164 点
169 ¥
发表于 2010-1-2 23:00 | 显示全部楼层
有想法有好
1495 点
1280 ¥
社区贡献 乐于助人
 楼主| 发表于 2010-1-6 09:19 | 显示全部楼层
源程序
显示代码:
*程序说明:此LCD驱动程序可用于LM3037 LCD模块
#include <at89x051.h>
#include <stdio.h>
#include <intrins.h>
#include "OS_CPU.h"
#include "lcd.h"
#include "delaytime.h"
#define INPUT  1
#define OUTPUT 2
#define VOL    3
#define MUTE   4
#define CD     1
#define DVD    2
#define PC     3
#define TUNER  4
#define TV     5
#define  INSIDE 1
#define  OUTER  2
#define MUTECLR 1
#define MUTEDIS 2
*定义单片机与LCD的接口
INT8U code db_value[24]={'-',60,57,54,51,49,46,42,40,38,35,32,30,27,24,21,19,16,13,10,8,5,3,0};
#define Lcd_Bus P1
sbit RS = P3^4;
sbit RW = P3^5;
sbit E        = P3^7;
//sbit PSB= P3^4;
bit RECEIVE_FLG=0;
  INT8U rcmd=0,rdata=0;
* 功能:延时程序,延长时间为a(ms).
void DelayTime(INT16U a)
  INT8U i;
  while(a--)
  for(i=0;i<125;i++);
//写命令到LCD
void Write_Com(INT8U cmdcode)
   RS=0;
   RW=0;
   E=1;
   Lcd_Bus=cmdcode;
   E=0;
   DelayTime(2);
//写数据到LDC
void Write_Data(INT8U disdata)
   RS=1;
   RW=0;
   E=1;
   Lcd_Bus=disdata;
   E=0;
    DelayTime(2);
*功能:初始化LCE屏,可以根据LCD显示的要求作修改
void Lcd_Init(void)
         DelayTime(4);
        Write_Com(0x38);  //选择8bit数据流
         DelayTime(4);
        Write_Com(0x0c);        //开显示,游标OFF,游标位置反白OFF。
         DelayTime(4);
        Write_Com(0x01); //清除显示
         DelayTime(4);
        Write_Com(0x06);
         DelayTime(2);
*  功能:在LCD上显示字符串,并指明起始位置
void Lcd_Str(INT8U startaddr,INT8U  *str)
  Write_Com(startaddr);
  while(*str>0)
  {Write_Data(*str);
    str++;
         DelayTime(2);
*功能:在LCD上显示数字
void Lcd_Num(INT8U startaddr, INT8U disnum)
  INT8U num[3]={0,0,'\0'};
  num[0]=disnum/10%10+0x30;
  num[1]=disnum%10+0x30;
  Lcd_Str(startaddr,num);
void Uart_int(void)
  SCON=0x50;
  TMOD=0x20;
  TH1=0xfd;
  TL1=0xfd;
  TR1=1;
  ES=1;
  EA=1;
void Uart_interrupt(void) interrupt 4 using 1
  rcmd=SBUF;
  RI=0;
  while(!RI);
  rdata=SBUF;
  RI=0;
  RECEIVE_FLG=1;
void ReceiveDeal(void)
  RECEIVE_FLG=0;
  switch(rcmd)
   case INPUT:
               switch(rdata)
                                case CD:
                                        Lcd_Str(0x83,"CD ") ;
                                                break;
                                case DVD:
                                         Lcd_Str(0x83,"DVD") ;
                                                 break;
                                case PC:
                                         Lcd_Str(0x83,"PC ");
                                                 break;
                                case TUNER:
                                          Lcd_Str(0x83,"TUN");
                                                  break;
                                case TV:
                                          Lcd_Str(0x83,"TV ");
                                                  break;
                                default:break;
               break;
   case OUTPUT:
                if(rdata==INSIDE)Lcd_Str(0x88,"内");
                                else if(rdata==OUTER)Lcd_Str(0x88,"外");
               break;
   case VOL:
               Lcd_Str(0x90,"音量:[  ]-  DB");
                           Delay_ms(1);
                           Lcd_Num(0x93,rdata);
                           Delay_ms(1);
                           Lcd_Num(0x95,db_value[rdata]);
                           Lcd_Str(0x97,"    ");
               break;
   case MUTE:
              if(rdata==MUTEDIS) Lcd_Str(0x97,"静音");
                          else if(rdata==MUTECLR)Lcd_Str(0x97,"    ");
               break;
   default:break;
void main(void)
  Uart_int();
  Lcd_Init();
  Lcd_Str(0x82,"HIFIDIY");
  Delay_ms(4);
  Lcd_Str(0x90,"2009参赛作品");
  Delay_ms(2600);
   Lcd_Init();
  Lcd_Str(0x80,"输入:");
  Delay_ms(2);
  Lcd_Str(0x90,"音量:    -  DB");
  Delay_ms(2);
  Lcd_Str(0x85,"输出:");
  while(1)
    if(RECEIVE_FLG)ReceiveDeal();
控制代码
#include<W78e65.h>
#include"OS_CPU.H"
#include"delaytime.h"
#define INPUT  1
#define OUTPUT 2
#define VOL    3
#define MUTE   4
#define CD     1
#define DVD    2
#define PC     3
