JLH1969 MOSFET Class A/AB amp
[复制链接] 查看: 159749|回复: 433
1510 点
1301 ¥
发表于 2008-5-13 21:01 | 显示全部楼层
39K电阻是负责PSrr的
输入也可改成差分对 胆hood老头说影响音质
网上都能google到
1191 点
929 ¥
社区贡献 新人进步
发表于 2008-5-13 21:02 | 显示全部楼层
我最后装机用了crc滤波。开关电源是试验元件搭电路用的,都没有干扰。
2912 点
975 ¥
发表于 2008-5-13 22:26 | 显示全部楼层
原帖由 drb888 于 2008-5-13 13:54 发表
谢谢millwood 老师!
DarkHorse大侠,请问你作的“基于ALEX的JLH-MOS上修改来的电路”实验结果如何?
结果是好的,但被我的3"SONY单元给扼杀啦!弄得我在好长时间以为这电路的低音不好...
当时我还做了ZEN-V2,那低频段提升太足,而SONY喇叭仔的低频衰减又很厉害,所以ZEN2与SONY仔搭配还比较可以.
ALEX的电路我没有做不敢乱说,但我改的那款是解释力高的表现,而且很甜,但没有什么感情,少了些深度吧!
不建议你做我改的那款,图纸仅供参考就好啦!
5672 点
5633 ¥
发表于 2008-5-14 07:28 | 显示全部楼层
回复 #44 millwood 的帖子
我来翻译此贴
quite a few people have asked that what simulator I was using.
it is switchCAD, by Linear. it is freely downloadable at Linear.com (http://www.linear.com/designtools/software/switchercad.jsp). click on "No thanks ...".
save it and then do an install.
very simple, and effective. However, it doesn't have a lot of devices (other than Linear's products) but good enough for most of our work.
I will upload the jlh1969 mosfet simulation file tomorrow for everyone to play with
相当多的人问我使用什么仿真器。
这是 switch CAD,来源于网站 Linear。在Linear.com它可以免费下载。
(http://www.linear.com/designtools/software/switchercad.jsp)。在"No thanks ..."上单击。
保存它然后安装。
非常简单和有效。可是,它没有许多器件(除了Linear’s产品)然而足以应付我们大多数工作。
我将在明天上载jlh 1969 mosfet 仿真文件与大家一起讨论。
译者注:这是LT(Linear Technology)的网站,下面是从该网站转过来的一段关于下载“SwitcherCAD”的说明,注册后就可以升级,如只想使用免费的,不需要注册,就点击“No thanks, just download the software”就可以下载,很快的,我已经下载。
Before You Download, Register for SwitcherCAD Updates
SwitcherCAD/LTspice is updated with new features, performance enhancements and device models on a regular basis. To receive email notification whenever a new SwitcherCAD version is released, just register as a Linear Insider today. In addition to SwitcherCAD news and updates, you'll receive notification of new product releases, the latest technical documents and more.
Register for a new MyLinear account.
Your download will begin immediately upon completion of the registration.
No thanks, just download the software.
该网站也有中文界面。有一个免费下载SwitcherCAD软件的窗口。
2857 点
2785 ¥
 楼主| 发表于 2008-5-14 09:45 | 显示全部楼层
原帖由 ch639827608 于 2008-5-13 14:24 发表
1 low slew rate, less then 1v/us
given the current feedback topology, I would be surprised if the slew rate is that low.
when the mosfet version was introduced, someone actually tested it and showed a slew rate in excess of 25v/us.
2 low PSRR
part of that is mitigated by the input biasing. But the output stage is open to supply ripples. simulation shows very little get passed out to the output, due to the amp being fast and the feedback used.
3 high THD,about 2% at full scale output
yes, this amp isn't a low THD design (but certainly less than 1% in my experience) but it sounds great. kind of like Pass designs.
4 low efficiency
the BJT version is class A so that doesn't help. the mosfet version can work in class A or class B. In Class B, it should be quite efficient.
However, the MOSFET version loses a few voltage vs. the BJT version in terms of maximum output voltage swing, this causes the maximum output power to suffer.
91
3809 点
2210 ¥
发表于 2008-5-14 11:16 | 显示全部楼层
原帖由 DarkHorse 于 2008-5-13 22:26 发表
ALEX的电路我 ...
DarkHorse:最近好像大作比较少,很忙吗?
一直很希望有适合IRFP250这种结电容大的管子的电路,因为毕竟功率大,而且管子易得。您手上有没好点的0DB的放大电路?(适合像irfp250这样的)。
millwood 是高手,但英文看起来确实比较辛苦一点。
5672 点
5633 ¥
发表于 2008-5-14 11:19 | 显示全部楼层
回复 #325 millwood 的帖子
QUOTE "given the current feedback topology, I would be surprised if the slew rate
is that low.
when the mosfet version was introduced, someone actually tested it and showed a slew rate in excess of 25v/us."
These are I translate the <iflying>#18 speak into chinese,not my experience.
Thank you
5672 点
5633 ¥
发表于 2008-5-14 11:54 | 显示全部楼层
Hi,millwood
Excuse me
I have additional question that it is have any JFET or MOSFET to replace the IRFP240 & IRFP9240?
Thank You
56
2305 点
607 ¥
发表于 2008-5-14 12:25 | 显示全部楼层
ALEX的电路我 ...
