130
2127 点
1757 ¥
发表于 2007-12-19 09:52 | 显示全部楼层
本人感觉在讨论QUAD 405电路时不要过分沉淀在“电桥”上,那是一种商业宣传成份大于实际作用的东西。
405制作中...
205 点
154 ¥
发表于 2007-12-19 23:17 | 显示全部楼层
C8 is feedforward network.
2857 点
2785 ¥
 楼主| 发表于 2007-12-20 08:43 | 显示全部楼层
原帖由 JiangWZ 于 2007-12-19 08:27 发表
millwood兄,
请问为啥你的仿真电路里多了一个R4, 应该是一枚0点几欧姆的小电阻与电感L1串联(和R5与电容C4并联形成共轭conjugate), 你的电桥参数是否符合 Z4*Z2 / Z1*Z3 = 1 或者 L = RRC 呢?
R4 was there to dampen the capacitor.
the resistor in parrellel with the capacitor is to counteract the serial resistance in the inductor.
both are highlighted in the JAES paper.
Because of those, the error nulling conditions are quite complicated and different from the ideal error nulling conditions.
2857 点
2785 ¥
 楼主| 发表于 2007-12-20 08:46 | 显示全部楼层
if you compare the simulated topology with the circuit in the JAES paper, you will notice that the current dumper (complimentory pair) is actually the "main amp", and the opamp is the anxillary amplifier, whose job is to correct the (cross-over) distortion in the dumper.
2857 点
2785 ¥
 楼主| 发表于 2007-12-20 08:49 | 显示全部楼层
原帖由 xiaolu36 于 2007-12-18 10:02 发表
是不是大多数功放都可以改成电流倾注式?
yes. most (Linn 3-stage) amps have an input stage + voltage amplification stage, which drive an output stage (complimentary pair). As such, you can easily reconfigure the first two stages as the anxillary amp, and the output stage as the current dumper.
1747 点
1674 ¥
发表于 2007-12-20 09:24 | 显示全部楼层
to millwood:
能否把Sadman分析QUAD405的current dumping的文章扫描上来。个人认为,walker的理论是有点论述不清楚,现在有仿真软件可以很好地验证.
130
2127 点
1757 ¥
发表于 2007-12-20 16:43 | 显示全部楼层
是不是大多数功放都可以改成电流倾注式?
原则上只要是甲类输出的电路都可以增添电流倾注元件后组成电流倾注式,但更加重视原设计者的意愿,应该是利用单端甲类电路组成效果较好。
2857 点
2785 ¥
 楼主| 发表于 2007-12-20 20:13 | 显示全部楼层
音响DSP , Sanderman has quite a few articles on error correction. Unfortunately, I have read none of them.
I do have a few nice papers on current dumping (Walker, and the two AES articles I mentioned), the Hawksford article, and the Cordell paper.
Unfortunately, they are all too big to be uploaded. I will need to figure out a way to shrink them more.
1219 点
1162 ¥
发表于 2007-12-21 16:40 | 显示全部楼层
123 点
58 ¥
发表于 2007-12-22 17:45 | 显示全部楼层
Current Dumpling Audio Amplifier - P.J. Walker
http://quad405.com/currentdumping.pdf
Feedforward Error Correction in Power Amplifiers - J. Vanderkooy and S.P. Lipshitz
http://quad405.com/jaes.pdf
123 点
58 ¥
发表于 2007-12-24 00:15 | 显示全部楼层
Distortion Correction in Audio PowerAmplifiers - M. J. HAWKSFORD
http://www.essex.ac.uk/dces/rese ... correction%20PA.pdf
Distortion Correction Circuits for Audio Amplifiers - M. J. HAWKSFORD
http://www.essex.ac.uk/dces/rese ... tion%20circuits.pdf
来自上海的
3558 点
1885 ¥
发表于 2007-12-24 08:36 | 显示全部楼层
gogowatch:
90楼的连接无法找到
123 点
58 ¥
发表于 2007-12-24 14:01 | 显示全部楼层
http://220.232.128.43/audio/quad ... -%20PJ%20Walker.pdf
http://220.232.128.43/audio/quad ... erkooy-Lipshitz.pdf
http://220.232.128.43/audio/quad ... 0MJ%20Hawksford.pdf
Distortion-Free Amplifiers - Walker et al. - Patent 3970953
http://220.232.128.43/audio/quad ... atent%203970953.pdf
1747 点
1674 ¥
发表于 2008-4-30 17:22 | 显示全部楼层
上面的连接不错,hawksford的就更精彩。
我也会做个来验证下。
1510 点
1301 ¥
发表于 2008-5-15 19:38 | 显示全部楼层
顶这贴 没人有意见吧
鰣の针
905 点
663 ¥
发表于 2008-5-16 01:43 | 显示全部楼层
留个记号~~慢慢学习
1108 点
691 ¥
发表于 2008-6-8 23:10 | 显示全部楼层
不错,这帖子可以多看看
367
4000 点
1902 ¥
发表于 2009-2-28 17:37 | 显示全部楼层
耿耿于怀
虽然一直在听405 也觉得入耳(按网络的文章改过好几处) 但是总觉得那个47欧很不爽 有了这个我总觉得功率分配会不一致
367
4000 点
1902 ¥
发表于 2009-2-28 17:41 | 显示全部楼层
hawksford那照片看起来很像牛顿,特别是发型,故意的吧,呵呵。
精妙绝伦博古通今.嘻嘻
1904 点
1904 ¥
发表于 2009-2-28 17:55 | 显示全部楼层
电路比较古旧。
GMT+8, 2025-12-20 02:22 , Processed in 0.138808 second(s), 6 queries , Gzip On, Redis On.
