157
4422 点
4197 ¥
发表于 2010-1-22 20:33 | 显示全部楼层
胜利的很不错,我就买的 胜利 的表,很耐用
96
2613 点
1863 ¥
发表于 2010-1-22 20:47 | 显示全部楼层
胜利吧,
1098 点
1092 ¥
发表于 2010-1-23 10:22 | 显示全部楼层
1196815
Lafeite 发表于 2010-1-22 20:28
请问Lafeite老大怎么个用法?能提供个教程吗???
2516 点
1944 ¥
优秀版主 优秀设计 论坛版主
发表于 2010-1-23 18:30 | 显示全部楼层
用论坛套件,切换到阻抗测量状态,用一个已知电阻校准一下就可以用了。总共就两个按钮,一个校准,一个测量。没必要写教程吧?
2516 点
1944 ¥
优秀版主 优秀设计 论坛版主
发表于 2010-1-23 18:35 | 显示全部楼层
一般来说,电声测量系统都具备LCR测量功能。
今天看了一下Speaker Workshop这个很不起眼的免费软件,同样有LCR测量功能。可能就是因为它是免费的才容易被冷落,其实Speaker Workshop是很好的软件,精度很高。
2516 点
1944 ¥
优秀版主 优秀设计 论坛版主
发表于 2010-1-23 18:37 | 显示全部楼层
下面是Speaker Workshop的相关帮助部分
How to Measure a Component
Speaker Workshop has provisions for measuring passive components.  These are resistors, inductors, and capacitors. Best results are obtained if the component impedance is approximately 10 ohms (or your reference resistor) somewhere in the 200Hz to 5KHz audio range.
In order to measure a component, you must first create a signal (for stupid historical reasons). Then just execute the Measure Passive Component command.
Step by Step
1. Create a signal
Create a new signal (Resource New Signal) or use an existing signal. Bring the window to top if the signal exists. This will add a Measure menu to the menubar.
2. Hook the component into your impedance jig
Connect the component carefully to the impedance jig. If the component抯 impedance is high (for example a small capacitor) use a large reference resistor. Otherwise, just use the standard 10 ohm reference resistor.
3. Check settings
Select the Option Preferences command and check the impedance and measurements tabs.  The impedance tab should have correct data for the impedance jig. The measurements tab should be set for a sample size of perhaps 8K or 16K  and a sample rate to get the component impedance near 10 ohms at perhaps ?or ?the sample rate. Resistors seem to test best at a sample rate of 44KHz.
4. Execute the Measure Passive Component command
Just select the measure menu and the passive component command within that menu.  This will send an MLS signal through the component.  The input is then analyzed and a best fit is found for the component value.The component type and value will be displayed in a dialog.
137 点
86 ¥
发表于 2010-1-23 20:28 | 显示全部楼层
292 点
98 ¥
发表于 2010-1-23 22:36 | 显示全部楼层
支持,21;22楼。
初烧此表足够。
87
1967 点
1955 ¥
 楼主| 发表于 2010-1-23 22:40 | 显示全部楼层
朋友这款表精度不是太好!尤其是大电容挡!
flscs1 发表于 2010-1-22 19:24
LC9243据说是电桥电路啊,怎么会精度不好。。。大电容,好像没几个表能测得准的吧
292 点
98 ¥
发表于 2010-1-23 23:12 | 显示全部楼层
补上图。五六年以上了,在沈阳购得,当时好像在三百多米。
284
8239 点
2519 ¥
发表于 2010-1-29 16:45 | 显示全部楼层
我用安捷伦的手持LCR数字电桥,U1732A
87
1967 点
1955 ¥
 楼主| 发表于 2010-1-29 16:59 | 显示全部楼层
已购入LC9243,感觉很不错。
禁言警告级 当前离线
小陈
Rank: 1
-3 点
77 ¥
发表于 2010-1-31 10:02 | 显示全部楼层
胜利的
349 点
343 ¥
发表于 2010-2-1 10:01 | 显示全部楼层
390 点
380 ¥
发表于 2010-2-1 20:20 | 显示全部楼层
推荐款白菜价的山创A6243L电容电感表淘宝价60元。我买了架测试精确度不错。
cenyuxun 发表于 2010-1-22 02:04
我有一个,测电容的误差是50%.电感因为没有别的表对比不知道准不.
390 点
380 ¥
发表于 2010-2-1 20:21 | 显示全部楼层
估计是坏了,不过我也没有用过多少次
1190 点
1214 ¥
发表于 2010-2-7 10:22 | 显示全部楼层
同惠的 手持电桥  TH2812A
159
胆石一家本无争
12744 点
11651 ¥
发表于 2010-2-24 11:55 | 显示全部楼层
呵呵! 兄弟们好 ! Lafeite 版主 列出的软件 有 L-C-R 测量功能呀 !既然爱上了这个嗜好, 乖乖的上测量仪吧 ! 把 买表的钱 省下 !
菜鸟
1646 点
1269 ¥
荣誉会员
发表于 2010-2-25 01:26 | 显示全部楼层
软件能测量了?好事啊。
2516 点
1944 ¥
优秀版主 优秀设计 论坛版主
发表于 2010-2-25 04:30 | 显示全部楼层
软件能测阻抗当然也应该能测量LCR。标准的虚拟仪器,可以像真实的LC表一样使用,这对于没有LC表的人很有意义,完全能把买表的钱省下来。
我们来这样看问题,真实的LC表精度由几个方面决定:级别、元件精度和出厂校准水平。好表元件实际精度最高也就0.1%,这个精度一旦固定,这个表也就这样了,你无法改变什么。再一个是出厂校准,这看工厂基准源水平。事实上我们很容易承受的低价表几乎都是降级产品和山寨货,前面提到的问题都会降级。
那么测量套件加软件会得到什么样的精度?理论上会比真实的LC表好的多。因为虚拟仪器的精度与实体元件精度无关,一切由软件校准,修正。当然,这就出现一个初始基准元件问题,可喜的是我们所用的套件校准时只需要一个电阻。这个电阻套件本身已经内置,也可以使用你认为更精确的外置电阻。至于内置电阻精度其实根本不是问题,因为我们可以精确标定。要求严格的可以借一部四位半或五位半数字表或台表来标定实际值。这个电阻也就无须考虑是否高精度、温漂多少ppm/℃。如果你有高精密金属箔之类基准电阻当然更好,可是真的没必要,烧过头了。
待新版测量套件完成后我会抽时间介绍如何将套件变成LCR表
GMT+8, 2026-4-7 07:10 , Processed in 0.179661 second(s), 9 queries , Gzip On, Redis On.
