- 5672
- 2880 小时
- 2019-2-10
- 100
- 2
- 26078
- 5585
- 2
- 5672 点
- 5633 ¥
- 2007-8-18
这是John Curl 最近在diyaudio.com的发言。
It should be understood that the JC-2 design is a PROVEN design topology that has been made in various versions for over 36 years. Slight deviations such as input fet types, output transistors or load resistors changes the distortion slightly, but not significantly. It is better just to build with the essential concepts intact. These are: Comp fet input, low value of load resistor, and fairly high current in the output transistors, 10ma min, 40-60 ma optimum. This will get you there.
__________________
"Condemnation without Examination is Prejudice"
John Curl 25th June 2010, 05:22 PM
这应该明白JC-2已经经过考验的布局,它被制作不同的版本超过36年。轻微的不同例如输入JFET的型号,输出晶体管或负载电阻的变化产生失真的轻度改变。制作它的较好的方法是有一个完整的基本观念,就是:配对的JFET输入,低值的负载电阻,和在输出晶体管足够高的电流,10ma最少,40~60ma最好。这将使你达到目的。
没有分析研究的指责是偏见
John Curl 2010/06/25 05:22 PM
我们仿制名机,就要先掌握该名机的完整的基本观念。 |
