- 1243
- 992 小时
- 2024-5-1
- 70
- 849380
- 1224
- 1243 点
- 1213 ¥
- 2018-6-1
如果一切顺利的话就可以测试了,先把你的功放上接些乱七八糟的喇叭,听个响
# Double-check!
aplay -l && arecord -l
**** List of PLAYBACK Hardware Devices ****
card 1: Set [C-Media USB Headphone Set], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
# Play white noise on 2-channels (L/R) on Card-1
speaker-test -c2 -D hw:1,0
# Play a WAV sound file
speaker-test -c2 -D hw:1,0 --test=wav -w /usr/share/sounds/alsa/Front_Center.wav
# Once the correct default card+device is set, and after reboot,
# then full left/right voice test (above) is performed, just by:
speaker-test -c2 -twav
# Record some sounds (with a VU bar):
arecord --device=hw:1,0 --format S16_LE --rate 44100 -c1 -V mono test.wav
# Play recorded sounds
aplay -D plughw:1,0 test.wav
# Play recorded sounds (sample rate have to be equal)
speaker-test -c2 -D plughw:1,0 -r 44100 --test=wav -W $HOME -w test.wav
