[音箱资料] 摩雷29和seas h0881哪个性价比高
[复制链接] 查看: 32901|回复: 70
362
2596 点
2596 ¥
论坛贵宾
发表于 2009-5-28 00:17 | 显示全部楼层
原帖由 ttt008 于 2009-5-27 21:57 发表
摩雷29和seas h0881价位相同,?哪个性价比高
MDT29不咋地,高频延伸和解析力都一般般。
以前国内的监一就是用它
等待验证会员 当前离线
游侠
141 点
135 ¥
 楼主| 发表于 2009-5-28 07:35 | 显示全部楼层
感谢J版.那么h1189是不是比h1149更好.h1212如何呢?
292
nostalgia
19692 点
12949 ¥
发表于 2009-5-28 11:41 | 显示全部楼层
回复 #22 ttt008 的帖子
很难说27TDFC和27TDC哪一个更好,我个人感觉是扬声器好坏不能靠价格来判断。
27TDFC有磁液,27TDC没有磁液。前者的瀑布图更干净一些,承受功率更大,分频点能更低。如果分频点需要分到2K,那么我不假思索的会选择27TDFC。
但是对于这两个纸盆低音,分频点2K5也都很合适,27TDC没有磁液显然也很合适,它的互调失真比27TDFC稍小一些。
这样很难取舍,看个人喜好了。
27TBFC/G是铝镁合金的金属膜高音,多数人凭心理感觉就不喜欢这款高音。据老外说,它和27TDFC的磁路是一样的。其实它在这三者之中有最小的失真,最干净的瀑布图。不要被频响曲线那里20K的跌落所吓倒,实际表现不是这样的,一般人想要声音表现它都能提供。
这三者中,我个人最喜欢的是27TBFC/G
摘抄几段国外对27TBFC/G的评价:
1:The Seas 27TB series tweeters are an aluminum tweeter based on the same motor used in the fabric dome versions. I chose the "TBFCG" version, which has ferrofluid and a rear chamber. Don't let the slightly rolled off top octave fool you... this tweeter will have all the "air", "sparkle" and [insert audiophile verbage here] that you'll ever need. But the best thing about it is its smooth response, low distortion and low frequency power handling ability.
2:The Seas 27TBFCG is one of the best tweeters at any price
3:The Seas 27TBFC/G is the new low cost testing champion. It gets this by having notably improved nonlinear distortion numbers higher up in the spectrum while having the same great low end performance.
4:The tweeter is the famous H1212. Delicious tweeter and though he certainly aluminum soft sound and very detail rich.
5:What beats the R2904/7000 ring radiator?
Well it depends.
Seas 27TBFC/G can be considered even if it's cheap.
6:Simply put, because it *is* the best in the group, even regardless of cost. If the Millennium only cost $30, I'd still buy the 27TBFCG. Of course the build quality of the Millennium is excellent. I love the thick metal frame. But the 27TBFCG sounds and measures better.
7:Yes, Seas 27TBFCG is one of the best sonding things I ever heard compared to it' s cost
8:Very smooth response, down a few dB at 20kHz. Very low distortion of all types, particularly the near non-existant high order harmonics. No notable energy storage problems.
