- 1232
- 981 小时
- 2024-4-17
- 70
- 849380
- 1213
- 1232 点
- 1202 ¥
- 2018-6-1
其实一切都是可以的,原文是这样的:
It's a VST-compatible host that's capable of:
bullet loading VST effects (aka "plugins")
bullet parameterizing / editing them
bullet sound output for VSTis
bullet MIDI-input and -output
bullet loading / saving .fxb / .fxp files
bullet I/O through either Windows MME or ASIO drivers
bullet Wave Player / Recorder
bullet MIDI Player
While the program started mainly as an aid in understanding and debugging VST plugins, it has evolved into a quite capable program by now which can be really helpful in a keyboard artist's Live setup.
所有的格式都是支持的,其实并不真的需要ASIO4ALL,我现在就没有用,我的XONAR U7本身就支持ASIO
为什么还要去虚拟呢,当然在没有ASIO的情况下,我试过好像只能44.1KHz,这个没有仔细研究,但虚拟电缆不是必须的,这个可以肯定,我用XONAR u7完美地实现了PC分频 |
