198 点
0 ¥
发表于 2005-8-9 23:16 | 显示全部楼层
[讨论]
巨可怕!!!!!!!!!!
双功放推怎样?
低音单独推,分频器简单点吧![em09][em09][em09][em09][em09][em09]
589 点
91 ¥
发表于 2005-8-9 21:19 | 显示全部楼层
投资不菲啊!一只高音2.5K,中音一只0.95K,低音一只2.4K,加上箱体、分频器,要超过2.5W了。好好搞。
再来一个参考:FA的旗舰有个版本是用ETON的单元:<img src="attachments/dvbbs/2005-8/20058921194251.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/20058921194251.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
2万
22907 点
21832 ¥
发表于 2005-8-9 20:22 | 显示全部楼层
162 点
38 ¥
 楼主| 发表于 2005-8-9 19:08 | 显示全部楼层
低音单元ETON 11中音单元ETON 5 高音单元申士宝 7000[贴图]
<img src="attachments/dvbbs/2005-8/200589193626170.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/200589193626170.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-8/200589193634246.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/200589193634246.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-8/200589193650623.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/200589193650623.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-8/200589193657507.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/200589193657507.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-8/2005891937658.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/2005891937658.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
实践出真知
3420 点
2128 ¥
元老级
发表于 2005-8-9 18:09 | 显示全部楼层
能这样考虑吗?分步走会少走弯路地。
第一步:既然投资了就多花点钱搞套论坛的测量套件。
第二步:根据你自己理想中的分频点,先制定一个实验用的分频器。
第三步:确定你的音箱的容积,这个应该是低音单元的容积问题,这里建议分步走,1。先搞好测量套件。2。最大可能地确定听音间的面积。3。先模拟一下你所需要的箱体的正面的尺寸,再用微粒板搞一个实验品。4。随后当然是实际测量低频的平直度啦!5。在这时候是有一点可以调整的,包括容积表面积倒相孔尺寸等,甚至在分频器调整一关都能补救。
第四步:装成品箱,在这中音腔体最好独立一个。毕竟低频单元在箱体的能量会很深地影响中音地。
第五步:调整你的分频器,这时候测量套件会发挥奇效,因为喇叭的灵敏度,相位,分频点衔接,房间特性补偿。。。[em11][em11][em11]
[em11][em11][em11]乱说啦,可能会帮倒忙地[em11][em11][em11]
198 点
0 ¥
发表于 2005-8-9 13:07 | 显示全部楼层
上喇叭PP
4977 点
3102 ¥
发表于 2005-8-9 12:40 | 显示全部楼层
可怕的投资.
真希望能作得很好.如同1999兄所说.在多单元的情况下单元选择的搭配是很重要的.不过你都买了.就试试吧!分频器是很难调了.不过既然已经买了单元就慢慢作.花上很多时间来慢慢调吧.真是可怕.两个11寸低音呢.好大的箱体.偶的电脑慢模拟一次花上不少时间.
162 点
38 ¥
 楼主| 发表于 2005-8-9 12:04 | 显示全部楼层
小弟想请大家帮助设计一个五单元三分频大型落地箱
小弟我己经从东讯把单元买来了所以请各位楼主帮助设计一下分频器
荣誉版主 当前离线
2020 点
1406 ¥
发表于 2005-8-9 09:25 | 显示全部楼层
rt
1、个人觉得这个低音和中低的搭配不大好,低频段的重叠太多。你现在也没有什么测量的曲线,大家都不敢动手,不如先通过参数的模拟,确定一下箱体的容积,尺寸 ,导管的尺寸。确定之后,开始箱子的打样,然后就是上箱测量喇叭,然后才开始动分频器。大家觉得如何?
2、这个中低音的Qts等参数,灵敏度也不匹配,我觉得作为书架箱的低音来用是个很好的单元,但是作为中音用就、、、太浪费了。我觉得应该把中音的腔体独立起来,这样免受低音的影响。高音也应该这样处理。还是建议楼主换个中音单元,灵敏度要89dB左右,F0 100左右
3、所以,先请楼主确定操作的步骤,大家再一步步给你建议
荣誉版主 当前离线
2020 点
1406 ¥
发表于 2005-8-9 09:14 | 显示全部楼层
我提点个人观点,供楼主参考
我贴出详细参数给你
1、低音
* Loudspeaker Enclosure Analysis Program
* LEAP?EnclosureShop 5.0.0.327  九月-12-2003
* ?993-2003 LinearX Systems Inc
* Date: Aug  9, 2005   Tue  9:05 am
* LTD File=C:\PROGRAM FILES\LEAP\Transducers\ETON.LTD
* Electro Mechanical Parameters
Name=        Eton 11-581/50HEX
Note=        Motor constants approximated by Levc
Model=        TSL
Domain=        FreeAir
Shape=        Round
Profile=        Cone
Fmd=           3.0000 KA
Qmd=           1.0000
Flp=           8.0000 KA
Qlp=           2.0000
Znom=           8.0000        Ohm
Revc=           5.4000        Ohm
Sd=          36.3000E-3        M?
