309 点
277 ¥
发表于 2011-9-4 15:38 | 显示全部楼层
bucuo
309 点
277 ¥
发表于 2011-9-5 07:23 | 显示全部楼层
绝对好贴,收藏了。
1336 点
1322 ¥
发表于 2011-9-27 21:04 | 显示全部楼层
世霸就是漂亮,雨后看着寒碜多了
43 点
43 ¥
发表于 2011-9-27 21:19 | 显示全部楼层
顶   好给力的音箱  不知道声音啥样
158
839 点
721 ¥
发表于 2011-9-28 18:38 | 显示全部楼层
经典之中的经典:世霸小明琴
所用的单元描述:
老版的单元:Mid-bass driver used in Guarneri Homage is a 150mm high-resolution unit from Audio Technology (formerly Skanning) with short coil, long air gap and vented back. It is important to point out that the main driver was from Audio Technology, not from Scan Speak as mistakenly wrote Michael Fremer in Stereophile review of Guarneri Memento in August 2007.
新版的小明琴:Mid-bass driver used in Guarneri Memento is a 150 mm ultra dynamic linearity driver from Audio Technology, with CCAW/Kapton eddy current free voice coil. According to Sonus Faber it is dynamically linear magnetic field motor incorporating Kellog and Faraday rings with all moving elements ventilated for resonance free response.
电参数
老版:In case of Guarneri Homage the multi-strand oxygen free copper wires were used as an internal wiring. The crossover was the first order unit with 6dB slope and crossing point at 2.5    kHz. Nominal impedance is 8 ohms. Sensitivity: 88 dB. Frequency response: 46Hz-20kHz.
新版:The crossover used in Memento is also the first order unit with 6dB slope and crossing point at 2.5 kHz. Nominal impedance is 4 ohms. Sensitivity: 88 dB. Frequency response: 39Hz – 30kHz.
两款小明琴的声音对比
As a Guarneri Memento owner, I am really surprised how good the old Guarneri Homage are. If I have had the opportunity to directly compare both speaker before purchase the choice would be very hard.
老版:for my ears old Guarneri have better midrange and better top-end than new ones. I am especially impressed by treble performance of the Homage. Trebles were more airy, with more sparkle and timbre. Midrange was more sophisticated and subtle than with Mementos. Also whole presentation was more liquid and homogenous.
. . I also found that transparency and clarity of Homage was better compared to Memento. There was also a little more harmonic texture and decay of notes seemed to stay a bit longer and could be heard more clearly.
新版:Memento in direct comparison in no slouch either. Overall tonal balance is shifted toward low end and the bass performance is much improved compared to the old Guarneri. Memento is also more dynamic speaker. I would describe them as a fuller, full bodied and more complete speaker than Homage and thus they easier may be considered as a contender for floorstanding speakers. Also I think that Memento is more universal speaker, but in my opinion it was not possible to maintain the homogenous and quality of trebles from old Guarneri
246 点
237 ¥
发表于 2011-9-30 11:50 | 显示全部楼层
这个太养眼了
158
839 点
721 ¥
发表于 2011-9-30 21:49 | 显示全部楼层
在世霸的各种系列中,最能代表世霸声音的“透明、純淨、細膩、嬌媚、鮮活特征”只有HOMAGE 系列。
在HOMAGE 系列中,现排除其他纪念意义另外演变的系列外,最正统的有三款, GUARNERI MEMENTO , AMATI ANIVERSARIO , STRADIVARI HOMAGE .
对于这三款单元,其中音单元确实一致性的选择了一个品牌AT。細膩音色,通透音场乃是HOMAGE 的最大魅力。在对STRADIVARI HOMAGE的评价中,一致的结论是中音单元是其灵魂,承担了300-4000Hz的主要频段。(150mm) transducer was chosen for its extremely high dynamic linearity and many other qualities traditional to Sonus faber. The midrange spectrum is in fact the “soul” of the Stradivari system. (三音路、四單體低音反射式落地喇叭,使用33mm Scanspeak 「Ring Radiator」雙振膜釹磁鐵高音單體、150mm Audio Technology中音單體、260mm SEAS低音單體×2,頻率響應22Hz-40kHz,分頻點300Hz、4kHz,平均阻抗4Ω,靈敏度92dB)。反映了SONUSFANER 的校声准则。
1789 点
1705 ¥
发表于 2011-10-1 09:36 | 显示全部楼层
不听也养眼
127
【中 国 免 检 玩 家】
280 点
304 ¥
发表于 2011-10-3 00:37 | 显示全部楼层
本坛大侠的高仿
ntlywxb 发表于 2011-4-2 16:17
    这个好啊~!!!
127
【中 国 免 检 玩 家】
280 点
304 ¥
发表于 2011-10-3 00:38 | 显示全部楼层
高音好漂亮啊~!!
3 点
1 ¥
发表于 2016-7-26 18:08 | 显示全部楼层
哪位兄弟分享一下世霸大情人的分频器?
158
839 点
721 ¥
发表于 2016-8-2 21:46 | 显示全部楼层
VINCI 要的图贴上来
50 点
48 ¥
发表于 2016-8-2 22:56 | 显示全部楼层
50 点
48 ¥
63 点
40 ¥
发表于 2016-8-3 09:46 | 显示全部楼层
感谢分享~~~~~~~~~~
106 点
98 ¥
发表于 2016-8-3 10:37 | 显示全部楼层
看着就舒服
1215 点
1169 ¥
发表于 2024-7-30 17:43 | 显示全部楼层
这个旧帖不错
182 点
160 ¥
发表于 2024-8-14 14:27 | 显示全部楼层
GMT+8, 2026-5-26 19:13 , Processed in 0.168280 second(s), 21 queries , Gzip On, Redis On.
