[其他] 介绍一篇有关接地的好文章
[复制链接] 查看: 3690|回复: 7
5672 点
5633 ¥
发表于 2010-6-8 18:11 | 显示全部楼层
在diyaudio.com有一篇有关接地的好文章,值得一读
Audio Component Grounding and Interconnection
David Davenport, 21st April 2010
链接http://www.diyaudio.com/forums/d ... nterconnection.html
52 点
152 ¥
发表于 2010-6-8 18:12 | 显示全部楼层
2780 点
2729 ¥
发表于 2010-6-8 18:17 | 显示全部楼层
wa哇WA 洋码字来的,呵呵 不过 可以用网页翻译来看下大概。
HIFI之王
608 点
628 ¥
发表于 2010-6-8 18:59 | 显示全部楼层
HIFI之王
608 点
628 ¥
发表于 2010-6-8 19:00 | 显示全部楼层
104
黔驴技穷
4863 点
3578 ¥
发表于 2010-6-8 20:53 | 显示全部楼层
骗我看天书?惭愧!不懂。
5672 点
5633 ¥
 楼主| 发表于 2010-6-9 15:43 | 显示全部楼层
This article focuses on audio system design for the DIY enthusiast implementing a stereo system for home use. There is a lot of information available for designing audio circuits, but precious little on interconnecting those circuits into a total audio system to achieve maximum performance. Interconnecting circuits to create an audio system involves connecting signals and grounds , both within a single component as well as between components. This article has the most benefit for the person constructing his or her own equipment, rather than merely interconnecting finished components. Although much of the information presented is applicable for professional installations, those installations face a myriad of problems due to physical size, number of components and different types of components, which are not addresses here.
Although I use electron tube circuits for many examples in this article, the concepts presented are valid for solid state circuits as well. Most, if not all digital circuits will use integrated circuits and I cover interconnecting digital electronics with analog electronics.
中译文:
音频组件接地和互相连接David Davenport,21st April 2010
这文章的目的是为DIY发烧友构建立体声家用音频系统提供设计的参考。音频线路设计有大量的参考资料,而将这些电路互相连接为一个整体音响系统如何获得最佳的操作性能方面的资料却少得可怜。互相连接线路形成音频系统包括信号连接和地线连接,这两种连接不论在单个组件和组件间都一样。
这文章对于构建他/她自己的设备比仅仅在成品组件间连接的人有更多的好处。虽然大多数资料是用于安装专业设备的,这些安装涉及的由于几何尺寸、组件数量和不同的组件类型而导致的大量的问题,在这里不加于论述。
虽然这文章里我是使用真空管线路作为例子,其原理对于晶体管线路也适用,如果不是都是数字电路用来构成一整体电路则我是将数字电路和模拟电路互相连接。
3090 点
3036 ¥
发表于 2010-6-9 15:57 | 显示全部楼层
我看完了,本来想顺便翻译一下,但发现太折磨人了。
