- 252
- 456 小时
- 2021-2-2
- 50
- 68425
- 250
- 252 点
- 239 ¥
- 2008-12-12
不久前进了3对,现在就是一边听罗技3寸一边回复呵呵,下面是资料,我感觉是做成密闭比做成倒相音质要来的好不少
DIAPHRAGM MTL [td=1,1,131]Paper
SURROUND MTL [td=1,1,131]Santoprene
NOMINAL IMPEDANCE [td=1,1,131]8 W
DCR IMPEDANCE [td=1,1,131]6.6 W
SENSITIVITY 1W/1m [td=1,1,131]87 dB
FREQUENCY RESPONSE [td=1,1,131]100-20K Hz
FREE AIR RESONANCE [td=1,1,131]100 Hz
VOICE COIL DIAMETER [td=1,1,131]18.4 mm
AIR GAP HEIGHT [td=1,1,131]6 mm
RATED POWER INPUT [td=1,1,131]12 W
MAXIMUM POWER INPUT [td=1,1,131]25 W
FORCE FACTOR, BL [td=1,1,131]3.3 TM
MAGNET WEIGHT (4.1oz) [td=1,1,131]115 g
MOVING MASS [td=1,1,131]1.71 g
FERRO FLUID ENHANCED [td=1,1,131]No
SUSPENSION COMPL. [td=1,1,131]1234.23MN-1
EFFEC.PISTON AREA [td=1,1,131]0.0032M2
Levc [td=1,1,131]0.3mH
Zo [td=1,1,131]52ohm
X-max [td=1,1,131]0.4 mm
Vas [td=1,1,131]1.79 Litr.
Qts [td=1,1,131]0.64
Qms [td=1,1,131]6.59
Qes [td=1,1,131]0.71 |
