- 180
- 86 小时
- 2021-8-18
- 50
- 860814
- 173
- 180 点
- 154 ¥
- 2019-3-27
我的电脑上处理音频是以声卡的时钟为准,数播系统基于Linux。
参考archlinux的文章
https://wiki.archlinux.org/index.php/Envy24control
关于DAC时钟
Hardware Settings
Master Clock
This section allows you to select the source and codec sample rate of the card's master clock. Int indicates a selection that will rely on the card's internal crystal for the clock. S/PDIF In is an advanced capability most often used when synchronizing two or more Ice1712-based cards. To achieve this, one card is set to an Int rate -- it will serve as the master clock. The "S/PDIF Outs" of the master clock card are connected to the "S/PDIF Ins" of the second card, and that card's clock is set to S/PDIF In, effectively "chaining" them together.
When using an Int option, Int 44100 (44.1 kHz) and higher are recommended for digital recording.
我现在用的是DMX 6Fire。
Supported cards
envy24control is designed to control ice1712-based cards, including, but not limited to:
M-Audio Delta 1010
M-Audio Delta 1010LT
M-Audio Delta DiO 2496
M-Audio Delta 66
M-Audio Delta 44
M-Audio Delta 410
M-Audio Audiophile 2496
Terratec EWS 88MT
EWS 88D
EWX 24/96
DMX 6Fire
Phase 88
Hoontech Soundtrack DSP 24
Soundtrack DSP 24 Value
Soundtrack DSP 24 Media 7.1
Event Electronics EZ8
Digigram VX442
Lionstracs
Mediastation
Terrasoniq TS 88
Roland/Edirol DA-2496 |
