- 1508
- 4204 小时
- 2026-4-23
- 70
- 102526
- 1932
- 1508 点
- 1480 ¥
- 2009-5-8
ecw638
Elite Coppersleeve Woofer, 6" diameter, 3" External voice coil, 8Ω, New design injected Damped Polymer Composite, (DPC) one piece cone, Uniflow aluminum die cast chassis, Neodymium/Ferrite Hybrid vented magnet motor, high grade magnets, linear impedance copper sleeve, 6mm Xmax, low Qts, low Fs Based on former top quality 6" Neolin unit, the Elite Coppersleeve unit, extends the performance by means of higher linear excursion, fresh design injected DPC cone, fluent aluminum chassis, and copper insulated motor for linear impedance.Easy qualitywise design match-up with Elite Tweeters. |
