798 点
381 ¥
发表于 2009-8-10 19:53 | 显示全部楼层
刘汉盛
5672 点
5633 ¥
发表于 2009-8-10 21:18 | 显示全部楼层
那就是Lightspeed Passive Attenuator了,
核心元件是光耦了。
The Lightspeed Passive Attenuator designed by George Stantscheff (GeorgeHiFi on the audio forums) is by far the very best passive attenuator that I have heard. There is perfect clarity, a widened soundstage, separation of instruments, and seemingly infinite detail. What makes this passive preamplifier interesting is that there are no contact points in the form of a "wiper" as in the case of a potentiometer or "switches" as may be with a discrete stepped attenuator. The key components in the Lightspeed Attenuator are Silonex NSL-32SR2 Optocouplers (PDF - 34kB). The optocoupler device is a sealed unit which consists of a high performance LED that shines on a light dependent resistor (LDR).
中译文:
光速被动衰减器
这由George Stantscheff(在音频论坛的George HiFi)设计的光速被动衰减器是到目前为止我所知道的最最好的被动衰减器,有着完美的透明、宽广的声场、良好的定位、和极为丰富的细节。这前置引人注意的是它没有像滑臂式电位器的滑动摩擦的触点或步进衰减器的转换触点。光速衰减器的关键元件是Silonex NSL-32SR2光耦(PDF-34KB),这光耦器是封装在一起的由高性能的LED照射光依赖电阻(LDR)组成。
The operating principle of the optocoupler is fairly simple. As the intensity of the LED varies, so does the internal resistance of the LDR (resistance decreases with increasing light). So in the case of the Lightspeed Attenuator, we change the volume (resistance) by changing the intensity of the LED. By using a series and shunt combination of optocouplers the attenuator can be configured to produces a constant input and output impedance, regardless of where the voltage control setting is.
It is worth mentioning that the Lightspeed Passive Attenuator is not for every audio system though. First off, it is a passive attenuator so there is no gain. Also, your source output impedance needs to be less than about 100 ohms which makes it suitable for use with several sources. The Lightspeed Attenuator works best with amplifiers that have input impedance greater than about 50k. If you would like to use the attenuator with a low input impedance amplifier best results are achieved by using a suitable buffer between the attenuator and amplifier.
中译文:
这光耦的工作原理非常简单,由于LED光强度的变化,引起LDR内阻的变化(阻值随光强度的增加而减少)。因此对于光速衰减器来说,我们通过改变LED的光度来改变阻值。通过使用光耦衰减器的串联和分流相结合可以配置成恒定的输入和输出阻抗,而与控制电压无关。
光耦衰减器并不适用于全部的音频系统,首先,它是被动衰减器所以它是没有增益的,也要求你的音源输出阻抗小于100欧姆,这样可以适合用几个音源。光耦衰减器连接输入阻抗大于大约50K欧姆的放大器工作最佳,如果你想将这衰减器用于低输入阻抗的放大器通过用合适的缓冲置于衰减器和放大器之间可以获得好结果。
光耦(LED和光依赖电阻)
光耦(LED和光依赖电阻)
798 点
381 ¥
发表于 2009-8-11 11:11 | 显示全部楼层
电路图只有12个晶体管,还有两个中功率管不知是做什么用的.
昨天找到一张类似的电路图,但不知放到那里了,找到了再贴出来
7975 点
7864 ¥
发表于 2009-8-11 11:18 | 显示全部楼层
7975 点
7864 ¥
发表于 2009-8-11 11:22 | 显示全部楼层
2223 点
2130 ¥
发表于 2009-8-11 11:29 | 显示全部楼层
一些带口音的英语的确很搞笑的,我以前听老外说“大大贝斯”,
后来才搞懂是Database的意思,真是晕倒啊。
2223 点
2130 ¥
发表于 2009-8-11 11:34 | 显示全部楼层
中译文:
“光速衰减器”在核物理领域的确存在,现在已经能做到把光速降低到1米/秒。
7975 点
7864 ¥
发表于 2009-8-11 11:44 | 显示全部楼层
2223 点
2130 ¥
发表于 2009-8-11 11:56 | 显示全部楼层
所以我觉得这个光致衰减器就是自娱自乐,自己做的哪有不好的道理呢。
5672 点
5633 ¥
发表于 2009-8-11 13:50 | 显示全部楼层
回复 #186 woaw 的帖子
<light dependent resistor - 不是光敏电阻么? 光依赖电阻是不规范的译法吧>
愿意就是光依赖电阻。
5672 点
5633 ¥
发表于 2009-8-11 14:01 | 显示全部楼层
回复 #190 woaw 的帖子
《我们对于这个光速衰减器的原理应该还没有弄懂.
如果说 LED+LDR=光速衰减器的话, 也太没有技术含量了, 拿LED和LDR的非线性来说, 话就长了.》
用我们自己的话来说或者叫做《光耦音量控制器》更为大家接受,
其特点是没有触点,用固定电阻搭接一个完全不可以调节的串联分流控制音量试一下就会发现这触点的有无的差别。
我是试过的,听感这里没必要说。
178
man
1090 点
634 ¥
发表于 2009-8-11 14:06 | 显示全部楼层
有完整电路图就好了
5672 点
5633 ¥
发表于 2009-8-11 14:08 | 显示全部楼层
回复 #194 骆驼仔 的帖子
这里http://diyaudioprojects.com/Soli ... Passive-Attenuator/有完整电路图和制作方法和过程及注意事项。
976 点
868 ¥
发表于 2009-8-11 15:25 | 显示全部楼层
好机卖好价总有它的理由,反正我做了富豪也不介意买一部.有某著名设计师说过,电路其实都差不多,就看你给了它什么理念,然后你象疯子一样坚持它直到被人接受你就是成功的
2223 点
2130 ¥
发表于 2009-8-12 11:44 | 显示全部楼层
原帖由 ch639827608 于 2009-8-11 14:01 发表
我是试过的,听感这里没必要说。
为什么没必要说听感?难道要说说测试数据?
5672 点
5633 ¥
发表于 2009-8-12 11:50 | 显示全部楼层
回复 #197 音乐传真 的帖子
<为什么没必要说听感?难道要说说测试数据?>
因为是主观的东西,各人自己去感受是最佳的方式。
85
认证会员 当前离线
傻人不眨眼
1889 点
1830 ¥
认证会员
发表于 2009-8-12 18:21 | 显示全部楼层
原帖由 机械站井 于 2009-8-11 15:25 发表
你的后面的是对的。
798 点
381 ¥
发表于 2009-8-13 19:03 | 显示全部楼层
贴个图
178
man
1090 点
634 ¥
发表于 2009-8-13 19:36 | 显示全部楼层
原帖由 nark 于 2009-8-13 19:03 发表
贴个图
此图工作正常吗?真想试下,调电流和输出直流怎样调能介绍下
56
小熊猫
6092 点
5749 ¥
发表于 2009-8-13 19:54 | 显示全部楼层
怎么看怎么像国内用烂的对称电流反馈+射极交叉跟随器~~~~~~~
甚至连测试出来的结果都7,8分相识~~~~~~~~
这个电路图没有问题,补上大功率恒流源就可以工作了~~~~
其他可以参考前级的设计~~~~~
GMT+8, 2026-4-6 15:17 , Processed in 2.390253 second(s), 9 queries , Gzip On, Redis On.
