[全频音箱] 超级全频喇叭!
  [复制链接] 查看: 1498401|回复: 4428
8 点
8 ¥
发表于 2007-4-30 04:24 | 显示全部楼层
原帖由 于 2007-4-29 20:31 发表
你原先发的那对小的模仿得一模一样,拷贝不走样啊。
小的是今年产品,好像叫H007系列。
原厂网址http://www.fergusonhill.co.uk/index.php
FHOO7 Mini Speaker System
The FHOO7 System is a mini version of the acclaimed FHOO1, FHOO2 & FHOO3 combined system, developed for a wider consumer market. It has been designed to work with all Hi-Fi music player formats. Competitively priced, it should be noted that no compromises were made in the R&D process, the sound and build quality are of the standard expected from a Ferguson hill product.
System dimensions  Specification
Amplifer 14 cm cubed  2 Horn speakers / 8 Ohm
Horn H 43cm W 27cm D 18cm x2  2 Bass speakers / 8 Ohm
Bass Sphere 20 cm diameter x2  Integrated Amplifier / Bi-amped class A/B
16 Watts times four into 8 Ohms
Frequency response 75Hz – 20KHz +/- 5dB
This product conforms with the EMC
Directive and the Low Voltage Directive.
Retail Price in the UK £495.00 incl VAT
Customers in the UK can buy direct from Ferguson Hill just call us on +44 (0)207 284 0969
8 点
8 ¥
发表于 2007-4-30 04:46 | 显示全部楼层
这个好看
FHOO1 Horn Speaker
The Ferguson Hill Loudspeakers are full range units from 150Hz - 20KHz, with no crossover, however, a sub bass unit is required below 150Hz. They reproduce music with a high level of clarity, detail and dynamics, are highly efficient, and will go loud with just a few watts (5 watts).This allows their use with relatively low powered amplifiers further increasing the level of clarity obtainable, from such relatively 'simple' amplifier circuits.
The stands are a welded stainless steel construction, satin polished, with internal damping, integral spikes, supplied with floor protector discs.
The horns are made from toughened cast acrylic, precision moulded, 8mm thick.The support ring and phase plug are precision machined from aluminium alloy, and have a protective anodised finish.The drive unit is a modified Lowther DX3 full range driver.
They require a sub bass/sub woofer from 150 Hz down, with level control, ideally taking the signal from the preamp stage.
Recommended amplifier power, 3 to 50 watts, they are ideally suited to low power valve amps, and also work well with high quality transistor amps. (A demonstration with your chosen amp is highly recommended).
Speaker dimensions  Specification
Height 1.65m  Drive unit: Modified Lowther DX3
Width 0.92m  Sensitivity 1M/1KHz/1 watt 100db
Depth 0.72m  Nominal impedance 8 ohm
Weight 27 Kg each without damping fill
Retail price in the UK £9950 incl VAT
31
3569 点
3118 ¥
发表于 2007-4-30 07:38 | 显示全部楼层
很漂亮,是一件艺术品。
认真的发烧友
3662 点
2874 ¥
发表于 2007-4-30 14:01 | 显示全部楼层
那个英国佬的玻璃球箱,性能不一定好.他不敢提技术数据.
还要价2500英磅.
31
3569 点
3118 ¥
发表于 2007-4-30 19:05 | 显示全部楼层
他的号角用的是LOWTHER单元,不错的。低音不知是什么单元。
18 点
18 ¥
发表于 2007-4-30 21:13 | 显示全部楼层
强帖留名! 对楼主的土炮对感兴趣,是否也能PM个价格!?
31
3569 点
3118 ¥
发表于 2007-4-30 22:43 | 显示全部楼层
原帖由 wjyqz 于 2007-4-30 21:13 发表
请收短信。
41 点
41 ¥
发表于 2007-5-1 20:24 | 显示全部楼层
耳机进度如何???没图了????
31
3569 点
3118 ¥
发表于 2007-5-1 21:27 | 显示全部楼层
试验中的平板振膜,中频好了,高频差了,要取个中间平衡值。
469 点
337 ¥
发表于 2007-5-1 21:44 | 显示全部楼层
中国之声  有你这样的人  中国喇叭的新纪元一定会改写
31
3569 点
3118 ¥
发表于 2007-5-1 22:35 | 显示全部楼层
我想把耳机做成几种不同风格:1)追求极端解晰力 2)追求韵味,渲染中频 3)追求平衡,高中低都很均匀,都不抢耳 ,不冷不热。
我发现这三点只能各自强化,却很难融合在一起。
142 点
258 ¥
发表于 2007-5-2 01:28 | 显示全部楼层
在879楼看到你的新耳机图了,不错,漂亮得很。特别注意到你用上了耳机的那个架子了。
刚去省城把我的X照今天拿回来了,马上要去外边了,一起加油,最近可能会上不成网了,希望再回来这里又看到你的进展,你的成功就是我的动力~~
41 点
41 ¥
发表于 2007-5-2 01:30 | 显示全部楼层
在平衡的基础上,着重解吸....监听...
再就是高频飘逸,中频有韵味......人声.....
51 点
1 ¥
发表于 2007-5-2 16:18 | 显示全部楼层
潜水许久, 有点决心想买倪兄的耳机, 请PM价格? 谢谢!
31
3569 点
3118 ¥
发表于 2007-5-2 17:00 | 显示全部楼层
原帖由 子禾 于 2007-5-2 16:18 发表
请看短信。
敢拆不会修
2186 点
2107 ¥
发表于 2007-5-2 21:12 | 显示全部楼层
一口气看完,无语了
31
3569 点
3118 ¥
发表于 2007-5-4 10:58 | 显示全部楼层
31
3569 点
3118 ¥
发表于 2007-5-4 11:29 | 显示全部楼层
拆完装起来,总会多零件!
851 点
571 ¥
发表于 2007-5-4 12:22 | 显示全部楼层
五一假期再次为倪兄加油!!!
31
3569 点
3118 ¥
发表于 2007-5-4 13:02 | 显示全部楼层
贴两张五一出游时拍的照片
原帖由 小木匠 于 2007-5-4 12:22 发表
五一假期再次为倪兄加油!!!
多谢!
