[基础知识] 我的TDA1543纪念版
[复制链接] 查看: 35318|回复: 68
157
8211 点
2614 ¥
 楼主| 发表于 2005-8-14 11:34 | 显示全部楼层
各位兄台
江湖救急,请帮忙,我等着通电呢[em08][em08][em08][em08]
158
超级贵宾 当前离线
打鬼子的
7491 点
2573 ¥
元老级 super 贵宾
发表于 2005-8-14 11:32 | 显示全部楼层
短接应该效果更好吧!
[em11][em11]
1235 点
2 ¥
是这个道理,不短接的话是用1543内部时钟
157
8211 点
2614 ¥
 楼主| 发表于 2005-8-14 11:26 | 显示全部楼层
但加电上机前有一个问题
SW4开关我没有,请问各位DX,能这样短接吗?能的话,这样可是在用板上的时钟?
如果SW4不装上,也不连线,全部开路状态又如何?
<img src="attachments/dvbbs/2005-8/2005814112655669.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/2005814112655669.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-8/200581411274284.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/200581411274284.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
113
2009 点
887 ¥
发表于 2005-8-14 11:24 | 显示全部楼层
不是两帖
是三贴啦,呵呵
157
8211 点
2614 ¥
 楼主| 发表于 2005-8-14 11:22 | 显示全部楼层
暂时只找到这个变压品器试机
双18V+双9V的,先用上罢。找到好的再换[em11]
<img src="attachments/dvbbs/2005-8/2005814111844148.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/2005814111844148.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
157
8211 点
2614 ¥
 楼主| 发表于 2005-8-14 10:31 | 显示全部楼层
输出电容用两只有极性的一正一反也可以的
有心思还可在二个电容的连接点加偏置电压试下[em11][em11][em11]
1235 点
2 ¥
发表于 2005-8-14 10:17 | 显示全部楼层
论坛的BUG,怎么发了两帖呀?
1235 点
2 ¥
发表于 2005-8-14 10:16 | 显示全部楼层
那样串联就是无级电容了,马兰士经常这样做。
1235 点
2 ¥
426 点
5 ¥
发表于 2005-8-14 10:13 | 显示全部楼层
ELNA BP
输出电容如果用两只有极性的一正一反可以吗?
1970 点
699 ¥
发表于 2005-8-14 01:56 | 显示全部楼层
文招兄焊得很漂亮!
我也是刚刚收到这套05纪念版的1543DAC,本来早就到了,可是又刮风又下雨的,一直过不去拿,也是今天才拿到,一看文招兄的已经快出声了!呵呵!
你的调整电压的方法很有用!我就不用再实验了!照着你的抄就OK 了!
晚些有空做完我也上来讨论!呵呵
779 点
502 ¥
发表于 2005-8-14 00:20 | 显示全部楼层
文兄,天那水有毒,少用为妙呀
搅搅阵
1741 点
1443 ¥
发表于 2005-8-13 23:59 | 显示全部楼层
文胸大或许受欢迎,HIFI发烧却最忌焊屎大督!
93
超级贵宾 当前离线
守时、守信、信心、恒心、好奇
3252 点
1069 ¥
元老级 论坛贵宾 花甲前辈 super 贵宾
发表于 2005-8-13 22:47 | 显示全部楼层
用天拿水不好的原因是它有可能对一些零件有损,
酒精清洗后留下灰白色的东西可以用硬尼龙扫子刷去。它的最大优点是对元件没有腐蚀性,不会损坏零件。
113
2009 点
887 ¥
发表于 2005-8-13 22:22 | 显示全部楼层
看来,老大们都爱面子,焊了板子还给美容,呵呵
157
8211 点
2614 ¥
 楼主| 发表于 2005-8-13 22:04 | 显示全部楼层
wongkm33兄
我认为还是天那水好用,只是我这次买的这瓶不好罢了。现在我用的清洗过后会留下许多水珠,说明不纯。
以前用过酒精,洗后会在板上留下白色的溶解物[em08][em08][em08][em08]
93
超级贵宾 当前离线
守时、守信、信心、恒心、好奇
3252 点
1069 ¥
发表于 2005-8-13 18:17 | 显示全部楼层
最好不要用天拿水清洗,用酒精清洗最好。
在图片中看焊锡是否光亮是不大准的,因为相机拍摄的相片一般会有点失真。
157
8211 点
2614 ¥
 楼主| 发表于 2005-8-13 15:57 | 显示全部楼层
是天那水不好
一洗就变暗了,我对我的焊錫还是满意的,seabreeze兄看看我的CS8412就知了,熔点高的焊錫很难焊的[em02][em02][em02][em02]
779 点
502 ¥
发表于 2005-8-13 15:26 | 显示全部楼层
"文招用的焊锡不好,熔点高,色泽暗"
是文胸的相机差呀!![em11]我觉得先用铝板压平4只1543然后上好镙丝再焊接,这样可以保证1543亲密接触铝板,不知文胸是不是这样搞的呀?[em11][em11][em11]
GMT+8, 2026-5-19 21:48 , Processed in 0.136899 second(s), 8 queries , Gzip On, Redis On.
