- 800
- 716 小时
- 2024-5-6
- 50
- 836360
- 843
- 800 点
- 796 ¥
- 2017-8-8
这是它的简介:
The modulation method employed in the Compact Disc (CD) digital audio system codeveloped by Philips N.V. (Eindhoven, The Netherlands) and Sony Corporation (Tokyo, Japan) is described. This method, called eight-to-fourteen (EFM), is an 8 (data bit) ---> 14 (channel bit) conversion block code with a space of 3 channel bits for every converted 14 channel bits which is used to connect the blocks. These 3 channel bits, called merging bits, are selectable, enabling the suppression of the low-frequency contents of the frequency spectrum.
First some of the major conditions are listed which are required of the modulation method used for recording/reproducing digital audio signals on an optical disk. The various parameters of EFM as a modulation method are explained in the second part, proving the suitability of EFM for optical disks. An actual example explains the method in detail; a frequency spectrum is also given to enhance understanding.
EFM is well matched with the error-correction method CIRC employed in the CD. The combination of these two methods plays an important role in stably reproducing a 2-channel 16-bit audio signal on a 12-cm-diameter optical disk for more than playing time, single sided.
描述了由Philips N.V.(荷兰埃因霍温)和Sony Corporation(日本东京)共同开发的光盘(CD)数字音频系统中采用的调制方法。这种方法称为八到十四(EFM),是8(数据位)-> 14(通道位)转换块代码,每个转换的14通道位都有3通道位空间,用于连接块。这3个通道位(称为耦合位)是可选的,从而可以抑制频谱的低频内容。
首先列出了一些主要条件,这些条件是用于在光盘上记录/再现数字音频信号的调制方法所必需的。第二部分介绍了EFM作为调制方法的各种参数,证明了EFM适用于光盘。一个实际的例子详细解释了该方法。还提供了频谱以增进理解。
EFM与CD中使用的CIRC纠错方法非常匹配。这两种方法的结合,使得可以稳定地在直径为12厘米的光盘上,重放2通道16位音频信号的时间超过LP双面播放的时间,这两种方法的结合起着重要作用。
