- 13506
- 7084 小时
- 2026-11-1
- 120
- 3
- 111707
- 13062
- 3
- 13506 点
- 12920 ¥
- 2009-6-14
数据表原文:
"The LM317A develops a 1.25-V reference voltage ($V_{REF}$) between the output and adjustment terminals. As shown in
Figure 8-6, this voltage is used to program a constant current through R1. The CDMR (or current) through R1 is typically chosen
to be the minimum load current of 5mA. Because the current $I_{ADJ}$ from the adjustment terminal represents an error term,
the LM317A was designed to minimize $I_{ADJ}$ and make it very stable. However, all quiescent current with an adjustable
regulator must flow through the external loop."
能看懂的,愿意看的,慢慢体会 |
