNP管,管脚和板子的脚位一样的。<br/><br/><br/><img src="attachments/dvbbs/2005-1/2005119195749624.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-1/2005119195749624.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />数字输出板<br/><br/><br/><br/><img src="attachments/dvbbs/2005-1/2005119201031477.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-1/2005119201031477.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />加装遥控背面<br/></div><p>请问,数字输出板在哪里买的能给个连结吗?</p>
942 点
612 ¥
发表于 2006-12-8 16:03 | 显示全部楼层
做的不错..
246 点
0 ¥
发表于 2006-12-9 08:01 | 显示全部楼层
请问&lt;我爱DIY&gt;这样一改电源开关不起作用了你是怎么解决的呢?
399 点
219 ¥
发表于 2007-4-10 13:58 | 显示全部楼层
请问一下能把加装红外遥控的部分说得详细点吗?
65
1898 点
1346 ¥
发表于 2007-4-10 16:14 | 显示全部楼层
学习
137
海纳百川
4563 点
4178 ¥
发表于 2007-8-8 11:30 | 显示全部楼层
这样该开关一定是没用了.要另外加,四脚晶镇很好那里搞的能帮我搞一个吗?
137
海纳百川
4563 点
4178 ¥
发表于 2007-8-8 11:32 | 显示全部楼层
另外我想问 下这个机器光头线很难拆下,手进不去,我是连头带板拿下再拆头的,老兄是怎么拆的呢?
419
4614 点
4183 ¥
发表于 2007-8-8 14:49 | 显示全部楼层
支持楼主,....