当然这不意味着27TDFC和27TDC不好,其实他们和27TBFC/G之间的差距是很小的。甚至在某些程度上,27TFFC和他们三者之间的差距也是很小的。从某些业余的说法来看,软球顶也许和纸盆搭配音色还更连贯呢。
2754 点
2610 ¥
发表于 2009-5-28 13:32 | 显示全部楼层
模糊记得J版以前在某个帖里说过SEAS  Mimir(密弥尔)套件有问题
请J版具体说明一下
292
nostalgia
19692 点
12949 ¥
发表于 2009-5-28 13:41 | 显示全部楼层
回复 #24 344ms 的帖子
不会吧,不可能是我讲的吧。最多是在老外的帖子里见老外说过
2754 点
2610 ¥
发表于 2009-5-28 13:45 | 显示全部楼层
张冠李戴了 好像是说频响曲线太雷人
J版说说
292
nostalgia
19692 点
12949 ¥
发表于 2009-5-28 13:46 | 显示全部楼层
回复 #26 344ms 的帖子
老外也就是说他的箱体设计和分频设计还不是最优化而已,据说自己重新设计可以至少提升60%效果
2754 点
2610 ¥
发表于 2009-5-28 13:50 | 显示全部楼层
他家的纸盆和铝盆  相比较各有什么特点
2754 点
2610 ¥
发表于 2009-5-28 14:01 | 显示全部楼层
纸盆系列 H1216-5寸 H1217-6.5寸小磁 H1215-6.5寸大磁
铝盆系列 H1141-5寸 H1085-6.5寸小磁 H1224-6.5寸大磁
打算在上面几款单元中选择
292
nostalgia
19692 点
12949 ¥
发表于 2009-5-28 14:08 | 显示全部楼层
回复 #29 344ms 的帖子
前面提到的CA15RLY和CA18RNX就是H1216和H1215,很好用,也很容易制作。CA18RLY要求箱体容积稍大,都适合做小落地了。
L15RLY/P会要求很低的分频点,那需要搭配一个很好的高音,这对于一个5寸单元来说,有点奢侈了。不过我觉得这个单元的失真很接近同口径的黄金系列,是个很有性价比的单元。
L18RCY/P和夜莺上面用的差不多,这个低音分频点似乎应该更低,也就是1.4K以下吧,应该不适合做2分频了。
L18RNX/P分频点可以上到1.8K,也只有少数几款高音可以搭配了。前面提到过这个低音,做得好应该不错吧。比同口径的黄金系列容易使用。
我比较喜欢用SEAS的单元命名来讨论,这样一眼就能看出单元的材料和用途,大致结构。用编号的话,还需要去查看到底是什么单元。
比如H1212,我不知道它是什么单元。不过如果说出来它是27TBFC/G,就大致知道27TB是1寸的是铝镁合金高音,F是有磁液,C是有后腔,G是前面有金属网格。
729 点
675 ¥
发表于 2009-5-28 14:36 | 显示全部楼层
谢谢yong-cd 兄分享SEAS厂方的图纸资料
546 点
439 ¥
新人进步
发表于 2009-5-28 14:52 | 显示全部楼层
原帖由 tt1558 于 2009-5-28 14:36 发表
客气了,这个也是坛子上hero89 大侠告诉我的。hero89 兄还有个图纸,但是不太详细。
546 点
439 ¥
新人进步
发表于 2009-5-28 14:53 | 显示全部楼层
分频
ao la!!
1285 点
1293 ¥
发表于 2009-5-28 15:09 | 显示全部楼层
H0881-06 27TFFC  290  $ 1
H1149-06 27TDC   286$
价格有提高了,晕
1061 点
358 ¥
发表于 2009-5-28 19:35 | 显示全部楼层
原帖由 Julien 于 2009-5-27 23:55 发表
根据国外网友的反馈,如果自己设计分频和箱体,效果比SEAS厂提供的更好,效果上升60%不止
我对CA18RNX+27TDFC或CA18RLY+27TDFC的组合很感兴趣,可自个实在菜,为了"效果上升60%不止"我在等有同好的玩家自己设计分频和箱体的实作,希望能享个现成照搬就是
231 点
112 ¥
发表于 2009-5-28 20:08 | 显示全部楼层
1216不能分的高么?似乎标称频率满高的~
292
nostalgia
19692 点
12949 ¥
发表于 2009-5-28 20:10 | 显示全部楼层
回复 #36 云海 的帖子
CA15RLY(H1216)可以分高啊,2K5到3K都可以啊
231 点
112 ¥
发表于 2009-5-28 20:20 | 显示全部楼层
菜鸟我挺看好1216+1212的。J版h883似乎比1212曲线还平一点么?请教什么分频结构比较好,l版那种理想么?
292
nostalgia
19692 点
12949 ¥
发表于 2009-5-28 20:25 | 显示全部楼层
回复 #38 云海 的帖子
27TAFC/G(H0883)后来被我淘汰了,失真大了点。分频对于CA15RLY来说,不难做的,低阶高阶都可以的。
231 点
112 ¥
发表于 2009-5-28 20:34 | 显示全部楼层
谢谢!
GMT+8, 2026-4-7 01:50 , Processed in 0.141572 second(s), 9 queries , Gzip On, Redis On.
