- 1072
- 5068 小时
- 2013-7-19
- 70
- 37180
- 1221
- 1072 点
- 1056 ¥
- 2008-3-12
S312 是8欧 的.
S312II - Black
Description 3-Way, 12-Inch Floorstanding Speaker
Series Studio
Finish Black
Crossover Frequencies 750Hz, 3000Hz
Frequency Response 35Hz – 20kHz (±3dB)
Max. Recommended Amplifier Power 250 Watts
Sensitivity (2.83V/1m) 92dB
Nominal Impedance 8 Ohms
Dimensions (H x W x D) 41" x 14-3/4" x 12-1/4" / 1041mm x 375mm x 311mm
Weight 35kg / 77 lb |
