[其他] 1969根本就不算甲类?
[复制链接] 查看: 22991|回复: 92
646 点
544 ¥
发表于 2010-4-19 18:35 | 显示全部楼层
我是旁观的,你们继续,我围观
242
1047 点
1079 ¥
发表于 2010-4-20 00:24 | 显示全部楼层
有道理
59 点
59 ¥
发表于 2010-4-20 10:35 | 显示全部楼层
走过路过,再潜水学习中
846 点
831 ¥
发表于 2010-4-20 14:44 | 显示全部楼层
还在学习中!
81
穷骨头发烧
1298 点
662 ¥
发表于 2010-4-20 14:53 | 显示全部楼层
甲类就甲类,什么叫纯甲类?换个马甲还是甲类。
269 点
264 ¥
 楼主| 发表于 2010-4-21 01:43 | 显示全部楼层
看来有不少人误会了…甲类就是纯甲类,两者无分别…我是说OTL只能做到类甲…即类似甲类状态并不是甲类…拜托那些扔砖头前先用心看清楚贴再扔好不?汗
173 点
177 ¥
发表于 2010-4-22 08:59 | 显示全部楼层
继续潜水…学习中
921 点
935 ¥
发表于 2010-4-22 09:00 | 显示全部楼层
逸.风 发表于 2010-4-21 01:43
哈哈哈哈哈哈!!!!!
430 点
430 ¥
花甲前辈
发表于 2010-4-22 13:24 | 显示全部楼层
菜鸟,我看不懂。管它69还是79,只要是好听的,给个MP3我一样用。
848 点
843 ¥
发表于 2010-4-22 15:17 | 显示全部楼层
甲类?类甲?文字游戏?
702 点
330 ¥
发表于 2010-4-22 23:07 | 显示全部楼层
4595 点
4559 ¥
发表于 2010-5-7 13:22 | 显示全部楼层
垃圾电路。。不思进取的人才会做。。
hdmdiy 发表于 2010-4-17 16:09
垃级?!那你开发一部又好声 人人会做  价级低 元件易购 又是甲类的功放来!
101 点
101 ¥
发表于 2010-5-7 14:53 | 显示全部楼层
论坛不只有潜规则,不利的帖子还会删的呢!
1387 点
1586 ¥
发表于 2010-5-7 16:39 | 显示全部楼层
1969.没做,也不想做,浪费时间是一,更可怕的是,走这条路,思路给封闭,所以不做
5672 点
5633 ¥
发表于 2010-5-7 19:52 | 显示全部楼层
66# 逸.风
我虽然没做1969,但是请问甲类和类甲主要区别在什么地方?
下面有甲类的定义(也提到了亚甲),阁下说的类甲是怎么定义的?是否就是下文提到的 Subclass A2?而亚甲(Subclass A2)是有时用来指胆机的特定的工作状态的。
Class A
100% of the input signal is used (conduction angle Θ = 360° or 2π; i.e., the active element remains conducting[5] (works in its "linear" range) all of the time. Where efficiency is not a consideration, most small signal linear amplifiers are designed as Class A. Class A amplifiers are typically more linear and less complex than other types, but are very inefficient. This type of amplifier is most commonly used in small-signal stages or for low-power applications (such as driving headphones). Subclass A2 is sometimes used to refer to vacuum tube Class A stages where the grid is allowed to be driven slightly positive on signal peaks, resulting in slightly more power than normal Class A (A1; where the grid is always negative[6]), but incurring more distortion
再下面是更为简明的解释
Class A
The amplifier conducts current throughout the entire cycle (360º). The Class A design is the most inefficient and is used in low-power applications as well as in very high-end stereo. Such devices may be as little as 15% efficient, with 85% of the energy wasted as heat.
179 点
179 ¥
发表于 2010-11-25 14:44 | 显示全部楼层
纯甲类应该是单管的,用NPN和PNP对管组成的是乙类,加上直流偏置就是甲乙类。
913 点
913 ¥
发表于 2010-11-25 14:52 | 显示全部楼层
发烧是追求是音质而不是分什么类的!只要有好的音就是我们DIY所要的目的!
volov960 发表于 2010-4-17 16:24
179 点
179 ¥
发表于 2010-11-25 15:10 | 显示全部楼层
[size=7]甲类放大器直流偏置设置得当,输出波形不会产生失真,但是没有信号输入时,也要消耗很大的功率,乙类放大器没有输入信号时消耗功率很小,但是会产生交越失真。所以才加一点直流偏置消除交越失真。这就是甲乙类放大器。
100
5541 点
5490 ¥
发表于 2010-11-25 15:16 | 显示全部楼层
大家又在谈论甲乙类话题了,菜鸟我先学好基础再侃吧
114
525 点
508 ¥
发表于 2010-11-25 16:32 | 显示全部楼层
我过来听课  没有权利仍砖头 呵呵  IC阶段。。。
GMT+8, 2025-12-23 10:17 , Processed in 0.159066 second(s), 7 queries , Gzip On, Redis On.
