- 4695
- 4545 小时
- 2023-8-13
- 100
- 1
- 219675
- 4511
- 1
- 4695 点
- 4385 ¥
- 2010-7-13
FEATURES
Excellent Sonic Characteristics
Low Noise: 6 nV/?Hz
Low Distortion: 0.0006%
High Slew Rate: 22 V/?s
Wide Bandwidth: 9 MHz
Low Supply Current: 5 mA
Low Offset Voltage: 1 mV
Low Offset Current: 2 nA
Unity Gain Stable
SOIC-8 Package
PDIP-8 Package
APPLICATIONS
High Performance Audio
Active Filters
Fast Amplifiers
Integrators
APPLICATION HIGHLIGHTS
1. Performance is fully specified for operation using ±5 V to
±15 V supplies.
2. A 0.04% differential gain and 0.19° differential phase error at
the 4.4 MHz color subcarrier frequency, together with its low
cost, make it ideal for many video applications.
3. The AD827 can drive unlimited capacitive loads, while its
30 mA output current allows 50 W and 75 W reverseterminated
loads to be driven.
4. The AD827’s 50 MHz unity-gain bandwidth makes it an
ideal candidate for multistage active filters.
5. The AD827 is available in 8-pin plastic mini-DIP and cerdip,
20-pin LCC, and 16-pin SOIC packages. Chips and MILSTD-
883B processing are also available.
多看点资料少一点自以为是 |