#define TUNER  4
#define TV     5
#define  INSIDE 1
#define  OUTER  2
#define MUTECLR 1
#define MUTEDIS 2
#define KEY_VOL_INC (P2&0xc0)==0x40
#define KEY_VOL_DEC (P2&0xc0)==0x80
#define KEY_MUTE   (P2&0x20)==0
#define KEY_INPUT_SEL  (P2&0x10)==0
#define KEY_OUTPUT_SEL (P2&0x08)==0
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
sbit key5=P1^4;
sbit key6=P1^5;
sbit key7=P1^6;
sbit key8=P1^7;
sbit key9=P0^7;
sbit key10=P0^6;
sbit key11=P0^5;
sbit key12=P0^4;
sbit key13=P0^3;
sbit BEE=P0^0;
sbit LED2=P0^2;
sbit sc1=P2^0;
sbit sc2=P2^1;
sbit sc3=P2^2;
sbit sc4=P3^3;
sbit sc5=P3^4;
sbit sc6=P3^5;
sbit sc7=P3^6;
sbit sc8=P3^7;
sbit red_pin=P3^2;
bit RECEIVE_FLG=0;
INT8U reddata[4];
typedef enum {VOL_INC_KEY=1,VOL_DEC_KEY,MUTE_KEY,INPUT_SEL_KEY,OUTPUT_SEL_KEY}KEY_VALUE;
INT8U VOL_OFFSET=10;
INT8U INPUT_OFFSET=3;
INT8U OUTPUT_OFFSET=0;
INT8U pre_vol_value=0;
bit MUTE_FLG=0;
INT8U Key_scan(void)
  INT8U key_value=0;
  if(KEY_VOL_INC)key_value=VOL_INC_KEY;
  else if(KEY_VOL_DEC)key_value=VOL_DEC_KEY;
  else if(KEY_MUTE)
    Delay_ms(8);
        if(KEY_MUTE)key_value=MUTE_KEY;
  else if(KEY_INPUT_SEL)
    Delay_ms(8);
        if(KEY_INPUT_SEL)key_value=INPUT_SEL_KEY;
   else if(KEY_OUTPUT_SEL)
    Delay_ms(8);
        if(KEY_OUTPUT_SEL)key_value=OUTPUT_SEL_KEY;
  while((P2&0xf8)!=0xf8)  ;
return key_value;
void Dis_str(INT8U cmd,INT8U sdata)
   SBUF=cmd;
   while(!TI);
   TI=0;
   Delay_ms(3);
   SBUF=sdata;
   while(!TI);
   TI=0;
void Drive_relay(INT8U vol_value)
  if(MUTE_FLG!=1)
     Dis_str(VOL,vol_value);
     switch(vol_value)
                 case 0:
                                 key1=0;Delay_ms(100);
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=1;
                                 break;
                 case 1:
                         key2=0; Delay_ms(100);
                         key1=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=1;
                                 break;
                 case 2:
                         key3=0; Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=1;
                                 break;
                 case 3:
                         key4=0; Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=1;
                                 break;
                 case 4:
                         key5=0; Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=1;
                                 break;
                 case 5:
                         key6=0;Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=1;
                                 break;
                case 6:
                              key7=0;Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=1;
                 break;
                case 7:
                         key8=0;Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=1;
                                 break;
                case 8:
                         key9=0;Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=1;
                                 break;
                case 9:
                         key10=0;Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key11=1;
                             key12=1;
                                 sc6=1;
                                 break;
                case 10:
                         key11=0; Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                             key12=1;
                                 sc6=1;
                                 break;
                case 11:
                         key12=0;Delay_ms(100);
                                 key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                 sc6=1;
                                 break;
                 case 12:
                                  key12=0; Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                                  sc6=0;
                                 break;
                 case 13:
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                             key12=1;
