- 2021
- 9156 小时
- 2026-11-25
- 100
- 824753
- 1973
- 2021 点
- 1966 ¥
- 2016-12-20
放个以前用谷歌搜到的ECX10N20/ECX10P20仿真模型:
.SUBCKT ECX10P20 1 2 3
* Model Generated by PEDC *
*Copyright(c) Power Electronics Design Centre*
* All Rights Reserved *
* Power Electronics Design Centre *
* Dept of Elec & Electronic Engineering *
* University of Wales Swansea *
* Singleton Park *
* Swansea SA2 8PP *
* Tel : +44 (0)1792 295420 *
* Fax : +44 (0)1792 295686 *
* E-mail : pedc@swansea.ac.uk *
* Model generated on Dec 6 1999
* MODEL FORMAT: SPICE Level 1
* External Node Designations
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
* O [1]
* Z
* Z Rd
* Z
* D2 |
* Cdg0 | /|| [9]
* |-||--|< |O---O-----|
* | [4]| \|| | |
* [2] Rg | ||---| Z ---
* 0--/\/\/\/\-O----|| M1 Z \ /D1
* |[7] ||---| Z ---
* | | Z |
* | Cgs0 | |RDS |
* |-----||--O---O-----|
* | [8]
* O
* Z
* Z Rs
* Z
* O [3]
M1 9 7 8 8 MM L=1 W=1
* Default values used in MM:
* The capacitances are added externally
* Other default values are:
* RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0
.MODEL MM PMOS LEVEL=1 IS=1e-32
+VTO=-0.426 LAMBDA=0.073 KP=0.673
RS 8 3 0.342
D1 9 8 MD
.MODEL MD D IS=1.0e-32 N=50 BV=250
+CJO=1.45e-9 VJ=0.446 M=0.377
RDS 8 9 1e+06
RD 9 1 0.523
RG 2 7 45.2
* Gate Source capacitance Cgs0
CAP1 7 8 696e-12
* Gate Drain capacitance Cdg0
CAP 7 4 15.2e-12
* Gate Drain Capacitance Cdgj0
* Modelled as a diode
D2 9 4 MDD
.MODEL MDD D IS=1e-32 N=50
+CJO=27.6e-12 VJ=0.817 M=0.871
.ENDS ECX10P20
.SUBCKT ECX10N20 1 2 3
* Singleton Park *
* Swansea SA2 8PP *
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
* O [1]
* Z
* Z Rd
* Z
* D2 |
* Cdg0 | \|| [9]
* |-||--| >|O---O-----|
* 0--/\/\/\/\-O----|| M1 Z / \D1
* |[7] ||---| Z ---
* | | Z |
* | Cgs0 | |RDS |
* | [8]
* O
* Z
* Z Rs
* Z
* O [3]
.MODEL MM NMOS LEVEL=1 IS=1e-32
+VTO=0.473 LAMBDA=0.092 KP=1.585
RS 8 3 0.41
D1 8 9 MD
+CJO=1.0e-9 VJ=0.7 M=0.5
RDS 8 9 1e+06
RD 9 1 0.58
RG 2 7 80
CAP1 7 8 400e-12
CAP 7 4 10.5e-12
D2 4 9 MDD
+CJO=94.8e-12 VJ=0.3 M=1
.ENDS ECX10N20
