Box
The box outside dimensions:
Front baffle: 20cm wide and 49.6cm high
Box depth: 29.6cm
Edges are trimmed with a roundover-bit r=12mm.
Driver placement:
Both drivers are centered on the vertical axis.
The distance between the drivers centers are 158.5mm
The distance from the top of the baffle to the tweeter centre: 65mm
The distance from the top of the baffle to the woofer centre: 223.5mm
The box has a removable tweeter baffle. This way we can measure all drivers flush mounted in the same box.
The box is approximately 18 liters and the port tuning is approximately 40Hz.
这个是单元布置,可以改下,不是很好看,当然分频得少为调下
