[分立后级] 直刻Mark Levinson NO 535H后级工程进行中
[复制链接] 查看: 28521|回复: 69
66
262 点
242 ¥
发表于 2014-3-26 17:48 | 显示全部楼层
自上第一次仿金嗓子E-405后级是09年,过程就不用多说了,时间比较伧促,自己经验不够,没原厂资料,部分参数不能研究清楚,只能是说一款能出声的产品,也费了好多DIY烧友的心
如今,在偶然的情况下遇上Mark Levinson NO535H 5声道HI- Eng后级,全平衡新颖的电路设计,有原厂的资料下,决定再仿一次,期待当然是希望是完美的,不会成烂尾工程.
Mark Levinson NO53XH后级组合起来极其方便 系列目前有4个型号:单声道后级1*300W NO531H  ,双声道后级2*300W  NO532H ,三声道后级3*300W  NO533H,五声道后级5*200W NO535H,但是我发现它们的功放板是一样的,相差100W之多,跟变压器输出
功率有关?,还是美商的夸大之说。。。
66
262 点
242 ¥
 楼主| 发表于 2014-3-26 17:52 | 显示全部楼层
Mark Levinson
N531H, 532H, 533H
Specifications
All specifications are subject to change without notice.
Input & Output Connectors  one balanced XLR input per channel
one unbalanced RCA input per channel
one pair “Hurricane” loudspeaker outputs with banana-plug
sockets per channel (banana-plug socket not available on the
230 VAC models)
Control Connectors  one Ethernet 10Base-T port
one 3.5mm mono (tip/sleeve) mini plug trigger input, 3-12Vdc
one 3.5mm mono (tip/sleeve) mini plug trigger output, 3-12Vdc
3-pin IEC standard power connector
Rated Output Power 20Hz to 20kHz at <0.5% THD, 300W per channel @ 8 Ω, full
output from 2.25Vrms
Frequency Response within 0.5dB from 10Hz to 20kHz
Signal-to-Noise Ratio >85dB, reference level: 2.83 Vrms
Input Impedance 60 kΩ (balanced); 30 kΩ (unbalanced)
Voltage Gain 26.8dB
Input Sensitivity 2.83Vrms output at 130mVrms input
Power Requirements 100V~, 120V~, 230V~, factory set for destination country
N531H: 300W; N532H: 600W; N533H: 900W
Dimensions*  Height (with feet): 7.65" (19.4cm)
Height (without feet): 6.97" (17.7cm)
Width: 17.75" (45.1cm)
Depth: 19.83" (50.4cm)
*See dimensions diagram on the next page.
Weight  Net weight: N531H: 52.5 lbs (23.8kg)
N532H: 74.0 lbs (33.6kg)
N533H: 90.0 lbs (40.8kg)
Shipping weight: N531H: 62.5 lbs (28.4kg)
N532H: 84.0 lbs (38.1kg)
N533H: 100.0 lbs (45.4kg)
Operating Environment  Operating temperature: 0 to 35C (32 to 95F)
Storage temperature: –30 to 75C (–22 to 167F)
Relative humidity: 95% maximum without condensation
45
禁言警告级 当前离线
Rank: 1
-36 点
128 ¥
发表于 2014-3-26 18:12 | 显示全部楼层
我也想弄台两个人都抬不动的后级
91 点
93 ¥
发表于 2014-3-26 18:13 | 显示全部楼层
又看见好东西了,我都还没开始动手装一套合适自己的音响来玩。
66
262 点
242 ¥
 楼主| 发表于 2014-3-26 18:17 | 显示全部楼层
66
262 点
242 ¥
 楼主| 发表于 2014-3-26 18:19 | 显示全部楼层
拆开散热器后,一目明了看似简单又不简单
86
1781 点
1654 ¥
发表于 2014-3-26 18:21 | 显示全部楼层
HIFI是视觉还是听觉?
66
262 点
242 ¥
 楼主| 发表于 2014-3-26 18:22 | 显示全部楼层
精华在此放大前级
禁言警告级 当前离线
Rank: 1
-3 点
27 ¥
发表于 2014-3-26 18:24 | 显示全部楼层
这么紧凑,抄板要万分小心 期待
66
262 点
242 ¥
 楼主| 发表于 2014-3-26 18:26 | 显示全部楼层
电源部分
427
又双叒叕
19187 点
18086 ¥
发表于 2014-3-26 19:12 | 显示全部楼层
单光耦一块板子上都快有十个
1459 点
1375 ¥
发表于 2014-3-26 19:14 | 显示全部楼层
5条腿的是什么家伙
975 点
945 ¥
发表于 2014-3-26 19:19 | 显示全部楼层
这个要顶
354 点
354 ¥
发表于 2014-3-26 19:30 | 显示全部楼层
用力顶
117
1194 点
1174 ¥
发表于 2014-3-26 20:25 | 显示全部楼层
使劲顶
851 点
571 ¥
发表于 2014-3-26 20:27 | 显示全部楼层
电源部分用这么多3300uf电容
408 点
341 ¥
发表于 2014-3-26 20:39 | 显示全部楼层
好贴,顶
农民工
718 点
594 ¥
发表于 2014-3-26 20:40 | 显示全部楼层
句子 发表于 2014-3-26 19:14
5条腿的是什么家伙
也是三极管,好象是里面多了个二极管吧。。。
280 点
315 ¥
发表于 2014-3-26 22:16 | 显示全部楼层
高手阿
593 点
512 ¥
发表于 2014-3-26 22:21 | 显示全部楼层
5条腿的是什么家伙
内部温补????