谢谢!我已准备了K851上M兄的电路,只等我的F2前级调好,网购的其他元件到位就上马
144 点
144 ¥
发表于 2008-5-14 16:39 | 显示全部楼层
http://www.inputking.com/
这是一个网页上的web输入法,不用安装就可以用来打中文了。在英文系统上也可以用。
请老大试用一下吧。看英语实在看不下去了。
144 点
144 ¥
发表于 2008-5-14 16:44 | 显示全部楼层
  InputKing在线中文输入系统是一基于浏览器的中文输入平台。它的功能是:使全球无数台联网计算机,在不安装任何中文输入软件的情况下,能即时用多种输入法输入简体和繁体中文。由于该系统较好地解决了未安装中文输入软件计算机的中文输入问题,加之其方便的在线查询英汉词典、汉英词典、汉语字典和汉字读音编码字典的功能,因此它的诞生,为在国外学习、工作和旅游的华人、使用特殊计算机系统的人士、以及学习中文的外国朋友带来了许多便利。
  目前该系统可在全球绝大多数联网计算机上使用。InputKing.com所提供的这项网上服务是免费的。
  如果您关于该系统有什么问题或建议,请与我们联系。我们也希望您把InputKing在线中文输入系统推荐给您的亲朋好友(包括网友),尤其是那些出国留学或移民国外的亲友。愿越来越多的人了解它,从而无论走到天涯海角,无论身处世界的任何角落,都能够在网上用中文表达思想、与亲友沟通。
  愿InputKing能成为大家的好助手。
2857 点
2785 ¥
 楼主| 发表于 2008-5-14 20:46 | 显示全部楼层
原帖由 ch639827608 于 2008-5-14 11:54 发表
Thank You
you want to replace the irfp240 / irfp9240 with jfet or mosfet?
first of all, the design is on n-channel mosfets (irfp240 or the likes). so if you want to use irfp9240, you will need to change the topology - npn transistor upfront, and pnp transistor as the phase splitter. that's doable but is a separate question.
using other n-channel mosfets as output devices is entirely doable. I have tried many and the only ones that didn't work out is fdp3682 - a Fairchild "switching" mosfet. I just couldn't get it thermally stable.
I have never tried power jfets. however, Nelson used some power jfets in zv8 and that was a fairly successful design. so I have no reason to believe that a power jfet wouldn't work here.
2912 点
975 ¥
发表于 2008-5-14 21:04 | 显示全部楼层
原帖由 j10 于 2008-5-14 11:16 发表
millwood 是高手, ...
对呀,近大半年来忙着房子装修,入住,老婆生子等人生大事,所以没有多少时间玩DIY!
但晚上都有听一俩个小时的歌曲...
你想做0DB的功放么,我也有这打算,电压放大用胆管,输出用MOSFET,比较好声的是K1058/J162,30~50W输出没有问题...以后有时间一定要试一试!
IRFP240/9240就是很不错的N沟/P沟管,作为互补输出也不错的.
在这胆结石之前,我还会先做出一台6P14单端机,应该这一俩个月内可以完成的...哈哈
5672 点
5633 ¥
发表于 2008-5-15 07:45 | 显示全部楼层
回复 #332 millwood 的帖子
QUOTE :"you want to replace the irfp240 / irfp9240 with jfet or mosfet?"
First of all ,thank you
It is because I looking for irfp240 and irfp9240 for a long time not found but irfp240,as a matter of fact I don't like to change them.
Recently,still in search of them for places I knew.
91
3809 点
2210 ¥
发表于 2008-5-15 09:07 | 显示全部楼层
原帖由 DarkHorse 于 2008-5-14 21:04 发表
但晚上都有听一俩个小时的歌曲...
你想做0DB的功放么,我也有这打算,电压放大用胆管,输出用MOSFET,比较好声的是K1058/J162, ...
噢,在忙人生大事啊!装修完一定要开窗,最好放半年才住。有孩子的话东西不能乱放,焊接完至少洗两遍手(俺先用洗洁精,再上去污粉仔细搓)。
前一段在外面听一个台产的6P14小功放声音比较柔和,400多块。但不知道这管以后好买吗?
5672 点
5633 ¥
发表于 2008-5-15 09:20 | 显示全部楼层
回复 #331 k1000j1000 的帖子
是不错的平台,据我所知,也很多旅外人士在用,我也试用过,很可以的。我也曾推荐给我在加州的几位同学用,他/她说用起来很慢,和打英文的速度比起来相差很远,不想用。
我在旅美时在英文版本的操作系统上也使用这中文输入法,但和拼音加加等相比,的确太慢了。
2912 点
975 ¥
发表于 2008-5-15 19:33 | 显示全部楼层
原帖由 j10 于 2008-5-15 09:07 发表
前一段在外面听一个台产的6P14小功放声音比较柔和,400多块。但 ...
400多的6P14台湾产的,不大可能吧,二手机么?
6P14很好买,二手及新的都有...建议还是自己做,牛当然叫专业厂定做啦,我只是想知道胆单端的味道,会不会适合我罢了...
91
3809 点
2210 ¥
发表于 2008-5-15 21:10 | 显示全部楼层
听老板说是库存。自己做估计这价下不来。声音来讲比较柔和好听。但据介绍有点挑音箱。
此外,楼上各位对场管有研究的帮看下这图http://bbs.hifidiy.net/viewthrea ... &extra=page%3D1
66 点
86 ¥
发表于 2008-5-28 14:33 | 显示全部楼层
大家第二级管子的工作电流是多少?为什么我做的电路第二级用C1815时不用消振电容也不会自激
如果换成D669却必须加此电容。是因为C1815的FT底的缘故吗?
1191 点
929 ¥
社区贡献 新人进步
发表于 2008-5-28 14:38 | 显示全部楼层
第二级管子的静态电流大约是10到20ma。我也加了防自激的小电容。用的20pf。如果不加,就会出现自激产生“沙沙”声。用过669和2383.
GMT+8, 2026-4-6 08:03 , Processed in 0.159611 second(s), 7 queries , Gzip On, Redis On.