Mmd=          53.0255E-3        Kg
Pmax=         150.0000        W
Rtvc=           1.6670        癈/W
Xgap=           8.0000E-3        M
Xcoil=          18.0000E-3        M
Xmax=           5.0000E-3        M
Krm=           4.9100E-3        Ohm
Erm=         650.0000E-3
Kxm=          14.7300E-3        H
Exm=         650.0000E-3
Rms=           1.1496        N稴/M
Mms=          57.0000E-3        Kg
Cms=         584.4670E-6        M/N
Vas=         110.0000E-3        M?
Fo=          27.5742        Hz
Qms=          8.5900
Qes=          0.3000
Qts=          0.2899
BL=          13.3330        T稭
Levc=         689.9852E-6        H
SPLo=          90.6932        dB
No=         737.0498E-3        %
* End
2、中低音
* Date: Aug  9, 2005   Tue  9:06 am
Name=        Eton 5-880/25HEX
Model=        TSL
Domain=        FreeAir
Shape=        Round
Profile=        Cone
Fmd=           3.0000 KA
Qmd=           1.0000
Flp=           8.0000 KA
Qlp=           2.0000
Znom=           8.0000        Ohm
Revc=           6.0000        Ohm
Sd=           7.9000E-3        M?
Mmd=           7.5960E-3        Kg
Pmax=          70.0000        W
Rtvc=           3.5710        癈/W
Xgap=           6.0000E-3        M
Xcoil=          12.0000E-3        M
Xmax=           3.0000E-3        M
Krm=           3.0600E-3        Ohm
Erm=         650.0000E-3
Kxm=           9.1800E-3        H
Exm=         650.0000E-3
Rms=           1.3852        N稴/M
Mms=           8.0000E-3        Kg
Cms=           1.3460E-3        M/N
Vas=          12.0000E-3        M?
Fo=          48.0000        Hz
Qms=          1.7600
Qes=          0.3500
Qts=          0.2900
BL=           6.4650        T稭
Levc=         430.0112E-6        H
SPLo=          87.7585        dB
No=         375.0000E-3        %
* End
952 点
113 ¥
发表于 2005-8-9 08:21 | 显示全部楼层
5单元?
老兄,你要的是气派,还是声音适合。多一个单元多一只鬼啊,呵呵
594 点
131 ¥
发表于 2005-8-8 23:02 | 显示全部楼层
最近我也在搞 前级4阶三分频功放
多年以来一直想搞的 了,就是 一个人开发成本太高,所以一直没开工,方案以及电路仿真倒是都做好了,电路图也画得差不多了,如果有几个人可以摊开版费的话,我也想把梦想中的系统实现,不然的话只能等我那天成了米王才会考虑咯
4977 点
3102 ¥
发表于 2005-8-8 21:13 | 显示全部楼层
软件里有上面单元的数据。
可以尝试设计箱体。但还搞不了太复杂的结构。
589 点
91 ¥
发表于 2005-8-8 20:53 | 显示全部楼层
再来5单元的!!
589 点
91 ¥
发表于 2005-8-8 20:51 | 显示全部楼层
4单元的箱体<img src="attachments/dvbbs/2005-8/200588205050215.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/200588205050215.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-8/200588205056187.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-8/200588205056187.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
589 点
91 ¥
发表于 2005-8-8 20:50 | 显示全部楼层
5单元的代表!
2万
22907 点
21832 ¥
发表于 2005-8-8 19:33 | 显示全部楼层
4977 点
3102 ¥
发表于 2005-8-8 19:19 | 显示全部楼层
不认同楼上的。
箱体对于音质的影响还是很厉害的。分频器同样影响厉害。要想作好箱子任一个环节都不能小看。而主动试分频不见得比被动的成功率高。
也泼一点冷水。楼主先择这个制作方案难度相当大。业余情况下相当难。而又用这么好的单元制作如果不成功会很浪费。
632 点
268 ¥
发表于 2005-8-8 19:06 | 显示全部楼层
这么贵的喇叭谁敢跟你纸上谈兵?
如果你在广州的话我倒是很想协助你装一下,另加给你3条建议:1.哑铃式设计弊多利少,而且成本,难度加大,不如三单元方式.2.箱体对音质影响甚小,分频器设计影响极大,难度也最大,切不可本末倒置!3.电子分频方式成功率很大,而且用于此也符合性价比要求.
881 点
214 ¥
发表于 2005-8-19 18:33 | 显示全部楼层
GMT+8, 2026-5-30 00:01 , Processed in 0.762823 second(s), 9 queries , Gzip On, Redis On.
