1103 点
1102 ¥
 楼主| 发表于 2011-10-14 23:47 | 显示全部楼层
1336 点
1322 ¥
发表于 2011-10-15 09:06 | 显示全部楼层
箱体很重要的,不能省,前板一定要超过40MM,够笨够厚
128
3799 点
3381 ¥
发表于 2011-10-15 15:43 | 显示全部楼层
好像TG有了新设计,楼主可以参考下
876 点
759 ¥
发表于 2011-10-15 16:20 | 显示全部楼层
回复 163# lakerblue
    楼主的箱子已经在海浪那里制作中了
678 点
675 ¥
发表于 2011-10-15 16:29 | 显示全部楼层
回复 163# lakerblue
    超版来个链接看看
1103 点
1102 ¥
 楼主| 发表于 2011-10-15 16:45 | 显示全部楼层
3799 点
3381 ¥
发表于 2011-10-15 17:57 | 显示全部楼层
回复  lakerblue
    超版来个链接看看
微笑1058 发表于 2011-10-15 16:29
    你的女儿很CUTE啊
http://www.troelsgravesen.dk/Jenzen-NEXT.htm
453 点
249 ¥
发表于 2011-10-15 18:25 | 显示全部楼层
回复 167# lakerblue
L版請問用6.5寸做中音有甚麼優勢?原5寸專職中音指向性方面不是更好嗎?
1336 点
1322 ¥
发表于 2011-10-15 18:32 | 显示全部楼层
好像TG有了新设计,楼主可以参考下
lakerblue 发表于 2011-10-15 15:43
刚好俺有两对0042,就是没这高音,只有0036和0006
128
3799 点
3381 ¥
发表于 2011-10-15 18:38 | 显示全部楼层
回复  lakerblue
trust1ym 发表于 2011-10-15 18:25
    嗯,这个箱子是TG的设计,他针对这个问题有过解释:
So, even 3-4" drivers can cope with a 300 Hz point of crossover and we do see middomes taken this low. Does it sound natural? I case you have an electronic crossover, preferably 24 dB/octave, try make a 320-1280 Hz midband and play voices on a 4", a 5" and a 6" driver. Add a coil to the drivers in order to make the response reasonably linear. All drivers on suitable baffles. Try adjust to the same loudness from the drivers and listen to voices. Quite some difference. Remarkably different. I've always found 6" drivers to give the best lower midrange. It adds a low-end weight to vocals that smaller drivers cannot do. However, depending on the woofer below and the chosen slope of the crossover you can make a perfect blend of sounds. If you can get away with a 2nd order filter the results may be very good indeed. With higher order filters you start depending very much on the actual performance of the driver itself and there's no "help from your friends" here. I've heard excellent vocal performance from a 6" midrange driver taken down to 150 Hz with - presumably - 4th order filters (Von Schweikert VR4 mkIII).
678 点
675 ¥
发表于 2011-10-15 18:46 | 显示全部楼层
你的女儿很CUTE啊
lakerblue 发表于 2011-10-15 17:57
    谢谢超版的夸奖
453 点
249 ¥
发表于 2011-10-15 19:28 | 显示全部楼层
回复 169# 飘逸仙子
0046呢?有沒?我也在困擾中上不上3分頻,始終技術未達標。
你的女儿很CUTE啊~
1336 点
1322 ¥
发表于 2011-10-15 19:37 | 显示全部楼层
回复  飘逸仙子
你的女儿很CUTE啊~
trust1ym 发表于 2011-10-15 19:28
我还以为是两只0042呢,仔细一看,下面的比上面的大些。哎……
看来我顶多搞个2。5分频的箱了,不折腾了,一动又得请人设计
1103 点
1102 ¥
 楼主| 发表于 2011-10-15 20:07 | 显示全部楼层
1336 点
1322 ¥
发表于 2011-10-15 20:51 | 显示全部楼层
正折腾测量件中,不知撒时能精通
60 点
60 ¥
发表于 2011-10-16 01:38 | 显示全部楼层
154 点
154 ¥
发表于 2011-10-17 11:10 | 显示全部楼层
支持一下!看帖要有毅力!LZ還需努力!
342 点
335 ¥
发表于 2011-10-24 16:36 | 显示全部楼层
恭喜成功,期待最终版本
342 点
335 ¥
发表于 2011-10-24 16:48 | 显示全部楼层
[quote]今早开声,声音很好,所以打算在海浪那里作对好的箱体。
用什么功放推的?看看能不能学学
257 点
243 ¥
发表于 2011-10-24 16:58 | 显示全部楼层
给楼主加油!!
希望不要象老方一样烂尾.
老方烂尾的首要原因是因为箱体造型和结构搞坏了.
没见过楼主的箱体新造型.
想请问楼主为何原用的分体式箱体"部分失败"?
说说也好让我等参考啊.
GMT+8, 2026-4-8 11:15 , Processed in 0.143042 second(s), 9 queries , Gzip On, Redis On.