                                 sc6=0;
                                 break;
                 case 14:
                         key10=0; Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key11=1;
                             key12=1;
                                 sc6=0;
                                 break;
                 case 15:
                         key9=0; Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=0;
                                 break;
                 case 16:
                         key8=0; Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=0;
                                 break;
                 case 17:
                         key7=0; Delay_ms(2);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=0;
                                 break;
                case 18:
                              key6=0; Delay_ms(100);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=0;
                 break;
                case 19:
                         key5=0;Delay_ms(2);
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=0;
                                 break;
                case 20:
                         key1=1;
                         key2=1;
                                 key3=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=0;
                                 break;
                case 21:
                         key3=0;Delay_ms(2);
                         key1=1;
                         key2=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=0;
                                 break;
                case 22:
                         key2=0;Delay_ms(100);
                         key1=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=0;
                                 break;
                case 23:
                         key2=1;
                                 key3=1;
                                 key4=1;
                                 key5=1;
                                 key6=1;
                                 key7=1;
                                 key8=1;
                                 key9=1;
                                 key10=1;
                                 key11=1;
                             key12=1;
                                 sc6=0;
                                 break;
           default:break;
void Uart_Init(void)
PCON=0x0;
SCON=0x50; //串口工作方式三
T2MOD=0;
RCAP2L=0xdc;
RCAP2H=0xff;
T2CON=0x30;   //波特率设定rate=9600
TR2=1;
void Key_deal(INT8U key_value)
  if(key_value==VOL_INC_KEY)
        if(VOL_OFFSET<23)
          MUTE_FLG=0;
          VOL_OFFSET++;
          Drive_relay(VOL_OFFSET);
          pre_vol_value=VOL_OFFSET;
  else if(key_value==VOL_DEC_KEY)
    if(VOL_OFFSET>0)
          MUTE_FLG=0;
          VOL_OFFSET--;
  else if(key_value==MUTE_KEY)
        if(MUTE_FLG==1)
           Dis_str(MUTE,MUTECLR);
           Delay_ms(20);
           MUTE_FLG=0;
        else
           Dis_str(MUTE,MUTEDIS);
           Delay_ms(20);
           MUTE_FLG=1;
           Drive_relay(0);
           pre_vol_value=0;
  else if(key_value==INPUT_SEL_KEY)
    if(INPUT_OFFSET<4)INPUT_OFFSET++;
        else INPUT_OFFSET=0;
        switch(INPUT_OFFSET)
          case 0:
                  Dis_str(INPUT,CD);
                  sc1=0;
                          sc2=0;
                          sc3=0;
                          sc4=0;
                          sc5=1;
                          break;
          case 1:
                     Dis_str(INPUT,DVD);
                  sc1=0;
                          sc2=0;
                          sc3=0;
                          sc4=1;
                          sc5=0;
                          break;
          case 2:
                  Dis_str(INPUT,PC);
                  sc1=0;
                          sc2=0;
                          sc3=1;
                          sc4=0;
                          sc5=0;
                          break;
          case 3:
                  Dis_str(INPUT,TUNER);
                  sc1=0;
