264 点
9 ¥
 楼主| 发表于 2005-5-7 14:23 | 显示全部楼层
仿8545的话,分频点就不能上4KHZ了
18W/8545-00
Characteristic sensitivity (2.83V / 1m) :  88 dB
Recommended frequency range :  28 - 4000 Hz
Free air resonance frequency, fs :  28 Hz
DC resistance, Re :  5.5 ohm
Voice coil inductance, Le :  0.4 mH
Effective piston area, Sd :  145 cm²
Moving mass incl. air, md :  20 g
Mechanical loss, Rm :  1.5 Ns/m
Force factor, BL :  8.0 Tm
Equivalent volume, Vas :  48 ltr.
Mechanical Q-factor, Qms :  2.3
Electrical Q-factor, Qes :  0.30
Total Q-factor, Qts :  0.27
Excursion, lin./max. :  ±6.5 / ±10 mm
Voice coil diameter :  42 mm
Rated power handling :  100 W
Net weight :  2.4 kg
GMT+8, 2026-5-3 04:01 , Processed in 0.123396 second(s), 9 queries , Gzip On, Redis On.
