求教测量套件!!
[复制链接] 查看: 5585|回复: 22
119 点
0 ¥
 楼主| 发表于 2005-11-19 17:16 | 显示全部楼层
过程是这样的
首先检测电平,将开关置于下、上、中:
<img src="attachments/dvbbs/2005-11/2005111917718194.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-11/2005111917718194.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
调到如图所示电平后,效正声卡:
<img src="attachments/dvbbs/2005-11/2005111917825466.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-11/2005111917825466.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
随后切换到测量栏目,将开关置于上、上、下,测量Z:
<img src="attachments/dvbbs/2005-11/20051119171041250.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-11/20051119171041250.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
就得到上述结果,考虑什么问题呢。这时候连接计算机只有两根线,一根是和声卡输出向连,是单声道的;一根和线路输入相连,结测量板SW和JUSTMLS;话筒输入和Probe没有接(接上也一样)。接线有问题吗?
119 点
0 ¥
 楼主| 发表于 2005-11-19 14:56 | 显示全部楼层
效正的全图?
效正的全图?没懂。
感觉和电平关系不大,我这个电平比较低,但是高的我也试过,还有我没有搞懂功放信号输入的电位器有什么用(就是那个W,我用的50K),说明里面叫开到最小,那么什么时候开大呢?
4977 点
3102 ¥
发表于 2005-11-18 10:16 | 显示全部楼层
连接有问题.
或者联线有问题.也或者是你的声卡电平调整有问题.或者声卡有设置好.也可能你的测试套件内部焊接出问题.不好判断呀.把你的较正发一个全图上来看看.目前看你测的阻抗这一项.电平太低了.
GMT+8, 2026-5-3 09:13 , Processed in 0.111363 second(s), 9 queries , Gzip On, Redis On.
