[DIY制作] 也试试顶级炮Klipsch P-312W
[复制链接] 查看: 28255|回复: 81
27 点
29 ¥
发表于 2010-6-9 10:50 | 显示全部楼层
世界上1000 W 的 民用炮就那么几个,这是另一个不差于 312 的炮, REVEL 30 SUBWOOF, 130斤的恐怖体重,15寸炮,通电最低耗费功率750W以上。
我所疑惑的 是查了 B15 的参数怎么跟 B30 都一样呢,而我还没看见有B30 的用家。。。
REVEL     30
回复 引用 编辑 TOP
baldwin 发短消息
加为好友
baldwin 当前在线
精华0 阅读权限10 在线时间84 小时 最后登录2010-6-9
新手上路 当前在线
UID83894 帖子68 积分15 威望0 点 贡献值0 点 注册时间2009-2-27  78#
发表于 2010-6-9 10:20 | 只看该作者 | 发短消息 SUBWOOFER
Low Frequency Extension: -3 dB @ 18 Hz (up to full-rated power)
Frequency Response: 20 Hz to fc ±0.5 dB, - 3 dB @ 18 Hz
True Linear Volume
Displacement: 275 in3
Weight (with amplifier): 145 lb (66.8 kg) net, including carton.
Overall Dimensions: 231⁄ 4"H x 20" W x 23 3⁄ 4"D
591 mm H x 508 mm W x 603 mmD
(with grille and feet; see Figure 15 below)
AMPLIFIER
Output Power: At least 1,000 Wrms , 1,400 Wpeak
EQ ALL Control: Engages all three parametric equalizers,
or bypasses them
CONTOUR Control: Selects Film, Music, or External Trigger EQ mode
Equalization –
Type: Three independent parametric equalizers
Frequency: Continuously variable from 18 to 80 Hz
Continued on the next page...
REVEL ULTIMA SUB 30
Owner’s Manual
20"
(508 mm)
23-1⁄4"
(591 mm)
17-7⁄ 8"
(454 mm)
20-7⁄8"
(530 mm)
20-1⁄ 2"
(521 mm)
23-3⁄4"
(603 mm)
2-3⁄ 16"
(56 mm)
SPECIFICATIONS
AMPLIFIER (Continued)
Equalization (Continued) –
Bandwidth: Continuously variable from 0.1 to 1.0 Octave
Level: Continuously variable from -14 to+6 dB
Low-Pass Filter –
Type: Low pass with ON/OFF switch
Slope: Selectable 24 or 48 dB per octave
Frequency: Selectable at 30, 40, 50, 60, 70, or 80 Hz
Phase: Continuously variable from 0 to 180°
High-Pass Filter –
Type: High pass, always on
Slope: Selectable 12 or 24 dB per octave
Frequencies: Selectable at 30, 40, 50, 60, 70, or 80 Hz
27 点
29 ¥
发表于 2010-6-25 21:21 | 显示全部楼层
怎么没人关注 这个炮呢。。昨天还有个朋友跟我说,这个功放不错,单元也就一般。
27 点
29 ¥
发表于 2010-7-15 13:46 | 显示全部楼层
hahahah,,,,,,,   有新的 炮箱了骂???
267 点
267 ¥
发表于 2010-7-15 15:38 | 显示全部楼层
功放板哪里搞的?厂机啊!
45 点
45 ¥
发表于 2010-7-16 00:46 | 显示全部楼层
255 点
255 ¥
发表于 2010-7-16 10:37 | 显示全部楼层
到位啊
1330 点
1245 ¥
发表于 2010-10-23 18:29 | 显示全部楼层
广西发烧友真的有福气,好低音炮!
876 点
759 ¥
 楼主| 发表于 2010-10-23 18:35 | 显示全部楼层
把南宁几个用户召集过来,就可以玩6只低音炮了
佑佑说~
410 点
403 ¥
发表于 2010-10-24 02:01 | 显示全部楼层
用音浪按摩~~~
283 点
283 ¥
发表于 2011-2-11 10:15 | 显示全部楼层
口水呀
好炮
3 点
203 ¥
发表于 2011-2-11 14:23 | 显示全部楼层
好炮
578
喇叭控
9612 点
6785 ¥
发表于 2011-2-11 19:20 | 显示全部楼层
CVBG 发表于 2010-10-23 18:35
南宁的变态真多,哈哈
305 点
304 ¥
发表于 2011-2-11 19:59 | 显示全部楼层
南宁烧友要说变态属乌鸦第一。。。
302
2967 点
2847 ¥
发表于 2011-2-11 23:42 | 显示全部楼层
的确是很强悍的炮。
1255 点
1350 ¥
发表于 2011-2-12 10:23 | 显示全部楼层
876 点
759 ¥
 楼主| 发表于 2011-2-12 12:20 | 显示全部楼层
补几张新的图片
876 点
759 ¥
 楼主| 发表于 2011-2-12 12:50 | 显示全部楼层
P-312W斜率有18dB /Octave、24 dB /Octave、36 dB /Octave、48 dB /Octave四个选项,在我的环境里选择此项比较理想,和各个声道完美结合、声底干净有力、层次丰富.....
181 点
179 ¥
发表于 2011-11-22 16:39 | 显示全部楼层
好炮,有人出不?有意收。
150 点
150 ¥
发表于 2012-2-6 15:05 | 显示全部楼层
78
cokecole
1401 点
1352 ¥
发表于 2012-2-6 18:29 | 显示全部楼层
回复 52# 乌鸦
    好点d类跑放有吗,mk250用
GMT+8, 2026-4-8 05:41 , Processed in 0.113357 second(s), 9 queries , Gzip On, Redis On.
