- 493
- 1459 小时
- 2021-4-23
- 50
- 133758
- 1153
- 493 点
- 841 ¥
- 2009-9-21
谁用过这个箱子?
皇太子的加强版,主要增强了低音效果,按Dali官方的说法是
“It has a unique ability to present the most delicate nuances while also delivering firm, well-defined bass.
”保持力度的同时,又能表现最微妙的细节......
高音看上去还是跟皇太子的一样,低音是5寸定制的。
ROYAL SCEPTER Specifications
Frequency range (+/- 3dB) [Hz]: 60 - 25.000
Sensitivity (2,83 V/1 m) [dB]: 88,0
Nominal impedance [ohms]: 4
Maximum SPL [dB]: 105
Recommended amplifier power [W]: 25 - 150
Crossover frequencies: 3600
High frequency driver: 1 x 3/4 " Soft textile dome
Low frequency driver: 1 x 5 " Polypropylene
Enclosure type: Bass reflex
Bass reflex tuning frequency [Hz]: 42,5
Connection input(s): Bi-wire
Recommended placement: Stand Shelf
Recommended distance from wall: 0.00
Loudspeaker type: Rear Surround
Max loudspeaker dimensions incl. base and grille (HxWxD) [mm]: 185 X 310 X 220
Loudspeaker weight [kg]: 4,9
从图片上看那是相当的靓仔啊~ |