                          sc2=1;
                          sc3=0;
                          sc4=0;
                          sc5=0;
                          break;
          case 4:
                  Dis_str(INPUT,TV);
                  sc1=1;
                          sc2=0;
                          sc3=0;
                          sc4=0;
                          sc5=0;
                          break;
      default:break;
  else if(key_value==OUTPUT_SEL_KEY)
        if(OUTPUT_OFFSET==1)
           Dis_str(OUTPUT,INSIDE);
           OUTPUT_OFFSET=0;
           sc7=1;
           key13=1;
           LED2=0;
        else
           Dis_str(OUTPUT,OUTER);
           OUTPUT_OFFSET=1;
           sc7=0;
           key13=0;
           LED2=1;
//红外遥控接收程序
void Ds0_83ms(void)
INT8U i;
for(i=0;i<255;i++);
void Ds2_5ms(void)
INT8U i,j;
for(i=0;i<5;i++)
for(j=0;j<153;j++);
void Red_read(void) interrupt 0 using 1//外部中断1的函数
   INT8U i,j;
   INT8U dm=0;
   BOOL RED_FLG=1;
   for(i=0;i<10;i++)
    Ds0_83ms();
    if(red_pin==1)
      RED_FLG=0;
          break;
if(RED_FLG)
    while(!red_pin);
    Ds2_5ms();
    if(red_pin)
     while(red_pin);
     for(i=0;i<4;i++)
          for(j=0;j<8;j++)
              dm>>=1;
              while(!red_pin);
              Ds0_83ms();
              if(red_pin)
                dm=dm|0x80;
                while(red_pin);
         reddata=dm;
         dm=0;
    if((reddata[2]==(~reddata[3])))
       if((reddata[0]==0x08)) RECEIVE_FLG=1;
void ReadKeyDeal(void)
   INT8U key_value=0;
   RECEIVE_FLG=0;
   switch(reddata[2])
         case 0x1d:        //input
                     break;
         case 0x1e://mute
                    key_value=MUTE_KEY;
                    break;
         case 0x1f://output
                    break;
         case 0x15://vol dec
                    break;
         case 0x17://vlo inc
                   break;
         default:break;
   Key_deal(key_value);
   Delay_ms(50);
   BEE=0;
void main(void)
  P0=0xff;
  P1=0xff;
  P2=0xff;
  P3=0xff;
   IT0=1;//外部中断0,下降延触发
   IE0=0;  //清除外部中断0标记位
   EX0=1;
  Uart_Init();
  EA=0;
////音量初始化
   key10=0;
   sc6=1;
        sc1=0;
        sc2=0;
        sc3=0;
        sc4=0;
        sc5=1;
         OUTPUT_OFFSET=0;
         sc7=1;
         key13=1;
         LED2=0;
//  BEE=0;
Delay_ms(3000);
Dis_str(INPUT,CD);
Delay_ms(40);
  Delay_ms(50);
  // Dis_str(VOL,VOL_OFFSET);
   Dis_str(VOL,0);
    Delay_ms(50);
        BEE=0;
EA=1;
  while(1)
    Key_deal(Key_scan());
        if(RECEIVE_FLG==1)
          BEE=1;
          ReadKeyDeal();
125
超级版主 当前在线
11598 点
10591 ¥
社区贡献 论坛贵宾 乐于助人 DIY大赛亚军
发表于 2010-1-6 09:51 | 显示全部楼层
学习……很强大
125
超级版主 当前在线
11598 点
10591 ¥
发表于 2010-1-6 09:52 | 显示全部楼层
学习……很强大
27 点
27 ¥
发表于 2010-1-7 14:50 | 显示全部楼层
全看了,LZ很强大
1381 点
1713 ¥
发表于 2010-1-7 16:26 | 显示全部楼层
楼主能不能帮忙开板呀?
1495 点
1280 ¥
社区贡献 乐于助人
 楼主| 发表于 2010-1-7 18:35 | 显示全部楼层
127# 容桂发烧友
我还想DIY个继电器音源切换+电动电位器音量(遥控控制及编码器控制音量)+JC2前级(或别的分立前级),
音源切换后信号可送外接一部前级,前级输出信号可选送至两部不同的后级。
有兴趣的 话到时多提意见,一起DIY.
890 点
740 ¥
发表于 2010-1-7 19:01 | 显示全部楼层
支持原創
冇大冇细,搞乜春吖!
626 点
657 ¥
发表于 2010-1-7 19:58 | 显示全部楼层
会编程多好,楼主强大
1495 点
1280 ¥
社区贡献 乐于助人
 楼主| 发表于 2010-1-8 00:47 | 显示全部楼层
718 点
689 ¥
发表于 2010-1-11 19:58 | 显示全部楼层
期待成品
151 点
161 ¥
发表于 2010-1-12 00:40 | 显示全部楼层
不是一般的强大啊
781 点
791 ¥
发表于 2010-1-12 10:51 | 显示全部楼层
超强的综合工程啊,看看就好,学不来啊!
317 点
345 ¥
发表于 2010-1-13 16:28 | 显示全部楼层
支持一下
1549 点
1558 ¥
发表于 2010-1-15 15:47 | 显示全部楼层
楼主能不能帮忙开板呀?
容桂发烧友 发表于 2010-1-7 16:26
期待楼主能开板!
486 点
476 ¥
发表于 2010-1-15 17:44 | 显示全部楼层
工程量不得了
1495 点
1280 ¥
社区贡献 乐于助人
 楼主| 发表于 2010-1-16 02:19 | 显示全部楼层
谢谢大家的支持,34票就是对我的支持与肯定。谢谢你们!
禁言警告级 当前离线
硬势力-低烧
Rank: 1
-2 点
67 ¥
发表于 2010-3-4 13:51 | 显示全部楼层
不是一般的强!
161 点
157 ¥
发表于 2010-3-14 20:16 | 显示全部楼层
太强捍了,应出成品
来自上海的
3558 点
1885 ¥
发表于 2010-3-19 18:27 | 显示全部楼层
总算把这DIY做完了,
原计划做两台,客厅及卧室各使用一台。
因时间关系,剩下的一台有空再完成了。
谢谢大家的指点。
最近在规划个电动电位器的,电子音量,继电器音量都DIY了,
继电器方式就是占地面积大 ...
蜡笔 发表于 2009-12-30 19:13
ALPS四连的电动电位器是有的,多见于一些早期的DOLBY-PROLOGIC之类的AV功放中
GMT+8, 2026-4-8 00:53 , Processed in 0.187905 second(s), 9 queries , Gzip On, Redis On.
